Community Member
Sip messages for outbound calls
Dear All,
1. I need to make a communication between our softphone to PSTN . when I call from sophtphone(caller)  , the cisco as5350 create a session progress and when the callee (not caller) reject the call without answering it , the cisco must send "busy here" message , but it send it after 30 sec , I think this is the timeout of sip , we also have another cisco device with same configuration in another center but it send the busy here immediately after the callee discounect the call.
  * what command it must be configured on cisco ?
2. another question is that when I dialed a number , the cisco make two session progress for that so 2 times the cell phone rings. specially when ever the callee reject the call. and instead of busy here it send "404 not found" message.
  * Is it possible it because of the registeration message that the cisco sent
    in the middle of the communication and after the first "session Progress"?
Following is the "debug ccsip all " output :
Received:
INVITE sip:19909127708134@10.31.2.235:5060 SIP/2.0
Via: SIP/2.0/UDP 10.31.2.228:5060;branch=z9hG4bK-74681ea7-c035-47ba-9cf8-21df54f47a4e-ppco
Max-Forwards: 10
Contact: <sip:666@10.31.2.228:5060>
To: "0dd20cd3-6a22-4dba-b56f-feeed064ce5d@10.31.2.228"<sip:19909127708134@10.31.2.228>
Call-ID: 0dd20cd3-6a22-4dba-b56f-feeed064ce5d@10.31.2.228
CSeq: 1 INVITE
Allow: INVITE, ACK, CANCEL, OPTIONS, BYE, REFER, NOTIFY, MESSAGE, REGISTER, SUBSCRIBE, INFO
Supported: replaces
User-Agent: UMSV
Graph-Track: #1:0>
Content-Type: application/sdp
Content-Length: 194
v=0
o=- 88211 88211 IN IP4 10.31.2.228
s=UMSV
c=IN IP4 10.31.2.228
t=0 0
m=audio 6232 RTP/AVP 8 101
a=rtpmap:8 PCMA/8000
a=ptime:20
a=rtpmap:101 telephone-event/8000
a=fmtp:101 0-15
Sent:
SIP/2.0 100 Trying
To: "0dd20cd3-6a22-4dba-b56f-feeed064ce5d@10.31.2.228"<sip:19909127708134@10.31.2.228>;tag=9E3248-F68
Date: Thu, 22 Apr 2004 15:41:05 GMT
Server: Cisco-SIPGateway/IOS-12.x
CSeq: 1 INVITE
Allow-Events: telephone-event
Content-Length: 0
*Apr 22 20:11:09: //23707/4D2F5C258DD7/SIP/Info/ccsip_get_rtcp_session_parameters: CURRENT VALUES: stream_callid=23707, current_s
eq_num=0x1BA0
*Apr 22 20:11:09: //23707/4D2F5C258DD7/SIP/Info/ccsip_get_rtcp_session_parameters: NEW VALUES: stream_callid=23707, current_seq_n
um=0x843
*Apr 22 20:11:09: //23707/4D2F5C258DD7/SIP/Info/ccsip_caps_ind: Load DSP with negotiated codec: g711alaw, Bytes=160
*Apr 22 20:11:09: //23707/4D2F5C258DD7/SIP/Info/ccsip_caps_ind: Set forking flag to 0x0
*Apr 22 20:11:09: //23707/4D2F5C258DD7/SIP/Info/sipSPISetDTMFRelayMode: Set DSP for dtmf-relay = CC_CAP_DTMF_RELAY_NTE_AND_OOB
*Apr 22 20:11:09: //23707/4D2F5C258DD7/SIP/Info/sip_set_modem_caps: Preferred (or the one that came from DSM) modem relay=0, from
CLI config=0
*Apr 22 20:11:09: //23707/4D2F5C258DD7/SIP/Info/sip_set_modem_caps: Disabling Modem Relay...
