SIP INVITE
Good morning,
Please, could you kindly help me with the following matter?
I have some questions regarding how CUCM builds some fields in a SIP INVITE message. Last week I was reviewing logs and I found the below R-URI when an extension calls another extension:
A number--> 7100 ---(1 SIP invite) ----> CUCM ---- (2 SIP invite) ----> B number 7101
1 SIP invite R-URI: sip:0@192.168.1.3; user=phone
2 SIP invite R-URI: sip:5ea27f5e-033b-880c-e304-0729574bfb1@192.168.1.2:51544;transport=tcp where
5ea27f5e-033b-880c-e304-0729574bfb1 is the user part.
I thought the first invite should be sip:7101@192.168.1.3; user=phone. Concerning the invite from CUCM to B number, how does CUCM build the user part from the B number?
Moreover, what are Contact ang tag fields  used for in a sip message? how does CUCM build them?
Thanks in advance.
Juan.
VIP Super Bronze
SIP INVITE
Delgado,
Some of your question will be answered in this document titled understanding sip traces..Please have a read.
https://supportforums.cisco.com/docs/DOC-27105
The request uri ideally will be to a valid extension but in cases where conferencing is involved, the r-uri is usally to some hexadecimal numbers similar to what you have posted.
Please rate all useful posts
"opportunity is a haughty goddess who waste no time with those who are unprepared"
Please rate all useful posts "The essence of christianity is not the enthronement but the obliteration of self --William Barclay"
SIP INVITE
Hi Aokanlawon,
Thanks for your quick response.
I had already read this thread but i didn't find any info regarding the topics i have explained.
In the case i'm facing, conference is not involved, just a basic call between 2 extensions. I have analyzed the complete SIP message and there is no field in the first INVITE (from IP phone to CUCM) where the B number is considered (R-URI sip:0@CUCM IP), so, how CUCM knows where the call has to be progressed? Concerning the 2nd INVITE (from CUCM to IP phone), what does the number indicated (hexadecimal) in the R-URI mean?
Wrt Contact field, why sometimes shows "From" field (A number) and others the hex number?
Juan
VIP Super Bronze
SIP INVITE
Can you please attach the full trace
Re: SIP INVITE
I cannot include the complete trace but a short piece. I hope this help to understand my question.
Thanks¡¡¡
Juan
VIP Super Bronze
SIP INVITE
since I didnt see the full INVITE sent by CUCM to IP Phone2, I can only assume that the INVITE was sent using the contact header rather than the AOR (address of record)
The Contact header says where you are (or rather, where your User Agent is), while the From header says who you are.
You might have several SIP devices all registered to the same Address of Record (the URI you put in the From header).
Further, REGISTER requests use Contact headers to maintain SIP's location service: they let a user agent update a registrar's location information..
Can you check if the contact header for IP Phone 2 matches what you have in the request uri..
SIP INVITE
Hi Aokanlawon,
I have not understood your answer.
I have noticed 2 unexpected behaviours:
- SIP INVITE between IP phone1 and CUCM. R-URI is sent in a strange format (0@CUCM-IP) instead of using B number to complete the R-URI. Why?
- SIP INVITE between CUCM and IP phone2. R-URI is built by adding a large string without sense for me. Why?
In both cases, Contact Header shows A number details. My question regarding Contact Header is why sometimes is complete with a large string as well instead of A number/extension.
BR,
Juan
VIP Super Bronze
SIP INVITE
What version of CUCM is this?
SIP INVITE
CUCM version 8.6.2
VIP Super Bronze
Re: SIP INVITE
I dont know whats going on there..My CUCM 8.6.2 shows the logs in the proper format
INVITE sip:907666930701@10.10.10.32:5060 SIP/2.0
Via: SIP/2.0/UDP 10.10.0.11:5060;branch=z9hG4bK2342979336fbf
From: "Strand" <02065543200>;tag=144360~ffa80926-5fac-4dd6-b405-2dbbc56ae9a2-392166051
To: <907666930701>
Date: Mon, 20 May 2013 15:20:16 GMT
User-Agent: Cisco-CUCM8.6
Re: SIP INVITE
Hi Juan,
     I can answer the second question for you now:
> When a SIP Phone registered with the CUCM makes a calls, the Contact URI is the PKID; the hex value which the CCM application uses to store PID ( Process Identifiers ) in the database.
