SIP Provider for Home Lab
I'm looking for a SIP Provider for a home labe. I will have a 2811 which I would like to use as the SIP gateway. Any suggestions.
Re: SIP Provider for Home Lab
Use a PC running a soft client like Xlite or similar and point the calls to the 2800 gateway. If you want to scale the network, run asterix on the PC and have multiple phones - in either case the PC will 'appear' as a SIP provider.
Might try Superphone
Can't give any recommendations about providers - it depends on where you are located and the overall bandwidth of the connection.
If you have a CCM , you don't even need a gateway router - you run a SIP trunk on the CCM direct to the external device/provider.
201
