SIP Invite format
Hello guys,
I have a problem to one of my customer.
Recently we have extend the number range and since this date we have trouble with inbound calls.
Called number is only specified in "To" field and not in "URI" field, "URI" field contains the general number used to authenticate on the trunk.
This makes all calls routed to general number.
what we received:
Received:
INVITE sip:222620920@217.xxx.xxx.114:5060 SIP/2.0
Record-Route: <sip:85.xxx.xxx.1;lr=on;ftag=as08e0eb54>
IP-src:85.xxx.xxx.16
PORT-src:5060
Via: SIP/2.0/UDP 85.xxx.xxx.1;branch=z9hG4bK50ef.f063de33.0
Via: SIP/2.0/UDP 85.xxx.xxx.16:5060;branch=z9hG4bK5f0bda0f;rport=5060
From: "Wywolanie" <sip:0032495243137@85.xxx.xxx.16>;tag=as08e0eb54
To: <sip:222620213@85.xxx.xxx.1>
038753: Jan 19 11:12:41: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Record-Route: <sip:85.xxx.xxx.1;lr=on;ftag=as23ac57c4>
PORT-src:5060
Via: SIP/2.0/UDP 85.xxx.xxx.1;branch=z9hG4bKabbb.1eeffe5.0
Via: SIP/2.0/UDP 85.xxx.xxx.16:5060;branch=z9hG4bK369f97dd;rport=5060
From: "Wywolanie" <sip:0032495243137@85.xxx.xxx.16>;tag=as23ac57c4
To: <sip:222620921@85.xxx.xxx.1>
Do you this kind of rules can work or not ?
http://www.cisco.com/en/US/products/sw/voicesw/ps5640/products_configuration_example09186a0080982499.shtml
Thanks for your help
Hervé Jacquemin
SIP Invite format
what I knew, the systems are using address in URI to route the calls, in your case:
I think something in Telco side. did you ask them?
Do you have the same problems with the numbers before expansions?
SIP Invite format
hi,
It's what we supposed but the provider said "we change nothing"...
but the problem appeared first time after the range expansion.
383
