SIP phone with CCME
I'm using CCME 4.1 and now I had purchased a linksys SIP IP Phone (model SPA921) and want to add this to my CCME. So what configuration should I have to do?
anyone has configured this and using it?
2 ACCEPTED SOLUTIONS
Hall of Fame Super Gold
Re: SIP phone with CCME
Please configure
voice register pool 10
number 1 dn 1
no application sip.app
Also you may need to make the username same as then number you want to register.
Here is the parts that you need to get the phone to register.
voice service voip
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
redirect ip2ip
h323
call start slow
modem passthrough nse codec g711ulaw
sip
registrar server expires max 240 min 60
voice class codec 1
codec preference 1 g711ulaw
codec preference 2 g729r8
codec preference 3 g729br8
voice class codec 2
voice class codec 3
voice class h323 1
h225 timeout tcp establish 3
voice register global
mode cme
source-address 10.72.13.19 port 5060
max-dn 200
max-pool 20
timezone 13
tftp-path slot0:
create profile sync 0390651099874129
ntp-server 10.71.13.19 mode directedbroadcast
voice register dn 1
number 4020
allow watch
name User1
label User1
voice register dn 2
number 4021
allow watch
name User2
label User2
voice register dn 3
number 4022
allow watch
name LinkSys
label LinkSys
voice register dn 4
number 4050
allow watch
name CIN-Tandberg
label CIN-Tandberg
voice register template 1
session-transport udp
softkeys hold Resume Newcall
softkeys idle Newcall Redial Cfwdall
softkeys connected Endcall Trnsfer Confrn Hold
voicemail 4200 timeout 30
voice register dialplan 1
type 7940-7960-others
pattern 1 4...
pattern 2 ....
pattern 3 .
id mac 0004.F213.2465
type P600
number 1 dn 2
template 1
dialplan 1
dtmf-relay rtp-nte
voice-class codec 1
description SoundPoint501
voice register pool 2
id mac 0004.F210.C66B
type P600
template 1
dialplan 1
dtmf-relay rtp-nte
voice-class codec 1
description SoundPoint301
voice register pool 3
id mac 000E.08DE.1C9B
number 1 dn 3
template 1
dialplan 1
dtmf-relay rtp-nte
voice-class codec 1
description LinkSys-SPA942
voice register pool 4
id mac 0050.6001.1419
number 1 dn 4
template 1
dialplan 1
dtmf-relay rtp-nte
voice-class codec 1
description CIN-Tandberg
!sip-ua
retry options 0
mwi-server ipv4:10.72.13.20 expires 3600 port 5060 transport udp
registrar ipv4:10.72.13.20 expires 3600 secondary
sip-server ipv4:10.72.13.20
presence enable
refer-ood enable 50
voice register pool xx
mac 0000.0000.0000
username 111 password 1234
In the spa921 configure the same username and password. For simplicity, use extension number as username.
Where should I configure the username in the SPA921, I do not find any option on any of the menus in the phone...
I could not locate the administrator guide for the spa921, but I see in the data sheet that digest authentication is supported, plus we know that other users have been successful in doing this, so you should be able to do that as well!
I've located the guide:
http://store.voxilla.com/files/linksys/SPA900_Series_Admin_Guide.pdf
Registration and authentication settings are made via web access to the phone, "Ext 1/2/3/4/5/6 Tab", see section 5-43.
I have done the settings on the phone as per the instructions in the guide, but still the phone is not getting registered with my CCME.
I think I'm going wrong somewhere in the CCME configuration...
Anybody has any sample configuration of CCME for SIP phones....
It will be great help if anybody can share the same...
1. voice register dn number same as number on the phone
2. voice register pool username and password to match what is configured in the phone, suggest it is the number itself.
3. realm none, or same on both voice register global and phone.
All failing, includ here configuration and output of "term mon" and "debug ccsip message".
Configuration:
voice service voip
sip
registrar server expires max 1200 min 300
mode cme
max-dn 288
max-pool 96
voice register dn 1
number 500
id mac 000E.08DD.8B04
application sip.app
username bitlink password bitlink
Debug output:
Jun 27 11:38:53.555: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
REGISTER sip:192.168.2.11 SIP/2.0
Via: SIP/2.0/UDP 192.168.2.34:5060;branch=z9hG4bK-f5e2cb53
To:
Call-ID: be7ffd50-89dcd76d@192.168.2.34
CSeq: 65293 REGISTER
Max-Forwards: 70
Contact: ;expires=3600
User-Agent: Sipura/SPA921-4.1.10(b)
Content-Length: 0
Allow: ACK, BYE, CANCEL, INFO, INVITE, NOTIFY, OPTIONS, REFER
Jun 27 11:38:53.559: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 100 Trying
To:
Date: Wed, 27 Jun 2007 11:38:53 GMT
Server: Cisco-SIPGateway/IOS-12.x
Content-Length: 0
Sent:
SIP/2.0 404 Not Found
To: ;tag=56904-C4A
Content-Length: 0
Please configure
number 1 dn 1
Hey,
Many thanks now its registered with my CCME..