To answer your second questions, I need you to let me know if when dialing phone B, were you making an enbloc call or digit by digit?
Jagpreet
Re: SIP INVITE
Hi Jagpreet,
I dial the number digit by digit.
Br,
Juan
VIP Super Bronze
SIP INVITE
+5 Jagpreet..I missed the point that these are sip phones
Juan,
If you look down into the trace you will see the remainder of the dialled digits. This is expected with sip phones. Just as with SCCP phones you will see the digits dialled one by one and cucm performing digit analysis. It is very similar. I am sure down in the remainder of the logs you will see the remaining digits dialled..I missed the fact that it was a sip phone
Re: SIP INVITE
Sorry Aokanlawon, I cannot find the dialed digits in the trace. This is what puzzles me. In the original SIP I only find the A number (82052015) and the R-URI and To header completed with a "0". I supposed that perhaps the caller had pressed Recall button, but no. I have dialed B number digit by digit getting the same result.
Jagpreet & Aokanlawon, your help is much appreciate.
Juan
Re: SIP INVITE
Juan,
     A complete set of CCM SDI and SDL traces would be helpful here if you can upload it for a test call.
I shall look into this otherwise as well.
Jagpreet
Re: SIP INVITE
Hi Jagpreet,
I cannot upload SDI/SDL traces but please, let me know anything I should check on logs in order to clarify/understand the behaviour described above.
Juan.
VIP Super Bronze
SIP INVITE
Look for the call-ID for this invite and use it to trace through the logs...You will see the remianing digits dialled somewhere in there
SIP INVITE
Hi...again... :-)
I have retested the case, and now, the INVITE from IP phone (A number) to CUCM is not 0@device IP but 8@device IP. I have gathered logs and after the INVITE, the device sends a NOTIFY, where I cannot see the B number, but CUCM makes the digit analysis of the B number (i don't know where it catchs the info) and progress the call.
Have you ever seen this behaviour?
Juan
VIP Super Bronze
SIP INVITE
Juan,
I will explain how a sip phone signals to CUCM when making a call...Two major things happen
1. The first digit dialled is sent in the INVITE
2. The remaining digits are sent via NOTIFY (in the NOTIFY, you will see the digits that are dialled
The trace below details what happens when a sip phone makes a call. I stopped this trace after digit=8 was dialled
Called number=918772888362
Here we get INVITE with SDP from the sip phone to CUCM
29/2010 10:36:33.771 |//SIP/SIPTcp/wait_SdlReadRsp: Incoming SIP TCP message from 172.18.159.152 on port
51682 index 2321 with 1717 bytes:
INVITE sip:9@172.18.106.59;user=phone SIP/2.0 (first digit dialled =9)
Via: SIP/2.0/TLS 172.18.159.152:51682;branch=z9hG4bK1636ab61
From: "Test User 1" <89919236>;tag=00260bd9669e07147bcb3aac-3cda8f0c
To: <9>
Call-ID: 00260bd9-669e000b-588c0c2b-2193e2a3@172.18.159.152
Max-Forwards: 70
Date: Mon, 29 Mar 2010 14:36:33 GMT
CSeq: 101 INVITE
User-Agent: Cisco-CP9951/9.0.1
Contact: <4A8A8F91-609E-D655-19EA-44EEDCD7B0D6>
Expires: 180
Accept: application/sdp
Allow: ACK,BYE,CANCEL,INVITE,NOTIFY,OPTIONS,REFER,REGISTER,UPDATE,SUBSCRIBE,INFO
