SIP Outbound Call Failing
I am attempting to troubleshoot an outbound call failing across a SIP trunk. I can dial this specific number from outside the network just fine, but it is the only that is failing across the SIP trunk. I have made calls to similar numbers and they are all routing out the same path. When I dial 18667173880, there is silence for about ten seconds, then fast busy, when I dial any other 18XX number, including 18666978487, the call proceeds and connects. I am not very familiar with SIP Debugs, but I see what I think are key messages:
SIP/2.0 408 Request Timeout
SIP/2.0 503 Service Unavailable
Reason: Q.850;cause=102
I do not know how much of the debug logs are neccesarry, but I will paste them here with the failed call (8667173880) as well as the successful call (8666978487)
I don't really know SIP at all, but from forum searching, I've found it could possibly be a codec issue, an h323 gateway on the other end that is not campatible due to the lack of an 'allow' sip h323 command, or possibly that the endpoint is just non-responsive. But why then does it pickup when I call from my cell phone?
Any help would be greatly appreciated.
*Dec  8 21:58:52.893: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
INVITE sip:918667173880@XXX.XX.83.253:5060 SIP/2.0
Date: Thu, 08 Dec 2011 20:42:50 GMT
Call-Info: <sip:XXX.XX.232.12:5060>;method="NOTIFY;Event=telephone-event;Duration=500"
Allow: INVITE, OPTIONS, INFO, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY, PUBLISH
From: "WP Test" <sip:8346@XXX.XX.232.12>;tag=13a3368a-2ecc-4f4d-bdac-c4e79bb85bf6-75292645
Allow-Events: presence, kpml
Supported: 100rel,timer,replaces
Min-SE:  1800
Remote-Party-ID: "WP Test" <sip:8346@XXX.XX.232.12>;party=calling;screen=yes;privacy=off
Content-Length: 0
User-Agent: Cisco-CUCM6.1
To: <sip:918667173880@XXX.XX.83.253>
Contact: <sip:8346@XXX.XX.232.12:5060;transport=tcp>
Expires: 180
Call-ID: 304b4680-ee11214a-1aabfd-ce814ac@XXX.XX.232.12
Via: SIP/2.0/TCP XXX.XX.232.12:5060;branch=z9hG4bK337aa674f39978
CSeq: 101 INVITE
Session-Expires:  86400
Max-Forwards: 70
*Dec  8 21:58:52.901: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
INVITE sip:18667173880@XXX.XX.63.17:5318 SIP/2.0
Via: SIP/2.0/UDP XXX.XX.83.253:5060;branch=z9hG4bK12C57B12
Remote-Party-ID: "WP Test" <sip:8346@XXX.XX.83.253>;party=calling;screen=yes;privacy=off
From: "WP Test" <sip:8346@XXX.XX.83.253>;tag=741AC90C-1674
To: <sip:18667173880@XXX.XX.63.17>
Date: Thu, 08 Dec 2011 21:58:52 GMT
Call-ID: A6CD0CBC-211E11E1-BBA881D9-E389BFEC@XXX.XX.83.253
Supported: 100rel,timer,resource-priority,replaces,sdp-anat
Min-SE:  1800
Cisco-Guid: 2798376044-555618785-3147989465-3817455596
User-Agent: Cisco-SIPGateway/IOS-12.x
Allow: INVITE, OPTIONS, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY, INFO, REGISTER
CSeq: 101 INVITE
Timestamp: 1323381532
Contact: <sip:8346@XXX.XX.83.253:5060>
Expires: 180
Allow-Events: telephone-event
Max-Forwards: 69
Content-Type: application/sdp
