sip mtp
Customer has CM in site A.   Site B has a cube router
The flow of voice is phone in Site B, to CM site A back to cube at site B.  I turned off mtp in the trunk connection in CM to the cube router and dtmf stopped working. In bound and outbound calls work but dtmf options for vm or don't work.
Bill
  • IP Telephony
Re: sip mtp
I dont think its an MTP issue, more of a dial peer issue at the cube.  Do you have a copy of the dial peer information from the Cube?
Re: sip mtp
dial-peer voice 9000 voip
translation-profile outgoing OutCallerId
destination-pattern 1..........
voice-class codec 1
no  voice-class sip localhost
no voice-class sip outbound-proxy
voice-class sip early-offer forced
voice-class sip profiles 2
session protocol sipv2
session target sip-server
dtmf-relay rtp-nte
dial-peer voice 860 voip
translation-profile incoming InwardAdd9
destination-pattern 86042689..
--More--                            voice-class codec 1
session target ipv4:192.168.110.11
incoming called-number 86042689..
dtmf-relay rtp-nte
fax protocol pass-through g711ulaw
dial-peer voice 9001 voip
destination-pattern ..........
voice-class codec 1
dtmf-relay rtp-nte
Re: sip mtp
I think it has to do with your DTMF relay setting.
https://supportforums.cisco.com/message/1171155#1171155
It could be a simple signal issue, but not sure without debugs.
dtmf-relay rtp-nte h245-signal might work.
http://www.cisco.com/en/US/docs/ios/12_2t/12_2t11/feature/guide/fth3dtmf.html
496