Remote-Party-ID: "Test User 1" <89919236>;party=calling;id-type=subscriber;privacy=off;screen=yes
Supported: replaces,join,sdp-anat,norefersub,extended-refer,X-cisco-callinfo,X-cisco-serviceuri,X-cisco-escapecodes,Xcisco-
service-control,X-cisco-srtp-fallback,X-cisco-monrec,X-cisco-config,X-cisco-sis-5.0.0,X-cisco-xsi-9.0.1
Allow-Events: kpml,dialog
Content-Length: 632
Content-Type: application/sdp
Content-Disposition: session;handling=optional
v=0
o=Cisco-SIPUA 26964 0 IN IP4 172.18.159.152
s=SIP Call
t=0 0
m=audio 29254 RTP/SAVP 0 8 18 102 9 116 124 101
c=IN IP4 172.18.159.152
a=crypto:XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
a=rtpmap:0 PCMU/8000
a=rtpmap:8 PCMA/8000
a=rtpmap:18 G729/8000
a=fmtp:18 annexb=no
a=rtpmap:102 L16/16000
a=rtpmap:9 G722/8000
a=rtpmap:116 iLBC/8000
a=fmtp:116 mode=20
a=rtpmap:124 ISAC/16000
a=rtpmap:101 telephone-event/8000
a=fmtp:101 0-15
a=sendrecv
m=video 25466 RTP/AVP 97
b=TIAS:1000000
a=rtpmap:97 H264/90000
a=fmtp:97 profile-level-id=42801E
a=recvonly
+++Next CUCM sends trying++++
03/29/2010 10:36:33.773 |//SIP/SIPTcp/wait_SdlSPISignal: Outgoing SIP TCP message to 172.18.159.152 on port
51682 index 2321
SIP/2.0 100 Trying
To: <9>
CSeq: 101 INVITE
Allow-Events: presence
Content-Length: 0
+++++Unified CM Sends a REFER to play Outside Dialtone++++
03/29/2010 10:36:33.780 |//SIP/SIPTcp/wait_SdlSPISignal: Outgoing SIP TCP message to 172.18.159.152 on port 51682
index 2321
REFER sip:89919236@172.18.159.152:51682 SIP/2.0
Via: SIP/2.0/TLS 172.18.106.59:5061;branch=z9hG4bK151511c5f04bf
To: <89919236>
Call-ID: 7747f400-bb01baf1-14685-3b6a12ac@172.18.106.59
CSeq: 101 REFER
Max-Forwards: 70
Contact: <89919236>
User-Agent: Cisco-CUCM8.0
Expires: 0
Refer-To: cid:1234567890@172.18.106.59
Content-Id: <1234567890@172.18.106.59>
Require: norefersub
Content-Type: application/x-cisco-remotecc-request+xml
Referred-By: <89919236>
Content-Length: 409
97903bc0-a3de-4a15-ba27-44c81fe3adcd-45510542
DtOutsideDialTone
user
++++Unified CM Sends a SUBSCRIBE for KPML++++
03/29/2010 10:36:33.781 |//SIP/SIPTcp/wait_SdlSPISignal: Outgoing SIP TCP message to 172.18.159.152 on port 51682 index 2321
SUBSCRIBE sip:89919236@172.18.159.152:51682 SIP/2.0
Via: SIP/2.0/TLS 172.18.106.59:5061;branch=z9hG4bK1515232b4e84f
To: <89919236>
Call-ID: 7747f400-bb01baf1-14686-3b6a12ac@172.18.106.59
CSeq: 101 SUBSCRIBE
Event: kpml; call-id=00260bd9-669e000b-588c0c2b-2193e2a3@172.18.159.152; from-tag=00260bd9669e07147bcb3aac-3cda8f0c
Expires: 7200
Contact: <9>
Accept: application/kpml-response+xml
Max-Forwards: 70
Content-Type: application/kpml-request+xml
Content-Length: 424
http://www.w3.org/2001/XMLSchema-instance"
xsi:schemaLocation="urn:ietf:params:xml:ns:kpml-request kpml-request.xsd" version="1.0">
[x#*+]|bs
++++ Phone Sends 200 OK for the REFER and SUBSCRIBE ++++
03/29/2010 10:36:33.802 |//SIP/SIPTcp/wait_SdlReadRsp: Incoming SIP TCP message from 172.18.159.152 on port 51682 index 2321 with 453
bytes:
SIP/2.0 200 OK
To: <89919236>;tag=00260bd9669e07167c743311-343ee3af
CSeq: 101 REFER
Server: Cisco-CP9951/9.0.1
Content-Length: 0
