Sip-info DTMF not working
Hello all!
My C2951 is connected via sip trunk to provider.
A provider's station supported only sip-info dtmf method.
My configuratin:
Cisco IOS Software, C2951 Software (C2951-UNIVERSALK9_NPE-M), Version 15.3(2)T, RELEASE SOFTWARE (fc3)
voice service voip
ip address trusted list
  ipv4 10.0.0.0 255.0.0.0
  ipv4 192.168.0.0 255.255.0.0
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
redirect ip2ip
fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback pass-through g711alaw
h323
sip
  registrar server expires max 300 min 60
  asymmetric payload full
  no call service stop
voice class codec 1
codec preference 1 g711alaw
codec preference 2 g711ulaw
codec preference 3 g729r8
voice class codec 2
dial-peer voice 1003 voip
description ** DISA **
service disa
session protocol sipv2
session target ipv4:192.168.130.1
incoming called-number 25119
voice-class codec 2
dtmf-relay sip-notify
no vad
sip-ua
credentials username USER password 7 PASSWORD realm 192.168.130.1
authentication username USER password 7 PASSWORD realm 192.168.130.1
retry invite 3
retry response 3
retry bye 3
retry cancel 3
retry register 3
timers trying 1000
registrar ipv4:192.168.130.1:5071 expires 3600
sip-server ipv4:192.168.130.1:5071
connection-reuse
host-registrar
I configured my Cisco in accordance with
http://www.cisco.com/en/US/docs/ios-xml/ios/voice/sip/configuration/12-4t/voi-sip-dtmf.html#GUID-0E228A53-4405-4730-8D54-B37979E69A8B
"Configuring SIP NOTIFY-Based Out-of-Band DTMF Relay"
But DFMF is not working
Jul 19 11:42:24: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
INFO sip:25119@192.168.130.72;transport=UDP;user=phone SIP/2.0
Via: SIP/2.0/UDP 192.168.130.1:5071;rport;branch=z9hG4bKx49wryuio2wmwota7mg0
From: "Anonimous" <sip:88123039120@192.168.130.1;user=phone;cpc=ordinary>;tag=krtyuiqylh
To: <sip:25119@192.168.130.72;user=phone>;tag=259E2784-2697
Call-ID: 78ne3bcrdkxvujgc0ma6@192.168.130.1
CSeq: 1053 INFO
Contact: <sip:88123039120@192.168.130.1:5071;transport=UDP;user=phone>
Max-Forwards: 70
User-Agent: M-200 Motor 5.86.63 (MPB)
Accept: application/sdp, application/dtmf, application/dtmf-relay
Allow: INVITE, ACK, BYE, CANCEL, OPTIONS, INFO, UPDATE, REGISTER
Supported: timer
Content-Type: application/dfmf-relay
Content-Length: 24
Signal=7
Duration=160
Jul 19 11:42:24: //71037/927E2D62B251/SIP/Msg/ccsipDisplayMsg:
Sent:
lenta-25-router#SIP/2.0 415 Unsupported Media Type
Date: Fri, 19 Jul 2013 07:42:24 GMT
Server: Cisco-SIPGateway/IOS-15.3.2.T
CSeq: 1053 INFO
Content-Length: 0
Pleas, help me. Where's my problem?
Re: Sip-info DTMF not working
Try using a different dtmf-relay function you have sip-notify set and you are not using the notify verb in your signaling.
You will need to allow Notify to use the INFO dtmf method.
Or try dtmf-relay rtp-nte to start with.
you may also need to set voice rtp send-recv but try it without to start with if you need out of band digits use
dtmf-relay rtp-nte digit-drop to the dial-peers
Hello Tim. Thank you for your response.
"You will need to allow Notify to use the INFO dtmf method." - please verify, I did not understand.
In that document
I don't find additional commands to enable INFO dtmf method.
In sip-ua I added " notify telephone-event max-duration 200" , but it not help.
"Or try dtmf-relay rtp-nte to start with." - I tried it, but the provider's station supported only sip-info dtmf method.
VIP Super Bronze
CUCM and IOS gateways can receive SIP INFO (RFC 2976) messages for DTMF but cannot generate them (CSCse50733)
You will need to get a provider that supports other form of DTMF e.g rtp-nte.SIP-INFO is old and deprecatted
Please rate all useful posts
"opportunity is a haughty goddess who waste no time with those who are unprepared"
Please rate all useful posts "The essence of christianity is not the enthronement but the obliteration of self --William Barclay"
Hello.
I  need to receive SIP INFO, and the provider's station supported only sip-info dtmf method.
Debu from my Cisco
The packet from the provider station:
Received:
To: <25119>;tag=259E2784-2697
CSeq: 1053 INFO
Contact: <88123039120>
Max-Forwards: 70
Supported: timer
Content-Length: 24
Signal=7
Duration=160
The packet from my cisco:
CSeq: 1053 INFO
Content-Length: 0
Pavel,
Since you are receiving SIP-INFO from the third party station, what is the dtmf method we are negotiating on the other SIP leg with your provider?
Take a look at sip signalling on both legs using "debug ccsip message" and see the DTMF method negotiated on both legs. This should you go further.
Avinash
Regards, Avinash
844
