SIP on CME 7
I'm working on configuring SIP phones on CME 7 and am getting stuck at the point of creating the profile. In "voice register global" mode, when I invoke "create profile", I get the following errors;
%Error deleting flash:/SIPDefault.cnf (File not found)
%Error deleting flash:/syncinfo.xml (File not found)
%Error deleting flash:/softkeyDefault.xml (File not found)
%Error deleting flash:/softkeyDefault_kpml.xml (File not found)
%Error deleting flash:/SEP001819D52FC8.cnf.xml (File not found)
Has anyone run into this before?
-Shikamarunara
Hall of Fame Super Gold
Re: SIP on CME 7
Is this a cisco phone you're using? Recommend you use SCCP only with these, as you will loose features and localization with SIP, and generally encounter more problems than advantages.
Re: SIP on CME 7
It sounds like your flash: is messed up. What does a 'show flash:' do.
or a simple 'copy run flash:test-my-flash' do?
-nick
168