*Apr 22 20:11:09: //23707/4D2F5C258DD7/SIP/Info/sip_generate_sdp_xcaps_list: Modem Relay and T38 disabled. X-cap not needed
*Apr 22 20:11:09: //23707/4D2F5C258DD7/SIP/Info/sip_set_modem_caps: Negotiation already Done. Set negotiated Modem caps and gener
ate SDP Xcap list
*Apr 22 20:11:09: //23707/4D2F5C258DD7/SIP/Info/sip_set_modem_caps: Modem Relay & Passthru both disabled
*Apr 22 20:11:09: //23707/4D2F5C258DD7/SIP/Info/sip_set_modem_caps: nse payload = 0, ptru mode = 0, ptru-codec=0, redundancy=0, x
id=0, relay=0, sprt-retry=12, latecncy=200, compres-dir=3, dict=1024, strnlen=32
*Apr 22 20:11:09: //23707/4D2F5C258DD7/SIP/Media/sipSPISetStreamInfo: 1 Active Streams
*Apr 22 20:11:09: //23707/4D2F5C258DD7/SIP/Media/sipSPISetStreamInfo: Adding stream type (voice+dtmf) from media line 1
caps.stream_count=1,caps.stream[0].stream_type=0x2, caps.stream_list.xmitFunc=
*Apr 22 20:11:09: //23707/4D2F5C258DD7/SIP/Media/sipSPISetStreamInfo: voip_rtp_xmit, caps.stream_list.context=
*Apr 22 20:11:09: //23707/4D2F5C258DD7/SIP/Media/sipSPISetStreamInfo: 0x636524C0 (gccb)
*Apr 22 20:11:09: //23707/4D2F5C258DD7/SIP/Info/ccsip_caps_ind: Load DSP with codec : g711alaw, Bytes=160
*Apr 22 20:11:09: //23707/4D2F5C258DD7/SIP/Info/ccsip_caps_ind: ccsip_caps_ind: ccb->flags_ipip = 0x603
*Apr 22 20:11:09: //23707/4D2F5C258DD7/SIP/Info/ccsip_caps_ack: Set forking flag to 0x3
*Apr 22 20:11:09: //23707/4D2F5C258DD7/SIP/Info/sipSPIValidateGtd: Signal Forward disabled
*Apr 22 20:11:09: //23707/4D2F5C258DD7/SIP/Info/sipSPISendInviteResponse183: Session Type is Media/Qos/Security/RTR SDP body is a
ttached
*Apr 22 20:11:09: //23707/4D2F5C258DD7/SIP/Transport/sipSPISendInviteResponse: Sending 183 Response to the Transport Layer
*Apr 22 20:11:09: //23707/4D2F5C258DD7/SIP/Transport/sipSPITransportSendMessage: msg=0x65A45FEC, addr=10.31.2.228, port=5060, sen
tBy_port=5060, is_req=0, transport=1, switch=0, callBack=0x6159C0E4
*Apr 22 20:11:09: //23707/4D2F5C258DD7/SIP/Transport/sipSPITransportSendMessage: Proceedable for sending msg immediately
*Apr 22 20:11:09: //23707/4D2F5C258DD7/SIP/Transport/sipTransportLogicSendMsg: switch transport is 0
*Apr 22 20:11:09: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportPostSendMessage: Posting send for msg=0x65A45FEC, addr=10.31.2.228,
port=5060, connId=0 for UDP
*Apr 22 20:11:09: //23707/4D2F5C258DD7/SIP/Info/sentInviteResponse18x: Sent a 18x Response
*Apr 22 20:11:09: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 183 Session Progress
CSeq: 1 INVITE
Allow: INVITE, OPTIONS, BYE, CANCEL, ACK, PRACK, COMET, REFER, SUBSCRIBE, NOTIFY, INFO, UPDATE, REGISTER
Contact: <sip:19909127708134@10.31.2.235:5060>
Content-Disposition: session;handling=required
Content-Length: 244
v=0
o=CiscoSystemsSIP-GW-UserAgent 8897 1451 IN IP4 10.31.2.235
s=SIP Call
c=IN IP4 10.31.2.235
t=0 0
m=audio 19514 RTP/AVP 8 101
a=fmtp:101 0-15
a=ptime:20
*Apr 22 20:11:11: //-1/000000000000/SIP/State/sipSPIChangeState: 0x65FB2EC4 : State change from (STATE_NONE, SUBSTATE_NONE)  to (
SIP_STATE_OUTGOING_REGISTER, SUBSTATE_NONE)
*Apr 22 20:11:11: //-1/000000000000/SIP/Info/sipSPIUaddCcbToUACTable: ****Adding to UAC table.
