Attention: The Community will be in read-only mode on 12/14/2017 from 12:00 am pacific to 11:30 am.
During this time you will only be able to see content. Other interactions such as posting, replying to questions, or marking content as helpful will be disabled for few hours.
We apologize for the inconvenience while we perform important updates to the Community.
SIP over WAN
I have a simple WAN configuration in my lab for a SIP test.
SIP7031 and proxy swWAN -> r1WAN (PPP) -> r2WAN -> R2FA -> LAN -> SIP6011 and proxy on this side too.
When I make a call from 7011 to 6011 it fails. I have a VOIP dial peer configured, and my CCAPI log shows no matching node.
What is my configuration missing? Should I have a special IOS to make this happen? If so, what do you recommend. Right now, I have the enterprise version that supports SIP and H323, and other general router features.
Steve
1 REPLY
Silver
Re: SIP over WAN
The Cisco SIP implementation enables supported Cisco platforms to signal the setup of voice and multimedia calls over IP networks.
Like other VoIP protocols, SIP is designed to address the functions of signaling and session management within a packet telephony network. Signaling allows call information to be carried across network boundaries. Session management provides the ability to control the attributes of an end-to-end call.
Try the document below
http://www.cisco.com/en/US/products/sw/iosswrel/ps5207/products_configuration_guide_chapter09186a008075196f.html#wp1125276 do a debug ccsip messages
http://www.cisco.com/en/US/tech/tk652/tk701/technologies_configuration_example09186a0080672b8b.shtml
344
