SIP on CME 7
shikamarunara
Level 4
Level 4
I'm working on configuring SIP phones on CME 7 and am getting stuck at the point of creating the profile. In "voice register global" mode, when I invoke "create profile", I get the following errors;
%Error deleting flash:/SIPDefault.cnf (File not found)
%Error deleting flash:/syncinfo.xml (File not found)
%Error deleting flash:/softkeyDefault.xml (File not found)
%Error deleting flash:/softkeyDefault_kpml.xml (File not found)
%Error deleting flash:/SEP001819D52FC8.cnf.xml (File not found)
Has anyone run into this before?
-Shikamarunara
paolo bevilacqua
Is this a cisco phone you're using? Recommend you use SCCP only with these, as you will loose features and localization with SIP, and generally encounter more problems than advantages.
It sounds like your flash: is messed up. What does a 'show flash:' do.
or a simple 'copy run flash:test-my-flash' do?
-nick
