SIP Profile not altering From in ccapi
I have applied a SIP Profile in the CUBE to modify the From Field to change Restricted to a physical number.  Callmanager is still seeing the call coming into it as Restricted and blocking the call.
Need help determining why the SIP Profile is not changing the From Header into Callmanager.
074046: Oct  4 09:48:52.324 CDT: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
INVITE sip:9523453341@65.113.136.170:5060 SIP/2.0
Via: SIP/2.0/UDP 67.14.121.152:5060;branch=z9hG4bK0bB0ce407d94d8f5ccc
From: "Unavailable" <sip:Restricted@67.14.121.152:5060;isup-oli=0>;tag=gK0b68c3da
To: <sip:9523453341@65.113.136.170:5060>
Call-ID: 571149464_29286831@67.14.121.152
CSeq: 29266 INVITE
Max-Forwards: 69
Allow: INVITE,ACK,CANCEL,BYE,INFO,NOTIFY,PRACK,UPDATE,OPTIONS
Accept: application/sdp, application/isup, application/dtmf, application/dtmf-relay,  multipart/mixed
Contact: "Unavailable" <sip:Restricted@67.14.121.152:5060>
P-Asserted-Identity: "Unavailable" <sip:Restricted@67.14.121.152:5060>
Supported: 100rel
Content-Length:  305
Content-Disposition: session; handling=required
Content-Type: application/sdp
074047: Oct  4 09:48:52.328 CDT: //-1/EB92EE67BDC3/CCAPI/cc_api_display_ie_subfields:
   cc_api_call_setup_ind_common:
   cisco-username=Restricted
   ----- ccCallInfo IE subfields -----
   cisco-ani=Restricted
   cisco-anitype=0
   cisco-aniplan=0
   cisco-anipi=0
   cisco-anisi=0
   dest=9523453341
   cisco-desttype=0
   cisco-destplan=0
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-rdntype=0
   cisco-rdnplan=0
   cisco-rdnpi=-1
   cisco-rdnsi=-1
   cisco-redirectreason=-1   fwd_final_type =0
   final_redirectNumber =
   hunt_group_timeout =0
Thank you for any assistance.
Becky
Hi Becky,
Can you post your CUBE configuration and a call flow explanation please?
Sergio
SIP from Carrier
CUBE to CM
We ended up creating a SIP profile that altered the From Header.
voice class sip-profiles 100
request INVITE sip-header From modify "Anonymous" "9525551212"
request INVITE sip-header From modify "Unavailable" "9525551212"
request INVITE sip-header From modify "Restricted" "9525551212"
request INVITE sip-header Remote-Party-ID modify "Anonymous" "9525551212"
request INVITE sip-header Remote-Party-ID modify "Unavailable" "9525551212"
request INVITE sip-header Remote-Party-ID modify "Restricted" "9525551212"
request INVITE sip-header P-Asserted-Identity modify "Anonymous" "9525551212"
request INVITE sip-header P-Asserted-Identity modify "Unavailable" "9525551212"
request INVITE sip-header P-Asserted-Identity modify "Restricted" "9525551212"
Hi Becky,
Try the following:
request INVITE sip-header From modify " "<9525551212>
Sergio
VIP Super Bronze
Becky,
I doubt if you need all these!  First of all the "unavailable" is an optional  display parameter and you dont have to worry about it. Second from your tarce, you are only using PAI (P-asserted-identity), hence there is no need to have remote-party-id configured. You can certainly tidy up your config...
Please rate all useful posts
"opportunity is a haughty goddess who waste no time with those who are unprepared"
Please rate all useful posts "The essence of christianity is not the enthronement but the obliteration of self --William Barclay"
358
