SIP Phone (8851) with PLAR and Extension Mobility... Possible?
Joe M
Would like to configure a SIP Phone with a PLAR on Button 1 and the Extension Mobility service on Button 2.  SIP Dial Rule for Button 1 to handle the PLAR works as expected when logged out.  However, once a Device Profile logs in, the SIP Dial Rule still takes over Button 1 and the user's extension doesn't get Dial Tone and can't make calls.
I'm not too familiar with SIP Dial Rules...   Can someone help me understand what's happening when I take the Device Profile's line off-hook and just hear dead air until the inter-digit timeout kicks in? Is there something I'm missing with regards to the Dial Parameters which would allow a non-PLAR extension on Button 1 to get dial tone and bypass the SIP Dial Rule configured on the device?
Thanks in advance,
Joe
Jitender Bhandari
Hi Joe,
Not possible see the below enhancement which was opened and then closed.
https://bst.cloudapps.cisco.com/bugsearch/bug/CSCul74064/?reffering_site=dumpcr
No SIP dial rules field on Extension Mobility Device Profile
CSCul74064
Description
Symptom:
Sip Dial rules can be applied to physical devices only. You cannot achieve the same using Extension Mobility Device Profile - as it does not have SIP Dial Rules field - it will take Sip dial rules from physical phone.
It affects for example PLAR function - as for SIP devices it is using SIP Dial Rules
Conditions:
Workaround:
no workaround
Further Problem Description:
(Rate if it helps)
JB