*Apr 22 20:11:11: //-1/000000000000/SIP/Info/sipSPIUaddCcbToTable: Added to table. ccb=0x65FB2EC4 key=262731F-73A311D8-A8BAA69D-3
66BA9F5
*Apr 22 20:11:11: //-1/000000000000/SIP/Transport/sipSPISendRegister: Sending REGISTER to the transport layer
*Apr 22 20:11:11: //-1/000000000000/SIP/Transport/sipSPIGetSwitchTransportFlag: Return the Global configuration, Switch Transport
is FALSE
*Apr 22 20:11:11: //-1/000000000000/SIP/Transport/sipSPITransportSendMessage: msg=0x65A45FEC, addr=10.31.2.228, port=5060, sentBy
_port=0, is_req=1, transport=1, switch=0, callBack=0x615A5A84
*Apr 22 20:11:11: //-1/000000000000/SIP/Transport/sipSPITransportSendMessage: Proceedable for sending msg immediately
*Apr 22 20:11:11: //-1/000000000000/SIP/Transport/sipTransportLogicSendMsg: switch transport is 0
*Apr 22 20:11:11: //-1/000000000000/SIP/Transport/sipTransportLogicSendMsg: Set to send the msg=0x65A45FEC
*Apr 22 20:11:11: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportPostSendMessage: Posting send for msg=0x65A45FEC, addr=10.31.2.228,
port=5060, connId=1 for UDP
*Apr 22 20:11:11: //-1/000000000000/SIP/State/sipSPIChangeState: 0x65FB2EC4 : State change from (SIP_STATE_OUTGOING_REGISTER, SUB
STATE_NONE)  to (SIP_STATE_OUTGOING_REGISTER, SUBSTATE_NONE)
*Apr 22 20:11:11: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
REGISTER sip:10.31.2.228:5060 SIP/2.0
Via: SIP/2.0/UDP  10.31.2.235:5060;branch=z9hG4bK271B51EC6
To: ".+" <sip:.+@10.31.2.228>
Date: Thu, 22 Apr 2004 15:41:11 GMT
Call-ID: 262731F-73A311D8-A8BAA69D-366BA9F5
User-Agent: Cisco-SIPGateway/IOS-12.x
Max-Forwards: 70
Timestamp: 1082648471
CSeq: 73335 REGISTER
Contact: <sip:.+@10.31.2.235:5060>
Expires: 60
Content-Length: 0
*Apr 22 20:11:11: //-1/xxxxxxxxxxxx/SIP/Info/httpish_msg_process_network_msg: Content Length 0, Bytes Remaining 2
*Apr 22 20:11:11: //-1/xxxxxxxxxxxx/SIP/Info/HandleUdpSocketReads: Msg enqueued for SPI with IP addr: 10.31.2.228:5060
*Apr 22 20:11:11: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportProcessNWNewConnMsg: context=0x00000000
Received:
SIP/2.0 200 Ok
Via: SIP/2.0/UDP 10.31.2.235:5060;branch=z9hG4bK271B51EC6;rport=5060
To: ".+"<sip:.+@10.31.2.228>
Max-Forwards: 70
Expires: 60
Content-Length: 0
*Apr 22 20:11:11: //-1/000000000000/SIP/Info/sipSPIUdeleteCcbFromUACTable: ****Deleting from UAC table.
*Apr 22 20:11:11: //-1/000000000000/SIP/Info/sipSPIUdeleteCcbFromTable: Deleting from table. ccb=0x65FB2EC4 key=262731F-73A311D8-
A8BAA69D-366BA9F5
*Apr 22 20:11:11: //-1/000000000000/SIP/Info/sipSPIFlushEventBufferQueue: There are 0 events on the internal queue that are going
to be free'd
*Apr 22 20:11:11: //-1/000000000000/SIP/Info/sipSPIUfreeOneCCB: Freeing ccb 65FB2EC4
*Apr 22 20:11:14: //-1/000000000000/SIP/State/sipSPIChangeState: 0x6600D5AC : State change from (STATE_NONE, SUBSTATE_NONE)  to (
*Apr 22 20:11:14: //-1/000000000000/SIP/Info/sipSPIUaddCcbToUACTable: ****Adding to UAC table.
*Apr 22 20:11:14: //-1/000000000000/SIP/Info/sipSPIUaddCcbToTable: Added to table. ccb=0x6600D5AC key=3D0F15A5-73A411D8-A8BBA69D-
366BA9F5
*Apr 22 20:11:14: //-1/000000000000/SIP/Transport/sipSPISendRegister: Sending REGISTER to the transport layer
*Apr 22 20:11:14: //-1/000000000000/SIP/Transport/sipSPIGetSwitchTransportFlag: Return the Global configuration, Switch Transport
is FALSE
*Apr 22 20:11:14: //-1/000000000000/SIP/Transport/sipSPITransportSendMessage: msg=0x65A46A9C, addr=10.31.2.228, port=5060, sentBy
*Apr 22 20:11:14: //-1/000000000000/SIP/Transport/sipSPITransportSendMessage: Proceedable for sending msg immediately
*Apr 22 20:11:14: //-1/000000000000/SIP/Transport/sipTransportLogicSendMsg: switch transport is 0
*Apr 22 20:11:14: //-1/000000000000/SIP/Transport/sipTransportLogicSendMsg: Set to send the msg=0x65A46A9C
*Apr 22 20:11:14: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportPostSendMessage: Posting send for msg=0x65A46A9C, addr=10.31.2.228,
*Apr 22 20:11:14: //-1/000000000000/SIP/State/sipSPIChangeState: 0x6600D5AC : State change from (SIP_STATE_OUTGOING_REGISTER, SUB
*Apr 22 20:11:14: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
Via: SIP/2.0/UDP  10.31.2.235:5060;branch=z9hG4bK271B65B0
To: "1116" <sip:1116@10.31.2.228>
Date: Thu, 22 Apr 2004 15:41:14 GMT
Call-ID: 3D0F15A5-73A411D8-A8BBA69D-366BA9F5
Max-Forwards: 70
Timestamp: 1082648474
CSeq: 73327 REGISTER
Contact: <sip:1116@10.31.2.235:5060>
Expires: 60
Content-Length: 0
*Apr 22 20:11:14: //-1/xxxxxxxxxxxx/SIP/Info/httpish_msg_process_network_msg: Content Length 0, Bytes Remaining 2
*Apr 22 20:11:14: //-1/xxxxxxxxxxxx/SIP/Info/HandleUdpSocketReads: Msg enqueued for SPI with IP addr: 10.31.2.228:5060
*Apr 22 20:11:14: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportProcessNWNewConnMsg: context=0x00000000
Received:
SIP/2.0 200 Ok
Via: SIP/2.0/UDP 10.31.2.235:5060;branch=z9hG4bK271B65B0;rport=5060
To: "1116"<sip:1116@10.31.2.228>
Max-Forwards: 70
Expires: 60
Content-Length: 0
*Apr 22 20:12:02: //-1/xxxxxxxxxxxx/SIP/Info/httpish_msg_process_network_msg: Content Length 0, Bytes Remaining 2
*Apr 22 20:12:02: //-1/xxxxxxxxxxxx/SIP/Info/HandleUdpSocketReads: Msg enqueued for SPI with IP addr: 10.31.2.228:5060
*Apr 22 20:12:02: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportProcessNWNewConnMsg: context=0x00000000
*Apr 22 20:12:02: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
*Apr 22 20:12:02: //-1/000000000000/SIP/Info/sipSPIUdeleteCcbFromUACTable: ****Deleting from UAC table.