03/29/2010 10:36:33.843 |//SIP/SIPTcp/wait_SdlReadRsp: Incoming SIP TCP message from 172.18.159.152 on port
51682 index 2321 with 465 bytes:
SIP/2.0 200 OK
To: <89919236>;tag=00260bd9669e07177ee0d51d-14f56f89
CSeq: 101 SUBSCRIBE
Expires: 7200
Content-Length: 0
SIP/2.0 200 OK
CSeq: 101 SUBSCRIBE
Expires: 7200
Content-Length: 0
220
++++User Dials a ‘1’, phone sends a NOTIFY to CUCM for the digit++++
NOTIFY sip:9@172.18.106.59:5061 SIP/2.0
Via: SIP/2.0/TLS 172.18.159.152:51682;branch=z9hG4bK1cd529ba
To: <9>;tag=1976165806
From: <89919236>;tag=00260bd9669e07177ee0d51d-14f56f89
CSeq: 1001 NOTIFY
Event: kpml
Subscription-State: active; expires=7200
Max-Forwards: 70
Content-Length: 209
Content-Type: application/kpml-response+xml
Content-Disposition: session;handling=required
forced_flush="false" digits="1" tag="Backspace OK"/>
+++Unified CM Replies to NOTIFY With a 200 OK++++
03/29/2010 10:36:34.352 |//SIP/SIPTcp/wait_SdlSPISignal: Outgoing SIP TCP message to 172.18.159.152 on port 51682
index 2321
SIP/2.0 200 OK
Date: Mon, 29 Mar 2010 14:36:34 GMT
CSeq: 1001 NOTIFY
Content-Length: 0
++++Unified CM Replies Sends a REFER to Disable Outside Dialtone+++
03/29/2010 10:36:34.353 |//SIP/SIPTcp/wait_SdlSPISignal: Outgoing SIP TCP message to 172.18.159.152 on port 51682
index 2321
Via: SIP/2.0/TLS 172.18.106.59:5061;branch=z9hG4bK151536ea86ab0
To: <89919236>
Call-ID: 77e08a80-bb01baf2-14687-3b6a12ac@172.18.106.59
CSeq: 101 REFER
Max-Forwards: 70
Contact: <89919236>
Expires: 0
Require: norefersub
Content-Length: 401
Dt_NoTone
user
+++Phone Replies With 200 OK to REFER++++
03/29/2010 10:36:34.402 |//SIP/SIPTcp/wait_SdlReadRsp: Incoming SIP TCP message from 172.18.159.152 on port
51682 index 2321 with 453 bytes:
SIP/2.0 200 OK
To: <89919236>;tag=00260bd9669e07184b08b96b-796ab86f
CSeq: 101 REFER
Content-Length: 0
++++User Dials a ‘8’, phone sends a NOTIFY to CUCM+++
03/29/2010 10:36:34.944 |//SIP/SIPTcp/wait_SdlReadRsp: Incoming SIP TCP message from 172.18.159.152 on port
51682 index 2321 with 896 bytes:
Via: SIP/2.0/TLS 172.18.159.152:51682;branch=z9hG4bK647d03c1
CSeq: 1002 NOTIFY
Event: kpml
Subscription-State: active; expires=7195
Max-Forwards: 70
Content-Length: 209
forced_flush="false" digits="8" tag="Backspace OK"/>
index 2321
SIP/2.0 200 OK
CSeq: 1001 NOTIFY
Content-Length: 0
As you can see this is similar to what you are seeing...The first digit dialled is seen in the INVITE, the remaining digits will be seen in NOTIFY.
SIP INVITE
Many thanks¡¡¡
Just the last question. Is it the normal procedure? I mean, I have noticed this behaviour but not in all the calls so, is it known when CUCM follows this method or when the device sends all the digits in the first INVITE?
Thanks again Jagpreet and Aokanlawon
Juan
VIP Super Bronze
SIP INVITE
If you dial the digit one by one..It will follow this method..If you do a redial where the digits are mostly sent enblock then you might not see this.. You will see an INVITE to the full number, since the phone is not doing a digit by digit dialling.
You can mark the thread as aswered to help others identify the correct responses in the future
930
