SIP Invite and authentication
Im trying to establish a SIP trunk between a lab CUBE and a SIP provider.
Incoming calls works from ITSP PSTN to the CUBE.
From the CUBE to ITSP call doesnt work
I spoke to the ITSP and  i know the reason but dont know how to implement it on the CUBE
Im sending my INVITE to the ITSP and my authentication credentials
ITSP respond with a 401 message asking for authentication.
CUBE should then resend my authentication credentials but it doesnt
Instead CUBE sends a 503 Message.
This ITSP explain to me that this is how they do the authentication:
Initial INVITE
They respond with 401 challenge
I should resend authentication
Attached is my running config and full debug
Below is partial debug ccsip events messages error for a quick look.
Any help would be great, thanks
o: <sip:95142221234@X.X.X.36>
Date: Fri, 21 Feb 2014 15:14:13 GMT
Call-ID: d0fe5600-30716d45-31-86b1fac@X.X.X.8
Supported: timer,resource-priority,replaces
Min-SE:  1800
User-Agent: Cisco-CUCM8.6
Allow: INVITE, OPTIONS, INFO, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY
CSeq: 101 INVITE
Expires: 180
Allow-Events: presence, kpml
Supported: X-cisco-srtp-fallback,X-cisco-original-called
Cisco-Guid: 3506329088-0000065536-0000000017-0141238188
Session-Expires:  1800
P-Asserted-Identity: <sip:5142546011@X.X.X.8>
Contact: <sip:5142546011@X.X.X.8:1234;transport=tcp>
Max-Forwards: 69
Content-Type: application/sdp
Content-Length: 213
v=0
o=CiscoSystemsCCM-SIP 1977 1 IN IP4 X.X.X.8
s=SIP Call
c=IN IP4 X.28.158.11
t=0 0
m=audio 25192 RTP/AVP 0 101
a=rtpmap:0 PCMU/8000
a=ptime:20
a=rtpmap:101 telephone-event/8000
a=fmtp:101 0-15
Sent:
INVITE sip:5142221234@siptrunking.bell.ca:1234 SIP/2.0
Via: SIP/2.0/UDP X.X.X.36:1234;branch=z9hG4bK93489C
From: <sip:5142546011@cube.jondoe.com;user=phone>;tag=2EBB4A6A-2656
To: <sip:5142221234@X.X.X.52>
Date: Fri, 21 Feb 2014 15:09:12 GMT
Call-ID: F495F43D-9A4011E3-B620A51A-DECFBE48@cube.jondoe.com
Supported: 100rel,timer,resource-priority,replaces,sdp-anat
Min-SE:  1800
User-Agent: Cisco-SIPGateway/IOS-15.2.4.M4
Allow: INVITE, OPTIONS, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY, INFO, REGISTER
CSeq: 101 INVITE
Timestamp: 1392995352
Contact: <sip:5142546011;tgrp=mtl_01_5142546011;trunk-context=siptrunking.bell.ca@X.X.X.36:1234>
Expires: 60
Allow-Events: telephone-event
Max-Forwards: 68
Content-Disposition: session;handling=required
Content-Length: 250
v=0
o=CiscoSystemsSIP-GW-UserAgent 6383 8345 IN IP4 X.X.X.36
s=SIP Call
c=IN IP4 X.X.X.36
t=0 0
m=audio 16580 RTP/AVP 0 101
c=IN IP4 X.X.X.36
a=fmtp:101 0-15
a=ptime:20
*Feb 21 15:09:12.329: //46391/D0FE56000000/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 100 Trying
Via: SIP/2.0/TCP X.X.X.8:1234;branch=z9hG4bK5647ab195a
From: <sip:5142546011@X.X.X.8>;tag=1977~20a67589-494c-4e2a-8283-ce7e70ffe562-85534657
To: <sip:95142221234@X.X.X.36>
CSeq: 101 INVITE
Server: Cisco-SIPGateway/IOS-15.2.4.M4
Content-Length: 0
*Feb 21 15:09:12.333: //-1/xxxxxxxxxxxx/SIP/Error/get_content_length:
Could not get Content-length
*Feb 21 15:09:12.333: //46392/D0FE56000000/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 100 Trying
CSeq: 101 INVITE
*Feb 21 15:09:12.355: //46392/D0FE56000000/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 401 Unauthorized