Content-Disposition: session;handling=required
Content-Length: 273
v=0
o=CiscoSystemsSIP-GW-UserAgent 4155 9134 IN IP4 XXX.XX.83.253
s=SIP Call
c=IN IP4 XXX.XX.83.253
t=0 0
m=audio 18564 RTP/AVP 18 101
a=rtpmap:18 G729/8000
a=fmtp:18 annexb=no
a=rtpmap:101 telephone-event/8000
a=fmtp:101 0-15
a=ptime:20
Sent:
SIP/2.0 100 Trying
CSeq: 101 INVITE
Server: Cisco-SIPGateway/IOS-12.x
Content-Length: 0
*Dec  8 21:58:52.969: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 100 Trying
CSeq: 101 INVITE
*Dec  8 21:59:01.481: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
To: <sip:18667173880@XXX.XX.63.17>;tag=aprqngfrt-384igp00000a6
CSeq: 101 INVITE
Content-Length: 0
*Dec  8 21:59:01.485: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
To: <sip:918667173880@XXX.XX.83.253>;tag=741AEA90-9E8
CSeq: 101 INVITE
Content-Length: 0
_________________________________________________________________________________________
293764: *Dec  8 20:43:38.693: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
INVITE sip:918666978487@XXX.XX.83.254:5060 SIP/2.0
Date: Thu, 08 Dec 2011 20:42:15 GMT
From: "WP Test" <sip:8043258346@XXX.XX.232.12>;tag=13a3368a-2ecc-4f4d-bdac-c4e79bb85bf6-75292555
Min-SE:  1800
Remote-Party-ID: "WP Test" <sip:8043258346@XXX.XX.232.12>;party=calling;screen=yes;privacy=off
Content-Length: 0
To: <sip:918666978487@XXX.XX.83.254>
Contact: <sip:8043258346@XXX.XX.232.12:5060;transport=tcp>
Expires: 180
Call-ID: 1b6eb300-ee112127-1aabee-ce814ac@XXX.XX.232.12
337a6f4935e974
CSeq: 101 INVITE
Max-Forwards: 70
293765: *Dec  8 20:43:38.705: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 100 Trying
Via: SIP/2.0/TCP XXX.XX.232.12:5060;branch=z9hG4bK337a6f4935e974
Date: Thu, 08 Dec 2011 20:43:38 GMT
CSeq: 101 INVITE
Allow-Events: t
elephone-event
Content-Length: 0
293767: *Dec  8 20:43:40.801: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
PRACK sip:918666978487@XXX.XX.83.254:5060;transport=tcp SIP/2.0
RAck: 596 101 INVITE
Content-Length: 236
To: <sip:918666978487@XXX.XX.83.254>;tag=591370B8-D02
C
Via: SIP/2.0/TCP XXX.XX.232.12:5060;branch=z9hG4bK337a713ddf3482
CSeq: 102 PRACK
Max-Forwards: 70
v=0
o=CiscoSystemsCCM-SIP 2000 2 IN IP4 XXX.XX.232.12
s=SIP Call
c=IN IP4 XXX.XX.83.45
t=0 0
m=audio 16964 RTP/AVP 18 101
a=ptime:20
a=fmtp:18 annexb=no
a=fmtp:101 0-15
I hope someone can assist. Thank you for your time.
Everyone's tags (7)
Hi.
From your attached log, first thing I can see is that first call goes to XXX.XX.83.253 and receives a timeout
the second call goes to XXX.XX.83.254 and it succesfully connects.
Try to check if there is any problem with .253 sip connection.
You can attach vg config here so we can help you more.
Carlo
Please rate all helpful posts "The more you help the more you learn"
Carlo,
The .253 is one of the SIP trunks in the route list that is offline. I have taken that trunk out of the list and the problem still exists. Apologies, I should have captured the SIP debug when that trunk was not in the list.
