04-11-2008 03:04 PM - edited 03-15-2019 10:01 AM
Does any of you know how to configure a linksys's SIP phone in CME 4.X
04-11-2008 03:57 PM
On the cme, Configure voice register global, dn and pool. Under pool, mac address doesn't matter, configure username same as number, codec g711u.
On the phone via web, configure proxy and registrar with the cme address, username and password.
These are the minimum steps.
04-14-2008 03:52 AM
Hi, I used this guide over at uc500.com:
http://uc500.com/files/CME-SIP-Config-Guidev3%20Oct%202007.pdf
Thanks to the Author Tony Huynh.
It helped me out. You dont need phone loads if you are using a Linkys SIP phone.
04-14-2008 06:32 AM
Thanks Craig,
very useful information
05-20-2008 02:04 PM
hi Craig,
I checked the guide you recommended but I could not register linksys's SIP phone.
some commands were not valid, I have CME 4.0
e.g. name, label
do you have an example of how did you configure one of your linksys phone.
regards
05-20-2008 02:08 PM
First, configure mode cme under voice register global. There are many posts here regarding that, use the search function.
