08-20-2013 09:14 AM - edited 03-16-2019 06:57 PM
Hi all,
We have recently started to deploy SIP phones to some of our project sites and offices. In one particular case, which is now doing my head in, I cannot seem to get the audio to work at all. The phone rings and makes an initial connection, but after that, fail - no audio on either end.
The SIP trunk is actually provided over the internet by a 3rd party provider (Gamma), so all the phones need is a local drop off to the internet. I have configured my VLAN on the core router to do this. Each port on the trunked Cisco switch has the voice vlan configured to look at the new voice VLAN I created on the router.
Long story short, the VLAN and connectivity is fine and works - the SIP phones were able to connect to Gamma's servers and pull down their updates and configuration.
Next step was to reconfigure the ACL and stateful packet inspection to allow SIP and RTSP to the desired destination servers (in this case, Gamma's SIP servers and networks). This was completed on a handful of other routers, and works ok on those. There was also some specific ports I had to open on UDP which has also been done.
Then we have to turn off Cisco SIP ALG, by using the command "no ip nat service sip tcp port 5060" - otherwise the router will try and do some funky stuff with the voice packets.
All done. Great, I thought.
But we get this problem where the SIP phone rings when dialled from an external source (which in this case is everything, since these are 3rd-party hosted SIP phones), but neither end can hear one another.
It tells me that once the intial connection is established over the data network, the voice packets are getting destroyed by something. In order to troubleshoot this, I turned off the stateful packet inspection AND access-lists. Still getting the same issue.
The router in question is a Cisco 1801 running IOS 12.4(24(T8). Connectivity is provided by a BT ADSL connected directly into this router.
Any help much appreciated.
08-20-2013 10:43 AM
If you disable SIP ALG, you can be 100% sure that voice will not go through.
You can update IOS, and re-enable it.
08-21-2013 02:40 AM
Why is that?
Our SIP provider specifically states that we need to turn this off.
Could you provide an explanation for this? I've read that it interferes with most VOIP standards, also we have this working on 3 of our project sites already with SIP ALG turned off.
I R Confused.
08-21-2013 02:46 AM
No SIP ALG = no adjustment of IP address in payload, no dynamicport opening, no NAT translation creation for RTP flows = nothing works.
Is not like Cisco left it as default just for fun.
08-21-2013 02:47 AM
So why do the other site SIP phones work?
And why are our providers saying the complete opposite to you? We even have to disable SIP ALG on our BT 2Wire routers where we have SIP phones.
I need to go on a VOIP course I think.
08-21-2013 02:51 AM
I don't know about other brand routers but I I know about my customers sites that use Cisco routers.
They all work perfectly with recent IOS, and things left at default. That includes SIP phones, SIP PBX and whatever else.
08-21-2013 02:54 AM
We're a Cisco house, so will try turning it on. Let you know how we do.
Our BT routers are on some smaller sites that only have ADSL and no MPLS link etc etc.
08-21-2013 06:00 AM
We resolved the issues.
They were twofold.
Firstly, the user on site had not connected the SIP phone to the correct port (on the phone!) - it was in the AUX port, which meant it got data and rang, but voice woudlnt work.
Secondly, our SIP provider decided to switchover to their new servers this morning and didnt feel like telling us! This meant that our existing ACL's were incorrect, so we updated those and all working!
I would add that SIP ALG is still DISABLED on all our Cisco routers, so I dont know where you're getting your info from. Maybe it is just our provider in particular that uses non-standard SIP ALG protocols.
Appreciate the efforts anyway.
Cheers.
08-21-2013 06:05 AM
I don't "get info", I have first hand experience.
Just for curiosity, you can try restoring the thing to default, and let us know if it works or not.
08-21-2013 06:55 AM
Thats fair enough
I will try it as soon as I have a development environment to do it in. These are all live sites I'm playing with, and since they are now working I can't really risk breaking them again.
thanks
08-21-2013 08:47 AM
Greg Dent wrote:
Thats fair enough
As they work now with SIP ALG disabled, in case of problems when re-enabling it for a test, you would then just revert config.
08-21-2013 04:17 PM
My VoIP provider insists I DISABLE ALG on my 880. And it works, however, your command is missing. Have you entered "no ip nat service sip udp port 5060"?
08-21-2013 05:14 PM
Leo Laohoo wrote:
Then we have to turn off Cisco SIP ALG, by using the command "no ip nat service sip tcp port 5060" - otherwise the router will try and do some funky stuff with the voice packets.My VoIP provider insists I DISABLE ALG on my 880. And it works, however, your command is missing. Have you entered "no ip nat service sip udp port 5060"?
Good observation, but it could be that the OP ITSP uses TCP, in that case the command he mentioned would be correct.
08-21-2013 05:29 PM
Sorry, Paolo. Didn't mean to say you were wrong.
True. But I thought that if one was to disable ALG you need BOTH commands.