version 12.4
service password-encryption
service sequence-numbers
hostname SIP3845-01
boot-start-marker
boot-end-marker
logging message-counter syslog
logging buffered 5000000
no logging console
no aaa new-model
dot11 syslog
no ip source-route
ip cef
ip name-server XXX.XX.62.36
no ipv6 cef
voice-card 0
dspfarm
dsp services dspfarm
voice service voip
address-hiding
allow-connections sip to sip
fax protocol cisco
sip
  bind control source-interface Loopback0
  bind media source-interface Loopback0
  early-offer forced
  midcall-signaling passthru
voice class codec 1
codec preference 1 g711ulaw
codec preference 2 g729r8
voice class sip-profiles 1
request INVITE sip-header Diversion modify "<>" "<>8043258700@XXX.XX.83.254"
request INVITE sip-header Diversion add "Diversion: \"Company\" <>8043258700@XXX.XX.83.254>;reason=unconditional;privacy=off;screen=yes"
voice translation-rule 9
rule 1 /^9\(.*\)/ /\1/
voice translation-rule 110
rule 1 /^804281....\(.*\)/ /\1/
voice translation-profile DIGITSTRIP-9
translate called 9
archive
log config
  hidekeys
ip ftp source-interface Loopback0
interface Loopback0
ip address XXX.XX.83.254 255.255.255.255
interface GigabitEthernet0/0
description Cisco UBE inside interface
ip address XXX.XX.64.150 255.255.255.252
duplex auto
speed auto
media-type rj45
interface GigabitEthernet0/1
description connection to VzB Private IP network
ip address XXX.XX.64.154 255.255.255.252
shutdown
duplex auto
speed auto
media-type rj45
router eigrp 2784
network XXX.XX.0.0
network XXX.XX.0.0
no auto-summary
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 XXX.XX.64.149
ip http server
ip http access-class 23
ip http authentication local
no ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
control-plane
call filter match-list 1 voice
outgoing called-number 9558252
sccp local Loopback0
sccp ccm XXX.XX.232.4 identifier 3 priority 3 version 6.0
sccp ccm XXX.XX.232.20 identifier 2 priority 2 version 6.0
sccp ccm XXX.XX.232.12 identifier 1 priority 1 version 6.0
sccp
sccp ccm group 10
associate ccm 1 priority 1
associate ccm 2 priority 2
associate ccm 3 priority 3
associate profile 2 register SIP01-MTP
dspfarm profile 2 mtp
codec g729r8
maximum sessions software 50
associate application SCCP
dial-peer voice 100 voip
description OUTBOUND Voice SIP calls to VzB
translation-profile outgoing DIGITSTRIP-9
destination-pattern 9T
voice-class sip early-offer forced
voice-class sip profiles 1
session protocol sipv2
session target sip-server
dtmf-relay rtp-nte
ip qos dscp af32 signaling
no vad
dial-peer voice 101 voip
description INBOUND G729 Voice SIP calls from VzB
shutdown
destination-pattern .T
incoming called-number .
dtmf-relay rtp-nte
no vad
dial-peer voice 102 voip
incoming called-number [2-9].........$
dtmf-relay rtp-nte
no vad
dial-peer voice 200 voip
description To/From CCM02
preference 1
destination-pattern 804.......$
session target ipv4:XXX.XX.232.12
dtmf-relay rtp-nte
fax rate disable
no vad
dial-peer voice 201 voip
description To/From CCM03
preference 2
session target ipv4:XXX.XX.232.20
dtmf-relay rtp-nte
fax rate disable
no vad
dial-peer voice 202 voip
description To/From CCM01
preference 3
shutdown
session target ipv4:XXX.XX.232.4
dtmf-relay rtp-nte
no vad
dial-peer voice 210 voip
preference 1
shutdown
destination-pattern 8043258715$
dtmf-relay rtp-nte
codec g711ulaw
no vad
dial-peer voice 9911 voip
destination-pattern 9911
voice-class sip asserted-id pai
dtmf-relay rtp-nte
no vad
dial-peer voice 911 voip
destination-pattern 911
no voice-class sip early-offer forced
dtmf-relay rtp-nte
no vad
sip-ua
set pstn-cause 1 sip-status 503
set pstn-cause 102 sip-status 503
retry invite 2
retry bye 2
retry cancel 2
timers trying 1000
sip-server ipv4:XXX.XX.62.49:5389
g729-annexb override
Hello Shawnangelo,
did you get and answer to your issue?
Im having the same problem.
7238
