05-30-2007 09:44 PM - edited 03-14-2019 09:48 PM
I'm using CCME 4.1 and now I had purchased a linksys SIP IP Phone (model SPA921) and want to add this to my CCME. So what configuration should I have to do?
anyone has configured this and using it?
Solved! Go to Solution.
06-28-2007 08:29 AM
Can you post your config to this thread..
06-28-2007 08:47 AM
Do you have 12.4(11)XJ3 and if not, can you upgrade to that ?
I see no reason for the "media not acceptable" message as the codecs specified are right. Perhaps, in the linksys config, try to exclude all the codecs but g.711u.
06-28-2007 10:43 AM
Here is the parts that you need to get the phone to register.
voice service voip
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
redirect ip2ip
h323
call start slow
modem passthrough nse codec g711ulaw
sip
registrar server expires max 240 min 60
voice class codec 1
codec preference 1 g711ulaw
codec preference 2 g729r8
codec preference 3 g729br8
voice class codec 2
voice class codec 3
voice class h323 1
h225 timeout tcp establish 3
voice register global
mode cme
source-address 10.72.13.19 port 5060
max-dn 200
max-pool 20
timezone 13
tftp-path slot0:
create profile sync 0390651099874129
ntp-server 10.71.13.19 mode directedbroadcast
voice register dn 1
number 4020
allow watch
name User1
label User1
voice register dn 2
number 4021
allow watch
name User2
label User2
voice register dn 3
number 4022
allow watch
name LinkSys
label LinkSys
voice register dn 4
number 4050
allow watch
name CIN-Tandberg
label CIN-Tandberg
voice register template 1
session-transport udp
softkeys hold Resume Newcall
softkeys idle Newcall Redial Cfwdall
softkeys connected Endcall Trnsfer Confrn Hold
voicemail 4200 timeout 30
voice register dialplan 1
type 7940-7960-others
pattern 1 4...
pattern 2 ....
pattern 3 .
voice register pool 1
id mac 0004.F213.2465
type P600
number 1 dn 2
template 1
dialplan 1
dtmf-relay rtp-nte
voice-class codec 1
description SoundPoint501
voice register pool 2
id mac 0004.F210.C66B
type P600
template 1
dialplan 1
dtmf-relay rtp-nte
voice-class codec 1
description SoundPoint301
voice register pool 3
id mac 000E.08DE.1C9B
number 1 dn 3
template 1
dialplan 1
dtmf-relay rtp-nte
voice-class codec 1
description LinkSys-SPA942
voice register pool 4
id mac 0050.6001.1419
number 1 dn 4
template 1
dialplan 1
dtmf-relay rtp-nte
voice-class codec 1
description CIN-Tandberg
!sip-ua
retry options 0
mwi-server ipv4:10.72.13.20 expires 3600 port 5060 transport udp
registrar ipv4:10.72.13.20 expires 3600 secondary
sip-server ipv4:10.72.13.20
presence enable
refer-ood enable 50
06-29-2007 10:33 PM
Thanks, it worked after I configured the voice class codec...
Thanks to all for your support.
Have a great day..
06-30-2007 03:27 AM
Good catch by derek, I've rated his post!
I was comparing the trace with another SIP phone that works ok w/o the need of configuring voice class, and could not see an obvious difference.