*Apr 22 20:12:02: //-1/000000000000/SIP/Info/sipSPIUdeleteCcbFromTable: Deleting from table. ccb=0x65F3EF00 key=3D0F15A5-73A411D8
-A8BBA69D-366BA9F5
*Apr 22 20:12:02: //-1/000000000000/SIP/Info/sipSPIFlushEventBufferQueue: There are 0 events on the internal queue that are going
to be free'd
*Apr 22 20:12:02: //-1/000000000000/SIP/Info/sipSPIUfreeOneCCB: Freeing ccb 65F3EF00
*Apr 22 20:12:04: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_event_handler:
*Apr 22 20:12:04: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_event_handler: switch(ev.ev_id: 137)
*Apr 22 20:12:04: //23707/4D2F5C258DD7/SIP/Info/ccsip_event_handler:
ccsip_event_handler: peer ID 23709 chans 0x636C8C38 event 137 flags 0x1002003A 0x603 data 0x636C8C38
ccsip_event_handler: CC_EV_H245_SET_MODE: peer ID 23709 chans 0x636C8C38 event 137 flags  0x1002003A 0x603 data 0x636C8C38
ccsip_event_handler: CC_EV_H245_SET_MODE: peer ID 23709 chans 0x636C8C38 event 137 flags 0x1002003A 0x603 data 0x636C8C38, type
= 6
ccsip_event_handler: !!!!!CC_EV_H245_SET_MODE: not clearing VTSP flag
*Apr 22 20:12:04: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_event_handler: CC_R_SUCCESS_WITH_CONFIRMED
*Apr 22 20:12:08: //-1/xxxxxxxxxxxx/SIP/Event/sipSPIEventInfo: Queued event from SIP SPI : SIPSPI_EV_CC_CALL_ALERTING
*Apr 22 20:12:08: //23707/4D2F5C258DD7/SIP/Info/ccsip_bridge: confID = 7645, srcCallID = 23707, dstCallID = 23709
*Apr 22 20:12:08: //23707/4D2F5C258DD7/SIP/Info/sipSPIUupdateCcCallIds: Old src/dest ccCallids: 23707/-1, new src/dest ccCallids:
23707/23709
*Apr 22 20:12:08: //23707/4D2F5C258DD7/SIP/Info/sipSPIUupdateCcCallIds: Old streamcallid=23707, new streamcallid=23707
*Apr 22 20:12:08: //23707/4D2F5C258DD7/SIP/Media/sipSPIProcessRtpSessions: sipSPIProcessRtpSessions
*Apr 22 20:12:08: //23707/4D2F5C258DD7/SIP/Media/sipSPIUpdateRtcpSession: sipSPIUpdateRtcpSession for m-line 1
*Apr 22 20:12:08: //23707/4D2F5C258DD7/SIP/Media/sipSPIUpdateRtcpSession: rtcp_session info
laddr = 10.31.2.235, lport = 19514, raddr = 10.31.2.228, rport=6232, do_rtcp=TRUE
src_callid = 23707, dest_callid = 23709, stream type = voice+dtmf, stream direction = SENDRECV
media_ip_addr = 10.31.2.228
*Apr 22 20:12:08: //23707/4D2F5C258DD7/SIP/Media/sipSPIUpdateRtcpSession: RTP session already created - update
*Apr 22 20:12:08: //23707/4D2F5C258DD7/SIP/Info/ccsip_get_rtcp_session_parameters: CURRENT VALUES: stream_callid=23707, current_s
eq_num=0x843
*Apr 22 20:12:08: //23707/4D2F5C258DD7/SIP/Info/ccsip_get_rtcp_session_parameters: NEW VALUES: stream_callid=23707, current_seq_n
um=0xB379
*Apr 22 20:12:08: //23707/4D2F5C258DD7/SIP/Info/ccsip_caps_ind: Load DSP with negotiated codec: g711alaw, Bytes=160
*Apr 22 20:12:08: //23707/4D2F5C258DD7/SIP/Info/ccsip_caps_ind: Set forking flag to 0x0
*Apr 22 20:12:08: //23707/4D2F5C258DD7/SIP/Info/sipSPISetDTMFRelayMode: Set DSP for dtmf-relay = CC_CAP_DTMF_RELAY_NTE_AND_OOB
*Apr 22 20:12:08: //23707/4D2F5C258DD7/SIP/Info/sip_set_modem_caps: Preferred (or the one that came from DSM) modem relay=0, from
CLI config=0
*Apr 22 20:12:08: //23707/4D2F5C258DD7/SIP/Info/sip_set_modem_caps: Disabling Modem Relay...
