SIP profiles when using NAT
Hi all,
We have a CUBE behind a firewall, and unfortunately we cannot run SIP INSPECT on the firewall. I am trying to modify the SIP headers so that we are correctly sending the external IP in the header information to the ITSP and the correct internal address to the CUCM
Relevant Config:
voice class sip-profiles 100
 request ANY sip-header From modify "192.168.46.18" "36.11.22.33"
 request ANY sip-header Via modify "192.168.46.18" "36.11.22.33"
 request ANY sip-header Remote-Party-ID modify "192.168.46.18" "36.11.22.33"
 request ANY sip-header Contact modify "192.168.46.18" "36.11.22.33"
 response ANY sip-header Contact modify "192.168.46.18" "36.11.22.33"
 response ANY sip-header Remote-Party-ID modify "192.168.46.18" "36.11.22.33"
 request ANY sdp-header Audio-Connection-Info modify "192.168.46.18" "36.11.22.33"
 request ANY sdp-header Connection-Info modify "192.168.46.18" "36.11.22.33"
 request ANY sdp-header Session-Owner modify "192.168.46.18" "36.11.22.33"
 response ANY sdp-header Session-Owner modify "192.168.46.18" "36.11.22.33"
 response ANY sdp-header Connection-Info modify "192.168.46.18" "36.11.22.33"
 response ANY sdp-header Audio-Connection-Info modify "192.168.46.18" "36.11.22.33"
voice class sip-profiles 101
 request ANY sip-header From modify "36.11.22.33" "192.168.46.18"
 request ANY sip-header Via modify "36.11.22.33" "192.168.46.18"
 request ANY sip-header Remote-Party-ID modify "36.11.22.33" "192.168.46.18"
 request ANY sip-header Contact modify "36.11.22.33" "192.168.46.18"
 response ANY sip-header Contact modify "36.11.22.33" "192.168.46.18"
 response ANY sip-header Remote-Party-ID modify "36.11.22.33" "192.168.46.18"
 request ANY sdp-header Audio-Connection-Info modify "36.11.22.33" "192.168.46.18"
 request ANY sdp-header Connection-Info modify "36.11.22.33" "192.168.46.18"
 request ANY sdp-header Session-Owner modify "36.11.22.33" "192.168.46.18"
 response ANY sdp-header Session-Owner modify "36.11.22.33" "192.168.46.18"
 response ANY sdp-header Connection-Info modify "36.11.22.33" "192.168.46.18"
 response ANY sdp-header Audio-Connection-Info modify "36.11.22.33" "192.168.46.18"
voice service voip
 sip
 sip-profiles 100
dial-peer voice 3000 voip
 description ***** To CUCM ***
 voice-class sip profiles 101
dial-peer voice 2000 voip
 description ***OUTBOUND PSTN***
voice-class sip profiles 100
IP Info:
192.168.46.18 - CUBE internal address
192.168.46.14 - CUCM Address
36.11.22.33 - CUBE External
88.11.22.33 - ITSP
What I have seen is:
- When I am not using SIP profiles, the invites are being sent to the ITSP using the CUBE internal address and being rejected by the ITSP
019844: Aug 26 14:12:43.841: //10096/000000000000/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 403 Forbidden-Source Endpoint Lookup Failed
Via: SIP/2.0/UDP 192.168.46.18:5060;received=31.221.99.51;branch=z9hG4bK5102CF
Call-ID: E1B88EF8-2C6111E4-ACF4FA6E-8F1CB832@192.168.46.18
CSeq: 101 OPTIONS
To: <sip:88.11.22.33>;tag=3618051230-117031
Content-Length: 0
- When I add a SIP profile to the outgoing dialpeer to the ITSP, the messages are sent correctly, but we get a problem because the SIP messages going to Call Manager show the external address as the contact and the RTP stream goes to the wrong place.
So, what I have now done is, created two SIP profiles. One on the outgoing dial-peer to the ITSP, to modify the internal address to the external address, and one on the outgoing dialpeer to the CUCM to modify the external interface to the internal interface.
For incoming calls, this is fine, I can see the SIP messages coming from 88.11.22.33 to 36.11.22.33 and then the CUBE is sending to the CUCM on 192.168.46.14 with the correct contact address of 192.168.46.14 and audio works.
