Community Member
SIP out of band ping
Has anyone configured out of band pings on the dial-peer pointing to their SIP providers. If you can you please let me know the procedure or point me to any cisco document.
I appreciate all the help...
Thanks!!
1 REPLY
Re: SIP out of band ping
Here is a Cisco doc/link:
http://www.cisco.com/en/US/partner/docs/ios/voice/cube/configuration/guide/vb-gw-sipsip_ps10591_TSD_Products_Configuration_Guide_Chapter.html#wp1345256
It is for version 15.0 but applies to 12.4 and 12.4T as well.
We have used this with our local carrier. Just make sure your carrier supports the Options Ping Out of Dialog.
HTH.
Bill
Please rate helpful posts.
HTH -Bill (b) http://ucguerrilla.com (t) @ucguerrilla
179