*Apr 22 20:12:08: //23707/4D2F5C258DD7/SIP/Info/sip_generate_sdp_xcaps_list: Modem Relay and T38 disabled. X-cap not needed
*Apr 22 20:12:08: //23707/4D2F5C258DD7/SIP/Info/sip_set_modem_caps: Negotiation already Done. Set negotiated Modem caps and gener
ate SDP Xcap list
*Apr 22 20:12:08: //23707/4D2F5C258DD7/SIP/Info/sip_set_modem_caps: Modem Relay & Passthru both disabled
*Apr 22 20:12:08: //23707/4D2F5C258DD7/SIP/Info/sip_set_modem_caps: nse payload = 0, ptru mode = 0, ptru-codec=0, redundancy=0, x
*Apr 22 20:12:08: //23707/4D2F5C258DD7/SIP/Media/sipSPISetStreamInfo: 1 Active Streams
*Apr 22 20:12:08: //23707/4D2F5C258DD7/SIP/Media/sipSPISetStreamInfo: Adding stream type (voice+dtmf) from media line 1
*Apr 22 20:12:08: //23707/4D2F5C258DD7/SIP/Media/sipSPISetStreamInfo: voip_rtp_xmit, caps.stream_list.context=
*Apr 22 20:12:08: //23707/4D2F5C258DD7/SIP/Media/sipSPISetStreamInfo: 0x636524C0 (gccb)
*Apr 22 20:12:08: //23707/4D2F5C258DD7/SIP/Info/ccsip_caps_ind: Load DSP with codec : g711alaw, Bytes=160
*Apr 22 20:12:08: //23707/4D2F5C258DD7/SIP/Info/ccsip_caps_ind: ccsip_caps_ind: ccb->flags_ipip = 0x603
*Apr 22 20:12:08: //23707/4D2F5C258DD7/SIP/Info/sipSPIValidateGtd: Signal Forward disabled
*Apr 22 20:12:08: //23707/4D2F5C258DD7/SIP/Info/sipSPISendInviteResponse183: Session Type is Media/Qos/Security/RTR SDP body is a
ttached
*Apr 22 20:12:08: //23707/4D2F5C258DD7/SIP/Transport/sipSPISendInviteResponse: Sending 183 Response to the Transport Layer
*Apr 22 20:12:08: //23707/4D2F5C258DD7/SIP/Transport/sipSPITransportSendMessage: msg=0x65A4526C, addr=10.31.2.228, port=5060, sen
*Apr 22 20:12:08: //23707/4D2F5C258DD7/SIP/Transport/sipSPITransportSendMessage: Proceedable for sending msg immediately
*Apr 22 20:12:08: //23707/4D2F5C258DD7/SIP/Transport/sipTransportLogicSendMsg: switch transport is 0
*Apr 22 20:12:08: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportPostSendMessage: Posting send for msg=0x65A4526C, addr=10.31.2.228,
*Apr 22 20:12:08: //23707/4D2F5C258DD7/SIP/Info/sentInviteResponse18x: Sent a 18x Response
*Apr 22 20:12:08: //23707/4D2F5C258DD7/SIP/Info/ccsip_caps_ack: Set forking flag to 0x3
*Apr 22 20:12:08: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
CSeq: 1 INVITE
Content-Length: 244
v=0
s=SIP Call
t=0 0
a=fmtp:101 0-15
a=ptime:20
*Apr 22 20:12:40: //-1/xxxxxxxxxxxx/SIP/Event/sipSPIEventInfo: Queued event from SIP SPI : SIPSPI_EV_CC_CALL_DISCONNECT
*Apr 22 20:12:40: //23707/4D2F5C258DD7/SIP/Info/act_recdinvite_disconnect: Performing disconnect
*Apr 22 20:12:40: //23707/4D2F5C258DD7/SIP/Info/sipSPIValidateGtd: Signal Forward disabled
*Apr 22 20:12:40: //23707/4D2F5C258DD7/SIP/Transport/sipSPITransportSendMessage: msg=0x65A4526C, addr=10.31.2.228, port=5060, sen
tBy_port=5060, is_req=0, transport=1, switch=0, callBack=0x6159BBB0
*Apr 22 20:12:40: //23707/4D2F5C258DD7/SIP/Transport/sipSPITransportSendMessage: Proceedable for sending msg immediately
*Apr 22 20:12:40: //23707/4D2F5C258DD7/SIP/Transport/sipTransportLogicSendMsg: switch transport is 0
*Apr 22 20:12:40: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportPostSendMessage: Posting send for msg=0x65A4526C, addr=10.31.2.228,
*Apr 22 20:12:40: //23707/4D2F5C258DD7/SIP/Info/sentErrResDisconnecting: Sent an 3456XX Error Response
*Apr 22 20:12:40: //23707/4D2F5C258DD7/SIP/State/sipSPIChangeState: 0x6603A598 : State change from (STATE_RECD_INVITE, SUBSTATE_N
ONE)  to (STATE_DISCONNECTING, SUBSTATE_NONE)
*Apr 22 20:12:40: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 404 Not Found
CSeq: 1 INVITE
Reason: Q.850;cause=31
Content-Length: 0
