Community Member
SIP IOS Gateway Outbound Calls Continue to Ring
I am trying to resolve an issue wherein the outogoing call continues to ring even after the end user has anwsered the phone.  But the incoming call works fine.  This is an IOS Gateway that is connected to a SIP provider and the call is made over the SIP trunk.  Any help in resolving this would be appreciated.  Let me know if I can provide you debugs or other information.
I am not seeing any issues with dial-peers as the call is going out and hence I have not copied them here.  However let me know if you need this.  Thanks
Ashley
1 ACCEPTED SOLUTION
VIP Super Bronze
Ashley after looking at your trace, I can see whats going on. Your provider is not sending 200 okay..
Here in your trace your provider sends 180 with sdp but after that they never sent a 200 ok. You need to contact them. If you want a bullet proof reason that it is their problem you can send me a trace for incoming call and I will show you that cucm sends a 200 ok for the call. You can then put this nicely at their feet and make them earn their wages
+++First 180 with sdp received from telco++++++++++
Received:
SIP/2.0 180 Ringing
Via: SIP/2.0/UDP 10.66.7.218:5060;branch=z9hG4bK6B81
Record-Route: <10.200.7.157:5060>
Call-ID: C5F1CD73-CB5E11E1-84FAAB7B-E412AAC8@10.66.7.218
To: <0097339982779>;tag=sbc0806dd2cbk7s-CC-36
CSeq: 101 INVITE
Contact: <0097339982779>
Allow: INVITE,ACK,OPTIONS,BYE,CANCEL,REGISTER,INFO,PRACK,SUBSCRIBE,NOTIFY,UPDATE,MESSAGE,REFER
Require: 100rel
RSeq: 1
Content-Length: 369
Content-Type: application/sdp
v=0
o=- 6268406 6268406 IN IP4 10.200.7.157
s=SBC call
c=IN IP4 10.200.7.157
t=0 0
m=audio 43398 RTP/AVP 8 0 18 4 2 98 99 97
a=rtpmap:8 PCMA/8000
a=rtpmap:0 PCMU/8000
a=rtpmap:18 G729/8000
a=rtpmap:4 G723/8000
a=rtpmap:2 G726-32/8000
a=rtpmap:98 G726-40/8000
a=rtpmap:99 G726-32/8000
a=rtpmap:97 telephone-event/8000
a=fmtp:97 0-15
a=fmtp:18 annexb=yes
*Jul 12 13:46:18.302: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
+++second 180 with sdp received from telco++++++++++
Received:
SIP/2.0 180 Ringing
CSeq: 101 INVITE
Require: 100rel
RSeq: 1
Content-Length: 369
v=0
s=SBC call
t=0 0
a=fmtp:97 0-15
*Jul 12 13:46:18.958: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
OPTIONS sip:10.66.7.218:5060 SIP/2.0
Via: SIP/2.0/UDP 10.200.7.157:5060;branch=z9hG4bKukebhftds22bachpfu72da2ft
Call-ID: isbcudfu4774ebcd24dspaffffuefo2d2k2o@SoftX3000
To: <10.66.7.218>
CSeq: 1 OPTIONS
Max-Forwards: 70
Content-Length: 0
+++Third 180 with sdp received from telco++++++++++
*Received:
SIP/2.0 180 Ringing
CSeq: 101 INVITE
Require: 100rel
RSeq: 1
Content-Length: 369
v=0
s=SBC call
t=0 0
a=fmtp:97 0-15
*Jul 12 13:46:24.302: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
+++Fourth 180 with sdp received from telco++++++++++
Received:
SIP/2.0 180 Ringing
CSeq: 101 INVITE
Require: 100rel
RSeq: 1
Content-Length: 369
v=0
s=SBC call
t=0 0
a=fmtp:97 0-15
*Jul 12 13:46:32.298: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
+++Fifth 180 with sdp received from telco++++++++++
Received:
SIP/2.0 180 Ringing
CSeq: 101 INVITE
Require: 100rel
RSeq: 1
Content-Length: 369
v=0
s=SBC call
t=0 0
a=fmtp:97 0-15
Ideally after the first 180 ringing your provider should send a 200 ok. I can bet this is Huwaei!
