Community Member
Sip phone with UC560 / CME
I have registered a Polycom IP Soundstation 5000 SIP phone with a UC560 (CME) system.
Internal calls work in both directions.
External calls work inbound but not outbound.
I ran "debug voip ccapi inout" and found that the dialed number has "ABCD" put in front of it:
043265: //-1/FBFA050185DC/CCAPI/cc_api_display_ie_subfields:
   cc_api_call_setup_ind_common:
   cisco-username=6044
   ----- ccCallInfo IE subfields -----
   cisco-ani=6044
   cisco-anitype=0
   cisco-aniplan=0
   cisco-anipi=0
   cisco-anisi=0
   dest=ABCD907584449552
   cisco-desttype=0
   cisco-destplan=0
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-rdntype=0
   cisco-rdnplan=0
   cisco-rdnpi=-1
   cisco-rdnsi=-1
   cisco-redirectreason=-1   fwd_final_type =0
   final_redirectNumber =
   hunt_group_timeout =0
043266: //-1/FBFA050185DC/CCAPI/cc_api_call_setup_ind_common:
   Interface=0x875A0A64, Call Info(
   Calling Number=6044,(Calling Name=)(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
   Called Number=ABCD907584449552(TON=Unknown, NPI=Unknown),
   Calling Translated=FALSE, Subscriber Type Str=Unknown, FinalDestinationFlag=TRUE,
   Incoming Dial-peer=40001, Progress Indication=NULL(0), Calling IE Present=TRUE,
   Source Trkgrp Route Label=, Target Trkgrp Route Label=, CLID Transparent=FALSE), Call Id=78945
043267: //-1/FBFA050185DC/CCAPI/ccCheckClipClir:
   In: Calling Number=6044(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
043268: //-1/FBFA050185DC/CCAPI/ccCheckClipClir:
   Out: Calling Number=6044(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
043269: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
043270: :cc_get_feature_vsa malloc success
043271: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
043272:  cc_get_feature_vsa count is 31
043273: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
043274: :FEATURE_VSA attributes are: feature_name:0,feature_time:2386993696,feature_id:18675
043275: //78945/FBFA050185DC/CCAPI/cc_api_call_setup_ind_common:
   Set Up Event Sent;
   Call Info(Calling Number=6044(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
   Called Number=ABCD907584449552(TON=Unknown, NPI=Unknown))
043276: //-1/xxxxxxxxxxxx/CCAPI/cc_build_feature_vsa:
043277: :Inside cc_build_feature_vsa
043278: //-1/xxxxxxxxxxxx/CCAPI/cc_build_feature_vsa:
043279:  feature call basic
043280: //-1/xxxxxxxxxxxx/CCAPI/cc_build_feature_vsa:
043281: cc_build_feature_vsa attr is fn:TWC,ft:10/06/2014 10:21:27.555,cgn:6044,cdn:ABCD907584449552,frs:0,fid:18675,fcid:FBFA05014C7011E485DCF6602ADD1E8F,legID:13461
043282: //78945/FBFA050185DC/CCAPI/cc_process_call_setup_ind:
   Event=0x885AFB08
043283: //-1/xxxxxxxxxxxx/CCAPI/cc_setupind_match_search:
   Try with the demoted called number ABCD907584449552
043284: //78945/FBFA050185DC/CCAPI/ccCallSetContext:
   Context=0x8C58C908
043285: //78945/FBFA050185DC/CCAPI/cc_process_call_setup_ind:
   >>>>CCAPI handed cid 78945 with tag 40001 to app "_ManagedAppProcess_Default"
043286: Oct  6 10:21:27.563: %AAA-3-BADSERVERTYPEERROR: Cannot process accounting server type radius (UNKNOWN)
043287: //78945/FBFA050185DC/CCAPI/ccCallProceeding:
043288: //-1/xxxxxxxxxxxx/CCAPI/cc_setupind_match_search:
043289: //-1/xxxxxxxxxxxx/CCAPI/cc_update_feature_vsa:
043290: : updating existing feature vsa
043291: //-1/xxxxxxxxxxxx/CCAPI/cc_update_feature_vsa:
043292:  feature call basic
043293: //78945/FBFA050185DC/CCAPI/ccCallDisconnect:
   Cause Value=17, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=0)
043294: //78945/FBFA050185DC/CCAPI/ccCallDisconnect:
   Cause Value=17, Call Entry(Responsed=TRUE, Cause Value=17)