*Apr 22 20:12:40: //-1/xxxxxxxxxxxx/SIP/Info/HandleUdpSocketReads: Msg enqueued for SPI with IP addr: 10.31.2.228:5060
*Apr 22 20:12:40: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportProcessNWNewConnMsg: context=0x00000000
Received:
ACK sip:19909127708134@10.31.2.228:5060 SIP/2.0
Max-Forwards: 10
CSeq: 1 ACK
User-Agent: CallCenter
Content-Length: 0
Everyone's tags (4)
Hi Zeinab,
The issue you are facing as mentioned in Case 1 & 2 is during incoming call from PSTN ?
What IOS version you are using?
Is call manager involved in this scenario?
Please share your running-config of gateway.
Nishant Savalia
Regards, Nishant Savalia
Community Member
1.during outgoing call from softphone
2.12.4(7h)
3.the call manager is a .net software developed by our firm
4. we have another scenario in another center with cisco ios 12.4(5a) but hasn't any problem in sending busy herer
also in "debug isdn q931" I noticed that the DISCOUNECT signal is recieved after 30 seconds , is it because of telco ?
    5     version 12.4
    6     service timestamps debug datetime localtime
    7     service timestamps log datetime
    8     no service password-encryption
    9     !
   10     hostname ACCESS-118
   11     !
   12     boot-start-marker
   13     boot system flash:c5350-js-mz.124-25a.bin
   14     no boot startup-test
   15     boot-end-marker
   16     !
   17     no logging console
   18     enable secret 5 $1$M221$2YQ8Ua1LWx1DUlzdIPwno1
   19     !
   20     !
   21     !
   22     resource-pool disable
   23     no aaa new-model
   24     !
   25     resource policy
   26     !
   27     clock timezone GMT 4 30
   28     spe default-firmware spe-firmware-1
   29     !
   30     !
   31     ip cef
   32     !
   33     !
   34     isdn switch-type primary-net5
   35     !
   36     voice call send-alert
   37     voice call disc-pi-off
   38     !
   39     voice service voip
   40      fax protocol t38 ls-redundancy 0 hs-redundancy 0 fallback none
   41      modem passthrough nse codec g711alaw
   42      sip
   43       ds0-num
   44       header-passing
   45       registrar server
   46       no call service stop
   47     !
   48     !
   49     !
   50     !
   51     !
   52     !
   53     !
   54     !
   55     !
   56     voice translation-rule 1
   57      rule 1 /^199/ //
   58     !
   59     !
   60     voice translation-profile OUT
   61      translate calling 1
   62      translate called 1
   63     !
   64     voice translation-profile call
   65     !
   66     !
   67     !
   68     !
   69     username admin password 0 Pendar110
   70     username pendar privilege 15 secret 5 $1$fGxh$0hiSg//QgvwKyXvFyqefA1
   71     !
   72     !
   73     controller E1 3/0
   74      framing NO-CRC4
   75      pri-group timeslots 1-31
   76      cablelength medium
   77     !
   78     controller E1 3/1
   79      pri-group timeslots 1-31
   80      cablelength medium
   81     !
   82     !
   83     interface GigabitEthernet0/0
   84      description "managment"
   85      ip address 10.31.x.x 255.255.255.0
   86      duplex auto
   87      speed auto
   88      negotiation auto
   89     !
   90     interface GigabitEthernet0/1
   91      no ip address
   92      shutdown
   93      duplex auto
   94      speed auto
   95      negotiation auto
   96     !
   97     interface Serial0/0
   98      no ip address
   99      shutdown
  100      clock rate 2000000
  101      no dce-terminal-timing-enable
  102      no fair-queue
  103     !
  104     interface Serial0/1
  105      no ip address
  106      shutdown
  107      clock rate 2000000
  108      no dce-terminal-timing-enable
  109     !
