SIP on 2821
Dear all,
I am trying to configure my SIP phones (7960) with a 2821. Is it possible to have my 2821 act as a sip server or should i use an external one?
5 Replies 5
paolo bevilacqua
Configure CME on the router, that will control all you telephones just fine. Can work with SIP or SCCP firmware on the phones, the latter is preferred ad it has mode features and supports different languages.
Hi.
Well thats ok. But what about the sip server that will be needed. All the config seems to use a sip server (external). Wanted to know if i can configure my 2821 as a sip server itself?
Yes, with SIP phones, CME is a SIP server.
But, you will see that SCCP works much better.
Ok. Thanks.
Well i already tested SCCP. Works ok with 7960 and CIPC too :). Now going to test sip.
You are welcome.
Please remember to rate useful posts with the scrollbox below.
