SIP phones cannot use TCL scripts (e.g. Paolo's Wakeup service)
J. S. Black
I have Paolo Bevilacqua's wake-up service programmed as a script in my CME 4.1. All SCCP phones can reach the wake up service and use it, but SIP endpoints just give me a fast busy. Is there a special command that needs to be added to my configuration for TCL scripts to work with SIP phones?
Thanks.
paolo bevilacqua
this due to a check in IOS that produces (erroneously in my opinion):
%CALL_CONTROL-6-CALL_LOOP: The incoming call has a global identfier already present in the list of currently handled calls. It is being refused.
The misspelling is not mine either :)
The workaround is to configure "session protocol cisco" under the DP, and "allow-connections sip to h323" under "voice service". Note, I use an _ivs image for this, not sure if it would work without.
paolo bevilacqua
Hi Paolo,
Yes, I forgot to include that error message - that is exactly what I was getting.
I'll try that when I have a minute. As always, you are an asset to this community :)
Thank you for the appreciation.
I found amazing that someone can bear with my funny pronunciation and mix of voices, sound volumes and time formats in that service :)