  110     interface Serial3/0:15
  111      no ip address
  112      encapsulation hdlc
  113      isdn switch-type primary-net5
  114      isdn incoming-voice modem 64
  115      isdn T306 400000
  116      isdn T310 400000
  117      isdn bchan-number-order ascending
  118      no cdp enable
  119     !
  120     interface Serial3/1:15
  121      no ip address
  122      encapsulation hdlc
  123      isdn switch-type primary-net5
  124      isdn incoming-voice modem 64
  125      isdn bchan-number-order ascending
  126      no cdp enable
  127     !
  128     interface Async1/00
  129      no ip address
  130      encapsulation slip
  131     !
  132     interface Async1/01
  133      no ip address
  134      encapsulation slip
  135     !
  136     interface Async1/02
  137      no ip address
  138      encapsulation slip
  139     !
  140     interface Async1/03
  141      no ip address
  142      encapsulation slip
  143     !
  144     interface Async1/04
  145      no ip address
  146      encapsulation slip
  147     !
  148     interface Async1/05
  149      no ip address
  150      encapsulation slip
  151     !
  152     interface Async1/06
  153      no ip address
  154      encapsulation slip
  155     !
  156     interface Async1/07
  157      no ip address
  158      encapsulation slip
  159     !
  160     interface Async1/08
  161      no ip address
  162      encapsulation slip
  163     !
  164     interface Async1/09
  165      no ip address
  166      encapsulation slip
  167     !
  168     interface Async1/10
  169      no ip address
  170      encapsulation slip
  171     !
  172     interface Async1/11
  173      no ip address
  174      encapsulation slip
  175     !
  176     interface Async1/12
  177      no ip address
  178      encapsulation slip
  179     !
  180     interface Async1/13
  181      no ip address
  182      encapsulation slip
  183     !
  184     interface Async1/14
  185      no ip address
  186      encapsulation slip
  187     !
  188     interface Async1/15
  189      no ip address
  190      encapsulation slip
  191     !
  192     interface Async1/16
  193      no ip address
  194      encapsulation slip
  195     !
  196     interface Async1/17
  197      no ip address
  198      encapsulation slip
  199     !
  200     interface Async1/18
  201      no ip address
  202      encapsulation slip
  203     !
  204     interface Async1/19
  205      no ip address
  206      encapsulation slip
  207     !
  208     interface Async1/20
  209      no ip address
  210      encapsulation slip
  211     !
  212     interface Async1/21
  213      no ip address
  214      encapsulation slip
  215     !
  216     interface Async1/22
  217      no ip address
  218      encapsulation slip
  219     !
  220     interface Async1/23
  221      no ip address
  222      encapsulation slip
  223     !
  224     interface Async1/24
  225      no ip address
  226      encapsulation slip
  227     !
  228     interface Async1/25
  229      no ip address
  230      encapsulation slip
  231     !
  232     interface Async1/26
  233      no ip address
  234      encapsulation slip
  235     !
  236     interface Async1/27
  237      no ip address
  238      encapsulation slip
  239     !
  240     interface Async1/28
  241      no ip address
  242      encapsulation slip
  243     !
  244     interface Async1/29
  245      no ip address
  246      encapsulation slip
  247     !
  248     interface Async1/30
  249      no ip address
  250      encapsulation slip
  251     !
  252     interface Async1/31
  253      no ip address
  254      encapsulation slip
  255     !
  256     interface Async1/32
  257      no ip address
  258      encapsulation slip
  259     !
  260     interface Async1/33
  261      no ip address
  262      encapsulation slip
  263     !
  264     interface Async1/34
  265      no ip address
  266      encapsulation slip
  267     !
  268     interface Async1/35
  269      no ip address
  270      encapsulation slip
  271     !
  272     interface Async1/36
  273      no ip address
  274      encapsulation slip
  275     !
  276     interface Async1/37
  277      no ip address
  278      encapsulation slip
  279     !
  280     interface Async1/38
  281      no ip address
  282      encapsulation slip
  283     !
  284     interface Async1/39
  285      no ip address
  286      encapsulation slip
  287     !
  288     interface Async1/40
  289      no ip address
  290      encapsulation slip
  291     !
  292     interface Async1/41
  293      no ip address
  294      encapsulation slip
  295     !
  296     interface Async1/42
  297      no ip address
  298      encapsulation slip
  299     !
  300     interface Async1/43
  301      no ip address
  302      encapsulation slip
  303     !
  304     interface Async1/44
  305      no ip address
  306      encapsulation slip
  307     !
  308     interface Async1/45
  309      no ip address
  310      encapsulation slip
  311     !
  312     interface Async1/46
  313      no ip address
  314      encapsulation slip
  315     !
  316     interface Async1/47
  317      no ip address
  318      encapsulation slip
  319     !
  320     interface Async1/48
  321      no ip address
  322      encapsulation slip
  323     !
  324     interface Async1/49
  325      no ip address
  326      encapsulation slip
  327     !
  328     interface Async1/50
  329      no ip address
  330      encapsulation slip
  331     !
  332     interface Async1/51
  333      no ip address
  334      encapsulation slip
  335     !
