Community Member
SIP integration Problems
I have a CUCM 4.1 that I need to integrate with a VoiceBlue (SIP Trunk), but I'm having problems when it tries to call to a different region. All the calls with the regions that use G711 function normaly, but when I try to make a call to a region with G729 the call is dropped.
Does any one have an idea of how I can make this function?
Community Member
Re: SIP integration Problems
What are you using as a transcoder? You need to have a transcoder available in the media resource list in order to transcode from 711 to 729
Community Member
u need to allow g.711 for MTP in your SIP trunk as CM 5.0 and below doesn't support G.729 for "INVITE with SDP".
133
