Hi all,
I'm setting up a Cube for my customer and i'm running into problems with incoming calls. Outgoing calls are working fine, my SIP trunks get registered but when I try to make an incoming call it just won't work.
When I do a debug ccsip message I can see that I receive a sip invite with my SIP username instead of the called number:
*Oct 8 08:24:34.007: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
INVITE sip:90908358PXXX@192.168.X;X:5060 SIP/2.0
Via: SIP/2.0/UDP 188.x.x.x:5060;branch=z9hG4bKrs049t30ageh1gk1e590.1
From: "0562xxxx"<sip:0562xxxx@provider.eu;user=phone>;tag=SDbtgt901-1114689618-1
286526262026-
To: "289455xx 289455xx"<sip:289455xx@provider.eu>
Call-ID: SDbtgt901-12e0301cc75ca3d9eeabdef03430ec24-s5gg440
CSeq: 91778438 INVITE
Contact: <sip:xxxxxx@188.x.x.x:5060;transport=udp>
Allow: ACK,BYE,CANCEL,INFO,INVITE,OPTIONS,PRACK,REFER,NOTIFY,UPDATE
Accept: multipart/mixed,application/media_control+xml,application/sdp
Supported:
Max-Forwards: 9
Content-Type: application/sdp
Content-Length: 550
And in my debug voip dialpeer it's showing allso my username as called number:
*Oct 8 08:17:54.923: //-1/62C7FFCD8054/DPM/dpAssociateIncomingPeerCore:
Calling Number=0562xxxxx, Called Number=90908358PXXX, Voice-Interface=0x0,
Timeout=TRUE, Peer Encap Type=ENCAP_VOIP, Peer Search Type=PEER_TYPE_VOICE,
Peer Info Type=DIALPEER_INFO_SPEECH
Is there a way that I can tell my cube that he doesn't have to look at the Invite sip:Username but to the TO: in my sip message? I have tried several methods for dial-peer destination-pattern, incoming called number etc. i've tried to configure the dial peer with asserted id pai, but none works.
many thanks in advance for your replies,
Best regards,
p-vincent
