Community Member
SIP is registering but No audio
Hi Experts,
I have a Cisco ASA 5510 running 8.4(5) software version and my asterisk server is placed in the DMZ. The asterisk server is NATed with a public IP and forwarded the SIP port 5060(tcp/udp) and RTP 10000 - 20000 (tcp/udp) to the server. I can register the phone and make calls using public IP (of asterisk server) but can't here anything.
Is there any other ports needs to be opened?
Ejaz
Community Member
Hi,can you see on the ASA any
can you see on the ASA any blocks / Drops?
Perhaps the RTP Port Range is another, than 10000 - 20000. For instance, Cisco uses UDP 16384 - 32767.
DrM
Community Member
This discussion has been
This discussion has been reposted from Hall of Fame to the IP Telephony community.
106