Please rate all useful posts
"'Nature is too thin a screen, the glory of the omnipresent God bursts through it everywhere"-Ralph Waldo Emerson
Please rate all useful posts "The essence of christianity is not the enthronement but the obliteration of self --William Barclay"
VIP Super Bronze
Ashley,
Can you please attach a sh run of your router.
Community Member
Re: SIP IOS Gateway Outbound Calls Continue to Ring
Thanks for taking the time to review this issue.  I have copied the configuration below.
Community Member
Hi ,
Configuration is copied below.
Thanks for taking the time.
voice-card 0
no dspfarm
voice call send-alert
voice service voip
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
redirect ip2ip
sip
  no call service stop
voice class codec 1
codec preference 1 g711alaw
codec preference 2 g729r8
voice translation-rule 1
rule 1 /^2169\(3..\)$/ /7\1/
voice translation-rule 2
rule 1 /^7\(3..\)$/ /012169\1/
voice translation-rule 3
rule 1 /^7\(3..\)$/ /2169\1/
voice translation-profile EXT
translate called 1
voice translation-profile INTERNATIONAL
translate calling 3
voice translation-profile LOCAL
translate calling 2
archive
log config
  hidekeys
interface GigabitEthernet0/0
ip address 10.66.7.218 255.255.255.252
ip virtual-reassembly
duplex auto
speed auto
media-type rj45
interface GigabitEthernet0/1
ip address 10.106.78.7 255.255.255.128
duplex auto
speed auto
media-type rj45
ip route 0.0.0.0 0.0.0.0 10.106.78.1
ip route 10.200.7.156 255.255.255.252 10.66.7.217
ip http server
no ip http secure-server
ip nat source list 1 interface GigabitEthernet0/0
access-list 1 permit 10.106.78.7
control-plane
voice-port 0/1/0
voice-port 0/1/1
voice-port 0/1/2
voice-port 0/1/3
dial-peer voice 7300 voip
translation-profile outgoing EXT
destination-pattern 21693..
session protocol sipv2
session target ipv4:10.104.160.29
incoming called-number .
dtmf-relay rtp-nte
codec g711alaw
dial-peer voice 7301 voip
preference 2
session target ipv4:10.104.160.30
dtmf-relay rtp-nte
codec g711alaw
dial-peer voice 2030 voip
description Test
destination-pattern 00T
session target ipv4:10.200.7.157
session transport udp
incoming called-number 21693..
dtmf-relay rtp-nte
codec g711alaw
dial-peer voice 2040 voip
description National Numbers
destination-pattern 0........
dtmf-relay rtp-nte
codec g711alaw
sip-ua
VIP Super Bronze
Thanks Ashley. Please do a test call and send the ff;
1. debug ccsip messages
2. debug voip ccapi inout
please put the logs in a text file and attach here. Dont paste them directly as it makes the thread very long. Thanks
Community Member
files are attached.
VIP Super Bronze
Received:
SIP/2.0 180 Ringing
CSeq: 101 INVITE
Require: 100rel
RSeq: 1
Content-Length: 369
v=0
s=SBC call
t=0 0
a=fmtp:97 0-15
Received:
SIP/2.0 180 Ringing
CSeq: 101 INVITE
Require: 100rel
RSeq: 1
Content-Length: 369
v=0
s=SBC call
t=0 0
a=fmtp:97 0-15
Received:
To: <10.66.7.218>
CSeq: 1 OPTIONS
Max-Forwards: 70
Content-Length: 0
*Received:
SIP/2.0 180 Ringing
CSeq: 101 INVITE
Require: 100rel
RSeq: 1
Content-Length: 369
v=0
s=SBC call
t=0 0
a=fmtp:97 0-15
Received:
SIP/2.0 180 Ringing
CSeq: 101 INVITE
Require: 100rel
RSeq: 1
Content-Length: 369
v=0
s=SBC call
t=0 0
a=fmtp:97 0-15
Received:
SIP/2.0 180 Ringing
CSeq: 101 INVITE
Require: 100rel
RSeq: 1
Content-Length: 369
v=0
s=SBC call
t=0 0
a=fmtp:97 0-15
Community Member
Thank you very much for this insight.  I was able to compare the logs and see the issue.  Thank you once again
341