I changed the username to the phone number then it got registered...
But now I'm able to place a call from my Cisco IP Phone to this SIP IP Phone, however the vice verse is not happening....
What could be the problem...
Attached the debug ccsip output taken during a call being placed from SIP IP Phone to Cisco IP Phone..
Jun 27 12:11:07.627: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
INVITE sip:104@192.168.2.11 SIP/2.0
Via: SIP/2.0/UDP 192.168.2.34:5060;branch=z9hG4bK-4438c165
To: <104>
Call-ID: 4b44a8ba-e7763bf1@192.168.2.34
CSeq: 101 INVITE
Max-Forwards: 70
Contact: <500>
Expires: 240
Content-Length: 393
Content-Type: application/sdp
v=0
o=- 76516 76516 IN IP4 192.168.2.34
s=-
c=IN IP4 192.168.2.34
t=0 0
m=audio 16456 RTP/AVP 0 2 4 8 18 96 97 98 101
a=rtpmap:0 PCMU/8000
a=rtpmap:2 G726-32/8000
a=rtpmap:4 G723/8000
a=rtpmap:8 PCMA/8000
a=rtpmap:18 G729a/8000
a=rtpmap:96 G726-40/8000
a=rtpmap:97 G726-24/8000
a=rtpmap:98 G726-16/8000
a=rtpmap:101 telephone-event/8000
a=fmtp:101 0-15
a=ptime:30
a=sendrecv
Jun 27 12:11:07.631: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 488 Not Acceptable Media
To: <104>;tag=22EC00-9DE
Date: Wed, 27 Jun 2007 12:11:07 GMT
CSeq: 101 INVITE
Allow-Events: telephone-event
Reason: Q.850;cause=65
Content-Length: 0
Jun 27 12:11:07.643: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
ACK sip:104@192.168.2.11 SIP/2.0
CSeq: 101 ACK
Max-Forwards: 70
Contact: <500>
Content-Length: 0
which IP Phone and firmware are you using?
It could be the IP phone that is refusing the call for some related to the codec.
Looks like you have a codec mis-match. Try a voice-class that includes at least G711, G729r8, and G729br8. You should also check your "voice register dialplan"
I have do the same config
In my case
CCME and Linksys are not in the same LAN
And IP adreses are not real (NAT)
Following debug messages
Sent:
SIP/2.0 400 Bad Request - 'Invalid IP Address'
Via: SIP/2.0/UDP 88.230.21.105:5060;branch=z9hG4bK-adf53327
To: 712 <712>;tag=234B8A4-FAF
Date: Wed, 18 Jul 2007 01:46:40 GMT
Call-ID: 853faa26-35b21eb2@88.230.21.105
CSeq: 21737 REGISTER
Content-Length: 0
THANKS
the error is because source and destination of the request are the same. Please include a diagram of all devices involved, how they are connected, addresses and configuration.
Just posted my config to another thread, but it works, however still haven't gotten MWI to work, and when I hit the messages button, it's treating the call like CFNA/CFB to CUE. If I dial my voice mail extension directly it works fine.
Also I'm running 2.0.3 on my SP501 phone, and CME 4.1.0.1 (IOS 12.4(11)XJ3 on a 3725).
Can you post your config to this thread..
Do you have 12.4(11)XJ3 and if not, can you upgrade to that ?
I see no reason for the "media not acceptable" message as the codecs specified are right. Perhaps, in the linksys config, try to exclude all the codecs but g.711u.
voice service voip
redirect ip2ip
h323
call start slow
sip
voice class codec 1
voice class codec 2
voice class codec 3
voice class h323 1
mode cme
max-dn 200
max-pool 20
timezone 13
tftp-path slot0:
voice register dn 1
number 4020
allow watch
name User1
label User1
voice register dn 2
number 4021
allow watch
name User2
label User2
voice register dn 3
number 4022
allow watch
name LinkSys
label LinkSys
voice register dn 4
number 4050
allow watch
name CIN-Tandberg
label CIN-Tandberg
pattern 1 4...
pattern 2 ....
pattern 3 .
type P600
number 1 dn 2
template 1
dialplan 1
dtmf-relay rtp-nte
voice-class codec 1
type P600
template 1
dialplan 1
dtmf-relay rtp-nte
voice-class codec 1
number 1 dn 3
template 1
dialplan 1
dtmf-relay rtp-nte
voice-class codec 1
number 1 dn 4
template 1
dialplan 1
dtmf-relay rtp-nte
voice-class codec 1
!sip-ua
retry options 0
presence enable
refer-ood enable 50
Thanks, it worked after I configured the voice class codec...
Thanks to all for your support.
Have a great day..
Good catch by derek, I've rated his post!
I was comparing the trace with another SIP phone that works ok w/o the need of configuring voice class, and could not see an obvious difference.
777