To: <sip:5142221234@X.X.X.52>;tag=SD2roa599-144107040-1392995653791
CSeq: 101 INVITE
WWW-Authenticate: DIGEST qop="auth",nonce="BroadWorksXhrxln9gfT1gm0nuBW",realm="siptrunking.bell.ca",algorithm=MD5
Content-Length: 0
*Feb 21 15:09:12.355: //46392/D0FE56000000/SIP/Error/sipSPIHandleAuthChallenge:
Error getting credentials
*Feb 21 15:09:12.355: //46392/D0FE56000000/SIP/Error/act_recdproc_new_message_response:
Error handling AuthenticationChallenge
*Feb 21 15:09:12.355: //-1/xxxxxxxxxxxx/SIP/Event/sipSPIEventInfo: Queued event from SIP SPI : SIPSPI_EV_CC_CALL_DISCONNECT
*Feb 21 15:09:12.355: //46392/D0FE56000000/SIP/Event/Session-Timer/sipSTSLMain: Event: E_STSL_SPI_EVENT
*Feb 21 15:09:12.355: //46391/D0FE56000000/SIP/Event/Session-Timer/sipSTSLMain: Event: E_STSL_SESSION_REFRESH_RESP
*Feb 21 15:09:12.355: //46391/D0FE56000000/SIP/Event/Session-Timer/sipSTSLMain: dir:1, method:102, resp_code:503, container:24FC4090
*Feb 21 15:09:12.355: //46391/D0FE56000000/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 503 Service Unavailable
To: <sip:95142221234@X.X.X.36>;tag=2EBB4A84-C56
CSeq: 101 INVITE
Reason: Q.850;cause=47
Content-Length: 0
*Feb 21 15:09:12.355: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
ACK sip:5142221234@X.X.X.52:1234 SIP/2.0
From: <sip:5142546011@cube.jondoe.com>;tag=2EBB4A6A-2656
Max-Forwards: 70
CSeq: 101 ACK
Content-Length: 0
*Feb 21 15:09:12.357: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
ACK sip:95142221234@X.X.X.36:1234 SIP/2.0
Max-Forwards: 70
CSeq: 101 ACK
Content-Length: 0
*Feb 21 15:09:24.211: //46393/000000000000/SIP/Error/sipSPIAddPrivacyHeader:
Orig Container is NULL...should have value except in case of sending OOD Options ping.
*Feb 21 15:09:24.211: //46393/000000000000/SIP/Error/sipSPIAddAssertedIDHeader:
*Feb 21 15:09:24.211: //46393/000000000000/SIP/Error/sipSPIAddPreferredIDHeader:
*Feb 21 15:09:24.211: //46393/000000000000/SIP/Msg/ccsipDisplayMsg:
Sent:
OPTIONS sip:X.X.X.8:1234 SIP/2.0
Via: SIP/2.0/UDP X.X.X.36:1234;branch=z9hG4bK93491142
To: <sip:X.X.X.8>
Date: Fri, 21 Feb 2014 15:09:24 GMT
Call-ID: FBAB0140-9A4011E3-B621A51A-DECFBE48@cube.jondoe.com
Max-Forwards: 70
CSeq: 101 OPTIONS
Everyone's tags (3)
1 ACCEPTED SOLUTION
VIP Super Bronze
Jean,
ITSP is correct, CUBE should send a re-INVITE with the authentication credentials, however you have not configured any..
You need to conigure this changing the number/credentials to what the ITSP has provided for you for authentication
conf t
sip-ua
credentials number 123456 username 123456 password XXXXX realm siptrunking.bell.ca
change 123456 to values provided by ITSP..
If you were giving a username/password..use the ff:
sip-ua
credentials username 123456 password 7 123456 realm siptrunking.bell.ca
authentication username 123456 password 7 123456 siptrunking.bell.ca
Please rate all useful posts
"The essence of christianity is not the enthronement but the obliteration of self --William Barclay"
Please rate all useful posts "The essence of christianity is not the enthronement but the obliteration of self --William Barclay"
VIP Super Bronze
Jean,
conf t
sip-ua
sip-ua
You are right, i should have though of it, i will implement it Monday and let you know how that goes, thank you for the fast response
Worked like a charm, thank you.
1745
