paa
SIP NAT
Hello all!
I have a strange problem, trying to use SIP over PAT. In my SIP program I cann't change client IP address. I see that statring 12.2 IOS support NAT SIP without any additional configuration. How can I disable it and using simple NAT without deepper SIP packet changing
192.168.10.x - inside local, 11.11.11.11 - outside local.
deb ip nat trans sip
lotus-3-gate#
074408: *Mar 24 20:45:38.013 PCTime: NAT: SIP: [0] processing INVITE message
074409: *Mar 24 20:45:38.013 PCTime: NAT: SIP: [0] translated embedded address 192.168.10.111->11.11.11.11
074410: *Mar 24 20:45:38.013 PCTime: NAT: SIP: [0] translate embedded port 5060->1025
074411: *Mar 24 20:45:38.013 PCTime: NAT: SIP: [0] register:0 door_created:1
074412: *Mar 24 20:45:38.021 PCTime: NAT: SIP: Contact header found
074413: *Mar 24 20:45:38.021 PCTime: NAT: SIP: Trying to find expires parameter
074414: *Mar 24 20:45:38.021 PCTime: NAT: SIP: [0] translated embedded address 192.168.10.111->11.11.11.11
074415: *Mar 24 20:45:38.021 PCTime: NAT: SIP: [0] No port present. Use new port 5060->1025
074416: *Mar 24 20:45:38.021 PCTime: NAT: SIP: [0] register:0 door_created:1
074417: *Mar 24 20:45:38.021 PCTime: NAT: SIP: [0] message body found
IPNAT SIP SDP: Warning: Invalid named events specified for fmtp attribute.
IPNAT SIP SDP: Warning: Unrecognized attribute (framerate)
074418: *Mar 24 20:45:38.021 PCTime: NAT: SIP: Media Lines present:2
074419: *Mar 24 20:45:38.021 PCTime: NAT: SIP(1): media-port passed as 0
074420: *Mar 24 20:45:38.093 PCTime: NAT: SIP: [1] processing SIP/2.0 100 Trying message
074421: *Mar 24 20:45:38.097 PCTime: NAT: SIP: [1] translated embedded address 11.11.11.11->192.168.10.111
074422: *Mar 24 20:45:38.097 PCTime: NAT: SIP: [1] translate embedded port 1025->5060
074423: *Mar 24 20:45:38.097 PCTime: NAT: SIP: [1] register:0 door_created:1
074424: *Mar 24 20:45:38.105 PCTime: NAT: SIP: [1] processing SIP/2.0 407 Proxy Authentication Required message
074425: *Mar 24 20:45:38.105 PCTime: NAT: SIP: [1] translated embedded address 11.11.11.11->192.168.10.111
074426: *Mar 24 20:45:38.105 PCTime: NAT: SIP: [1] translate embedded port 1025->5060
074427: *Mar 24 20:45:38.105 PCTime: NAT: SIP: [1] register:0 door_created:1
074428: *Mar 24 20:45:38.105 PCTime: NAT: SIP: Contact header found
074429: *Mar 24 20:45:38.105 PCTime: NAT: SIP(1): no prior addr/port translation present. Not supported
074430: *Mar 24 20:45:38.105 PCTime: NAT: SIP: Trying to find expires parameter
074431: *Mar 24 20:45:38.105 PCTime: NAT: SIP(2): no prior addr/port translation present. Not supported
074432: *Mar 24 20:45:38.105 PCTime: NAT: SIP: [1] Got port 5060 for 62.148.237.132
074433: *Mar 24 20:45:38.105 PCTime: NAT: SIP: [1] register:0 door_created:0
074434: *Mar 24 20:45:38.121 PCTime: NAT: SIP: [0] processing ACK message
074435: *Mar 24 20:45:38.121 PCTime: NAT: SIP(1): no prior addr/port translation present. Not supported
074436: *Mar 24 20:45:38.121 PCTime: NAT: SIP(2): no prior addr/port translation present. Not supported
074437: *Mar 24 20:45:38.121 PCTime: NAT: SIP: [0] Got port 5060 for 62.148.237.132
074438: *Mar 24 20:45:38.121 PCTime: NAT: SIP: [0] register:0 door_created:0
074439: *Mar 24 20:45:38.121 PCTime: NAT: SIP: [0] translated embedded address 192.168.10.111->11.11.11.11
074440: *Mar 24 20:45:38.121 PCTime: NAT: SIP: [0] translate embedded port 5060->1025
074441: *Mar 24 20:45:38.121 PCTime: NAT: SIP: [0] register:0 door_created:1
816