However, what I can see with outgoing calls, is that initially all the signalling traffic is fine:
068357: Aug 29 10:13:17.468: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
INVITE sip:07714123456@192.168.46.18:5060 SIP/2.0
Via: SIP/2.0/TCP 192.168.46.14:5060;branch=z9hG4bKc2cf5ab70534
From: "TCC Phone7" <sip:+442031234567@192.168.46.14>;tag=73591~5cec2a93-537f-40cd-bf17-e7b4de1fe86e-29863481
To: <sip:07714123456@192.168.46.18>
Date: Fri, 29 Aug 2014 10:14:26 GMT
Call-ID: 3ffab280-40015282-bdf4-e2ea8c0@192.168.46.14
Supported: timer,resource-priority,replaces
Min-SE:  1800
User-Agent: Cisco-CUCM10.5
Allow: INVITE, OPTIONS, INFO, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY
CSeq: 101 INVITE
Expires: 180
Allow-Events: presence, kpml
Supported: X-cisco-srtp-fallback,X-cisco-original-called
Call-Info: <sip:192.168.46.14:5060>;method="NOTIFY;Event=telephone-event;Duration=500"
Call-Info: <urn:x-cisco-remotecc:callinfo>;x-cisco-video-traffic-class=DESKTOP
Cisco-Guid: 1073394304-0000065536-0000000295-0237938880
Session-Expires:  1800
P-Asserted-Identity: "TCC Phone7" <sip:+442031234567@192.168.46.14>
Remote-Party-ID: "TCC Phone7" <sip:+442031234567@192.168.46.14>;party=calling;screen=yes;privacy=off
Contact: <sip:+442031234567@192.168.46.14:5060;transport=tcp>
Max-Forwards: 69
Content-Length: 0
068358: Aug 29 10:13:17.476: //27351/3FFAB2800000/SIP/Msg/ccsipDisplayMsg:
Sent:
INVITE sip:07714123456@88.11.22.33:5060 SIP/2.0
Via: SIP/2.0/UDP 36.11.22.33:5060;branch=z9hG4bK39121292
Remote-Party-ID: "TCC Phone7" <sip:02031234567@36.11.22.33>;party=calling;screen=yes;privacy=off
From: "TCC Phone7" <sip:02031234567@36.11.22.33>;tag=525572C8-1895
To: <sip:07714123456@88.11.22.33>
Date: Fri, 29 Aug 2014 10:13:17 GMT
Call-ID: EDF11C33-2E9B11E4-B5ADFA6E-8F1CB832@192.168.46.18
Supported: 100rel,timer,resource-priority,replaces,sdp-anat
Min-SE:  1800
User-Agent: Cisco-SIPGateway/IOS-15.2.4.M6
Allow: INVITE, OPTIONS, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY, INFO, REGISTER
CSeq: 101 INVITE
Timestamp: 1409307197
Contact: <sip:02031234567@36.11.22.33:5060>
Expires: 180
Allow-Events: telephone-event
Max-Forwards: 68
Content-Type: application/sdp
Content-Disposition: session;handling=required
Content-Length: 259
v=0
o=CiscoSystemsSIP-GW-UserAgent 4541 1686 IN IP4 36.11.22.33
s=SIP Call
c=IN IP4 36.11.22.33
t=0 0
m=audio 19242 RTP/AVP 8 0 101
a=rtpmap:8 PCMA/8000
a=rtpmap:0 PCMU/8000
a=rtpmap:101 telephone-event/8000
a=fmtp:101 0-16
The INVITE is sent from CUCM on .14 to the CUBE at .18, the CUBE is then sending an INVITE to the ITSP with the correct address information, however, when the ITSP sends back the SIP 183 response, the CUBE sends a 183 to the CUCM, but with a Contact of the external address:
068363: Aug 29 10:13:17.904: //27350/3FFAB2800000/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 183 Session Progress
To: <sip:07714123456@192.168.46.18>;tag=52557470-1338
CSeq: 101 INVITE
Contact: <sip:07714123456@36.11.22.33:5060;transport=tcp>
Supported: sdp-anat
Server: Cisco-SIPGateway/IOS-15.2.4.M6
Content-Length: 247
And then when the call connects:
068370: Aug 29 10:13:25.388: //27350/3FFAB2800000/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
CSeq: 101 INVITE
Remote-Party-ID: <sip:07714123456@36.11.22.33>;party=called;screen=no;privacy=off
Supported: replaces
Supported: sdp-anat
Session-Expires:  1800;refresher=uas
Require: timer
Supported: timer
Content-Length: 247
v=0
o=CiscoSystemsSIP-GW-UserAgent 1290 7090 IN IP4 36.11.22.33
s=SIP Call
t=0 0
m=audio 19240 RTP/AVP 8 101
a=fmtp:101 0-15
a=ptime:20
This would suggest to me that the profile is not being used in this case and the RTP stream is then being sent to this external address (the firewall) and being dropped.
Is this something that I am doing wrong, or is there a better way to achieve this?
What you can do rather than
What you can do rather than using sip profiles is to bind source and media address on the inbound and outbound dial-peer.  Here is the link.
Bronze
Hi all, I was also facing the
Hi all,
I was also facing the:
My CUBE is only configured with a single LAN side address and I’m using NAT forwarding from the firewall, so I can’t use the bind media method.
However the above configuration using the ‘voice class sip-profile’ worked for me, but I only needed the config on the peer going towards the ITSP.
Thanks!
Matty
2212
