I have a fax server (10.130.44.12) with sip trunk to cisco voice gateway (10.110.255.130). The Fax team informed me that they can't send any faxes.
I monitored the gateway and I have faxes goining to the PSTN. I see that the fax server is sending lots of invites to my gateway and than I they get a gateway timeout.
FAX server <----SIP-----> cisco gateway <----PRI-----> PSTN
This is my dial peer that is't hitting:
dial-peer voice 21 pots
description Triparty Simulation outbound
preference 1
destination-pattern 08T
progress_ind setup enable 3
progress_ind alert enable 8
progress_ind connect enable 8
port 0/0/0:15
I use translatorX to debug the sip messages.
Did I miss something in the config?
