SIP phone 7940 - INVITE problem
Hi all,
i have a problem with SIP IP 7940. I have a asterisk 11.8.1. When i try sip show peers, soft phone have a response 9ms, cisco 7940 210ms. I was try network change (connect only cisco switch asterisk) - same problem.
I thing problem is in configuration of cisco.
This is all my config.
SIPXXXXXXX.cnf
line1_name: "10"
line1_shortname: "10 - Roman"
line1_displayname: "BOS"
line1_authname: "10"
line1_password: "pass"
line2_name: "20"
line2_shortname: "20 - Roman UO"
line2_displayname: "Universe Order"
line2_authname: "20"
line2_password: "pass"
phone_label: "Roman"
SEPXXXXXXX.cnf.xml
<device>
<deviceProtocol>SIP</deviceProtocol>
<devicePool>
<dateTimeSetting>
<dateTemplate>D/M/Y</dateTemplate> ; by adding a after the Y shows time in 12 hour mode i.e. D/M/Ya
</dateTimeSetting>
<callManagerGroup>
<members>
<member priority="0">
<callManager>
<ports>
<ethernetPhonePort>2000</ethernetPhonePort>
<sipPort>5060</sipPort>
<securedSipPort>5061</securedSipPort>
</ports>
<processNodeName>192.168.10.5</processNodeName>
</callManager>
</member>
</members>
</callManagerGroup>
</devicePool>
</device>
SIPDefault.cnf
#image_version: "P0S3-08-9-00"
proxy1_address: "192.168.10.5"
proxy2_address: "192.168.10.5"
# Proxy Server Port
##proxy1_port:"5060"
##proxy2_port:"5060"
# proxy3_port:"5060"
# proxy4_port:"5060"
##proxy_emergency: "192.168.10.5"
##proxy_emergency_port: "5060"
##proxy_backup: "192.168.10.5"
##proxy_backup_port: "5060"
##outbound_proxy: "192.168.10.5"
##outbound_proxy_port: "5060"
telnet_level: "2"
phone_prompt: "Cisco7940"
phone_password: "password"
#enable_vad: "0"
network_media_type: "auto"
user_info: phone
nat_enable: "0"
##nat_enable: "1"
##nat_address: ""
##voip_control_port: "5060"
start_media_port: "16348"
end_media_port:  "20134"
nat_received_processing: "0"
##dyn_dns_addr_1: ""
##dyn_dns_addr_2: ""
#dyn_tftp_addr: "192.168.10.107"
tftp_cfg_dir: "./"
##proxy_register: "1"
##timer_register_expires: "120"
##preferred_codec: "none"
##tos_media: "5"
##enable_vad: "0"
##dial_template: "dialplan"
autocomplete: "1"
##cnf_join_enable: "1"
##semi_attended_transfer: "0"
##call_waiting: "1"
##anonymous_call_block: "0"
##callerid_blocking: "0"
##dnd_control: "0"
##dtmf_inband: "1"
##dtmf_outofband: "avt"
##dtmf_db_level: "3"
##dtmf_avt_payload: "101"
##timer_t1: "500"
##timer_t2: "4000"
##sip_retx: "10"
##sip_invite_retx: "6"
timer_invite_expires: "180"
sntp_mode: "unicast"
sntp_server: "195.250.155.25"
time_zone: "EET"
time_format_24hr: "1"
date_format: "D/M/Y"
##dst_offset: "0"
#dst_start_month: "April"
##dst_start_day: ""
dst_start_day_of_week: "Mon"
##dst_start_week_of_month: "1"
#dst_start_time: "2"
dst_stop_month: "Dec"
#dst_stop_day: "1"
dst_stop_day_of_week: "Sunday"
#dst_stop_week_of_month: ""
#dst_stop_time: "2"
#dst_auto_adjust: "1"
##messages_uri: "*99"
#services_url: "http://example.domain.ext/services/menu.xml"
#directory_url: "http://example.domain.ext/services/directory.php"
logo_url: "http://192.168.10.5/logo_cisco.bmp"
#http_proxy_addr: ""
#http_proxy_port: 80
#remote_party_id: 0
XMLDefault.cnf.xml
<Default>
<callManagerGroup>
    <members>
          <callManager>
             <ports>
                <mgcpPorts>
                   <listen>2427</listen>
                   <keepAlive>2428</keepAlive>
                </mgcpPorts>
             </ports>
             <processNodeName></processNodeName>
          </callManager>
       </member>
    </members>
 </callManagerGroup>
<loadInformation8 model="IP Phone 7940">P0S3-08-9-00</loadInformation8>
<authenticationURL></authenticationURL>
<directoryURL></directoryURL>
<idleURL></idleURL>
<informationURL></informationURL>
<messagesURL></messagesURL>
<servicesURL></servicesURL>
</Default>
Could someone help me with this problem?
Thanks.
Everyone's tags (1)
52