043295: Oct  6 10:21:27.587: %VOIPAAA-5-VOIP_CALL_HISTORY: CallLegType 2, ConnectionId FBFA05014C7011E485DCF6602ADD1E8F, SetupTime 10:21:27.557 BST Mon Oct 6 2014, PeerAddress 6044, PeerSubAddress , DisconnectCause 11  , DisconnectText user busy (17), ConnectTime 10:21:27.587 BST Mon Oct 6 2014, DisconnectTime 10:21:27.587 BST Mon Oct 6 2014, CallOrigin 2, ChargedUnits 0, InfoType 2, TransmitPackets 0, TransmitBytes 0, ReceivePackets 0, ReceiveBytes 0
043296: //-1/xxxxxxxxxxxx/CCAPI/cc_build_feature_vsa:
043297: :Inside cc_build_feature_vsa
043298: //-1/xxxxxxxxxxxx/CCAPI/cc_build_feature_vsa:
043299:  feature call basic
043300: //-1/xxxxxxxxxxxx/CCAPI/cc_build_feature_vsa:
043301: cc_build_feature_vsa attr is fn:TWC,ft:10/06/2014 10:21:27.555,cgn:6044,cdn:ABCD907584449552,frs:1,fid:18675,fcid:FBFA05014C7011E485DCF6602ADD1E8F,legID:13461
043302: Oct  6 10:21:27.587: %VOIPAAA-5-VOIP_FEAT_HISTORY: FEAT_VSA=fn:TWC,ft:10/06/2014 10:21:27.555,cgn:6044,cdn:ABCD907584449552,frs:1,fid:18675,fcid:FBFA05014C7011E485DCF6602ADD1E8F,legID:13461,bguid:FBFA05014C7011E485DCF6602ADD1E8F
043303: //78945/FBFA050185DC/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x875A0A64, Tag=0x0, Call Id=78945,
   Call Entry(Disconnect Cause=17, Voice Class Cause Code=0, Retry Count=0)
043304: //78945/FBFA050185DC/CCAPI/cc_api_call_disconnect_done:
   Call Disconnect Event Sent
043305: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
043306: :cc_free_feature_vsa freeing 8E46A218
043307: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
043308:  vsacount in free is 30
I can see the following translation rules which I believe are responsible. They are built in as part of CUE but I'm not sure what they are for:
voice translation-rule 411
 rule 1 /^9\(.*\)/ /ABCD9\1/
voice translation-rule 412
 rule 1 /^ABCD\(.*\)/ /\1/
voice translation-rule 422
 rule 1 /^ABCD909[01]......../ //
 rule 2 /^ABCD9090[89]......./ //
 rule 3 /^ABCD9098\(.*\)/ //
 rule 15 /^ABCD\(.*\)/ /\1/
 voice translation-profile SIP_Incoming
 translate called 411
voice translation-profile SIP_Passthrough
 translate called 412
voice translation-profile SIP_Passthrough_CallBlocking
 translate called 422
How can I avoid outbound calls from the SIP phone from hitting these rules or is there something else going on which I'm not aware of?
Everyone's tags (3)
1 ACCEPTED SOLUTION
I would remove below
voice source-group CCA_SIP_SOURCE_GROUP_CUE_CME
 access-list 2
 translation-profile incoming SIP_Incoming
and test .
Community Member
Kindly send us the running
Kindly send us the running configuration of the CME so that we can see where the translation profiles are applied and from where it is getting invoked.
Community Member
Config attached. i have
Config attached. i have removed some passwords and IP addresses.
thank you.
 access-list 2
and test .
Community Member
thanks that worked.im a bit
thanks that worked.
im a bit concerned about what this code does though. according to another post:
https://supportforums.cisco.com/discussion/11282411/voice-source-group-ccasipsourcegroupcuecme
"This is a bit of a hack.
There's an incoming dial-peer on the router which matches all incoming calls (unless a specific DID has been configured) and rejects the call. The dial-peer has "permission term" configured. This is part of the toll fraud / anti loop mechanism which configured the router to only accept incoming calls placed to numbers which are configured on the system.
Remembering that the Unity module is a separate SIP UA, calls from CUE destined to PSTN would fail because of this, so what they've done is prefix incoming calls from networks described by access-list 2 (i.e. the CUE module) with ABCD. We then have an incoming dial-peer which matches calls starting ABCD, this is removed and the call is successful."
Why would unity need to call the PSTN?
Voicemail seems to be working.
i think if you use CCA , it
i think if you use CCA , it configures those xlation rules for some reason
308