  336     interface Async1/52
  337      no ip address
  338      encapsulation slip
  339     !
  340     interface Async1/53
  341      no ip address
  342      encapsulation slip
  343     !
  344     interface Async1/54
  345      no ip address
  346      encapsulation slip
  347     !
  348     interface Async1/55
  349      no ip address
  350      encapsulation slip
  351     !
  352     interface Async1/56
  353      no ip address
  354      encapsulation slip
  355     !
  356     interface Async1/57
  357      no ip address
  358      encapsulation slip
  359     !
  360     interface Async1/58
  361      no ip address
  362      encapsulation slip
  363     !
  364     interface Async1/59
  365      no ip address
  366      encapsulation slip
  367     !
  368     interface Group-Async0
  369      no ip address
  370      encapsulation slip
  371      no group-range
  372     !
  373     interface Group-Async1
  374      physical-layer async
  375      no ip address
  376      encapsulation slip
  377      async mode interactive
  378      no peer default ip address
  379     !
  380     !
  381     ip route 0.0.0.0 0.0.0.0 10.31.x.x
  382     no ip http server
  383     !
  384     !
  385     access-list 101 permit ip any any
  386     dialer-list 1 protocol ip permit
  387     snmp-server community public RO
  388     !
  389     !
  390     !
  391     control-plane
  392     !
  393     call treatment on
  394     call threshold global cpu-5sec low 50 high 80 treatment
  395     call threshold global cpu-avg low 50 high 80 treatment
  396     !
  397     !
  398     voice-port 3/0:D
  399      disc_pi_off
  400      input gain 3
  401      output attenuation -3
  402      echo-cancel coverage 32
  403      no non-linear
  404      playout-delay mode fixed
  405      no comfort-noise
  406      cptone DE
  407      timeouts call-disconnect infinity
  408      timeouts wait-release 180
  409      bearer-cap Speech
  410     !
  411     voice-port 3/1:D
  412      disc_pi_off
  413      input gain 3
  414      output attenuation -3
  415      echo-cancel coverage 32
  416      no non-linear
  417      playout-delay mode fixed
  418      no comfort-noise
  419      cptone DE
  420     !
  421     !
  422     !
  423     dial-peer voice 2 pots
  424      translation-profile outgoing OUT
  425      service session
  426      destination-pattern .+
  427      no digit-strip
  428      direct-inward-dial
  429      port 3/1:D
  430      forward-digits all
  431     !
  432     dial-peer voice 4 voip
  433      service session
  434      shutdown
  435      destination-pattern .+
  436      session protocol sipv2
  437      session target sip-server
  438      session transport udp
  439      dtmf-relay rtp-nte
  440      codec g711alaw
  441      no vad
  442     !
  443     dial-peer voice 20 voip
  444      service session
  445      destination-pattern 973T
  446      session protocol sipv2
  447      session target sip-server
  448      dtmf-relay rtp-nte
  449      codec g711alaw
  450      no vad
  451     !
  452     dial-peer voice 10 pots
  453      translation-profile outgoing OUT
  454      service session
  455      destination-pattern .+
  456      no digit-strip
  457      direct-inward-dial
  458      port 3/0:D
  459      forward-digits all
  460     !
  461     dial-peer voice 5 voip
  462      destination-pattern +
  463      session protocol sipv2
  464      session target sip-server
  465      session transport udp
  466      dtmf-relay rtp-nte
  467      codec g711alaw
  468      no vad
  469     !
  470     !
  471     sip-ua
  472      credentials username 1116 password 00141608005A19 realm pendar
  473      authentication username 1116 password 1315121C0F0D16 realm pendar
  474      no remote-party-id
  475      no redirection
  476      srv version 1
  477      retry invite 2
  478      retry bye 1
  479      retry refer 3
  480      retry register 10
  481      timers notify 400
  482      timers refer 567
  483      timers register 100
  484      registrar ipv4:10.31.x.x expires 60
  485      sip-server ipv4:10.31.x.x
  486     !
  487     ss7 mtp2-variant Bellcore 0
  488     ss7 mtp2-variant Bellcore 1
  489     ss7 mtp2-variant Bellcore 2
  490     ss7 mtp2-variant Bellcore 3
  491     !
  492     line con 0
  493      logging synchronous
  494     line aux 0
  495     line vty 0 4
  496      password Pendar110
  497      login local
  498     line 1/00 1/59
  499      modem InOut
  500     !
  501     scheduler allocate 10000 400
  502     ntp broadcastdelay 10
  503     ntp clock-period 17188805
  504     ntp update-calendar
  505     ntp server 217.218.158.42
  506     ntp server 195.146.63.100
  507     end
1). during outgoing call from softphone
----- in this case who is disconnecting the call before answered (i.e. PSTN or your phone)
Please share debug isdn q931 and debug ccsip all for this scenario.
If you are receiving disconnect message from Telco after 30 seconds then you have to contact Telco for this.
Nishant Savalia
560
