03-26-2014 08:33 PM - edited 03-16-2019 10:16 PM
We currently are running CUCM 8.6 and have 1800+ SCCP phones in place. There was a new product purchased for AV that will require us to connect (2) IP7000 SIP phones to our Call Manager. I am not sure how configurtion of these phones would differ from configuring a new SCCP phone. Any help is appreciated
Solved! Go to Solution.
03-26-2014 09:13 PM
Here is a previous forum discussion on this topic,
https://supportforums.cisco.com/discussion/10762706/polycom-ip-7000-call-manager-7
03-26-2014 09:13 PM
03-26-2014 11:50 PM
Hi jameskuder,
I suggest you follow the discussion provided by Erick, and if you still have issues, we could check further what might be happening.
03-27-2014 08:01 AM
Thank you for info. I went to start and am actually stuck at Step 1. It says to add a new End User. I do not even have an option to add one. We use AD, but I do not want to use an AD account this conference room phone.
03-27-2014 08:56 AM
In 9.x and above you can have AD (LDAP) users and local users. In your 8.x version you'll need to add an user in LDAP/AD to do this unfortunately. Or maybe you can tie it to an existing end-user (AD) without a phone, etc to get it to work. Problem is if someone deletes that user then the phone may stop working. You'll also need a different end user for each 3rd party SIP device as if you use the same SIP digest user on multiple SIP phones that doesn't work.
03-27-2014 09:40 AM
In Call Manager, it keeps showing that the phone is rejected. What could be causing that?
