SIP provider to Unity gives fast busy
Hi all. I'm trying to configure a SIP trunk from Allstream on a CME, and my last snag is that calls coming in through the SIP trunk hit a fast busy when they're sent to unity. Calls from phone to phone or from outside to an FXO line go to Unity without issue.
Here are the parts of my config I have access to now:
Unity Dial peer:
 destination-pattern 13019
 session protocol sipv2
 session target ipv4:10.1.17.2
 dtmf-relay rtp-nte
 codec g711ulaw
 no vad
Incoming dial-peer:
dial-peer voice 3030 voip
 description ** MTS Allstream Provider SIP **
 translation-profile incoming SIP_Incoming
 session target ipv4:216.13.193.132
 incoming called-number .
 no voice-class sip privacy-policy passthru
 no voice-class sip g729 annexb-all
 voice-class sip bind control source-interface GigabitEthernet0/0
 voice-class sip bind media source-interface GigabitEthernet0/0
 dtmf-relay rtp-nte
 codec g711ulaw
 ip qos dscp cs3 signaling
 no vad
voice service voip
 ip address trusted list
  ipv4 0.0.0.0
 allow-connections sip to sip
 fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback none
 sip
  rel1xx disable
  min-se 600 session-expires 600
  header-passing
  midcall-signaling passthru
  g729 annexb-all
Dialpeer debug:
*Oct 14 17:45:35.953 PDT: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
   Calling Number=, Called Number=13019, Peer Info Type=DIALPEER_INFO_SPEECH
   Match Rule=DP_MATCH_DEST; Called Number=13019
   Result=Success(0) after DP_MATCH_DEST
*Oct 14 17:45:35.953 PDT: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
   dialstring=13019, saf_enabled=0, saf_dndb_lookup=1, dp_result=0
*Oct 14 17:45:35.953 PDT: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
   List of Matched Outgoing Dial-peer(s):
     1: Dial-peer Tag=1
   Calling Number=, Called Number=6044175261, Peer Info Type=DIALPEER_INFO_SPEECH
   Match Rule=DP_MATCH_DEST; Called Number=6044175261
   No Outgoing Dial-peer Is Matched; Result=NO_MATCH(-1)
   dialstring=6044175261, saf_enabled=0, saf_dndb_lookup=1, dp_result=-1
   Result=NO_MATCH(-1)
   Result=SUCCESS(0)
     1: Dial-peer Tag=1
*Oct 14 17:45:35.961 PDT: //-1/6321E1B18C5C/DPM/dpMatchPeersCore:
*Oct 14 17:45:35.961 PDT: //-1/6321E1B18C5C/DPM/dpMatchSafModulePlugin:
*Oct 14 17:45:35.961 PDT: //-1/6321E1B18C5C/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
     1: Dial-peer Tag=1
*Oct 14 17:45:35.961 PDT: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
*Oct 14 17:45:35.961 PDT: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
   dialstring=NULL, saf_enabled=0, saf_dndb_lookup=0, dp_result=0
*Oct 14 17:45:35.961 PDT: //-1/xxxxxxxxxxxx/DPM/dpMatchPeers:
   Result=SUCCESS(0)
     1: Dial-peer Tag=1
*Oct 14 17:45:35.961 PDT: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
   Calling Number=6044175261, Called Number=, Voice-Interface=0x0,
   Timeout=TRUE, Peer Encap Type=ENCAP_VOIP, Peer Search Type=PEER_TYPE_VOICE,
   Peer Info Type=DI
ALPEER_INFO_SPEECH
   Result=NO_MATCH(-1) After All Match Rules Attempt
   dialstring=NULL, saf_enabled=0, saf_dndb_lookup=0, dp_result=-1
   Calling Number=13019, Called Number=13019, Peer Info Type=DIALPEER_INFO_SPEECH
   dialstring=13019, saf_enabled=1, saf_dndb_lookup=1, dp_result=0
   Result=SUCCESS(0)
     1: Dial-peer Tag=1
CCSIP Error
***************Oct 14 17:49:07.489 PDT: //1036/E131008B8C62/SIP/Error/sipSPI_ipip_set_history_info_header:
 Not SIP2SIP mode
*Oct 14 17:49:07.489 PDT: //-1/xxxxxxxxxxxx/SIP/Error/ccsip_set_release_source_for_peer:
 Failed AV set
*Oct 14 17:49:07.489 PDT: //-1/xxxxxxxxxxxx/SIP/Error/sipSPIGetContentQSIG:
 No Inbound Container Created !!!
*Oct 14 17:49:07.489 PDT: //-1/xxxxxxxxxxxx/SIP/Error/sipSPIGetContentQ931:
CCSIP Event:
*Oct 14 18:06:12.877 PDT: //-1/xxxxxxxxxxxx/SIP/Event/sipSPIEventInfo: Queued event from SIP SPI : SIPSPI_EV_CC_CALL_FORWARD
*Oct 14 18:06:12.881 PDT: //1043/44661A9D8C78/SIP/Event/Session-Timer/sipSTSLMain: Event: E_STSL_SESSION_REFRESH_RESP
*Oct 14 18:06:12.881 PDT: //1043/44661A9D8C78/SIP/Event/Session-Timer/sipSTSLMain: dir:1, method:102, resp_code:302, container:3AFFA128
*Oct 14 18:06:12.881 PDT: //-1/xxxxxxxxxxxx/SIP/Event/sipSPIEventInfo: Queued event from SIP SPI : SIPSPI_EV_CC_CALL_DISCONNECT
Thanks. I can provide whatever other info may be helpful.
Can you please try to add what follows
Under voice service voip
no supplementary service sip moved-temporarily
no supplementary service refer
Please Try these two commands and let me know.
If that doesn't help, please capture the complete logs in a text file and attach it. The one you gave above is incomplete.
//Suresh Please rate all the useful posts.
can you capture debug voice ccapi inout & debug ccsip message for a failed call and attach the logs here?
Sure thing. Enabled term mon right before it went to the fast busy:
*Oct 15 17:43:50.223 PDT: //1046/4E8686FF8C7E/CCAPI/cc_api_call_disconnected:
   Cause Value=19, Interface=0x3E41966C, Call Id=1046
   Call Entry(Responsed=TRUE, Cause Value=19, Retry Count=0)
*Oct 15 17:43:50.223 PDT: //1045/4E8686FF8C7E/CCAPI/ccCallReleaseResources:
   release reserved xcoding resource.
*Oct 15 17:43:50.223 PDT: //1046/4E8686FF8C7E/CCAPI/cc_api_get_transfer_info:
   Transfer Number=NULL
*Oct 15 17:43:50.223 PDT: //-1/xxxxxxxxxxxx/CCAPI/ccUpdateRedirectingNumber:
   type=6 redirecting_number=13000
*Oct 15 17:43:50.223 PDT: //-1/xxxxxxxxxxxx/CCAPI/ccUpdateRedirectNumber:
   type=6  Original Called Number=13000, Called Number=13000, Calling Number=6044175261, Calling DN=-1 Calling Id=1045,
   Redirect Number=13019, Redirect Reason=2
   Updated numbers: type=6  Original Called Number=13000, Redirect Number=13019
*Oct 15 17:43:50.223 PDT: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
*Oct 15 17:43:50.223 PDT: :cc_get_feature_vsa malloc success
*Oct 15 17:43:50.223 PDT:  cc_get_feature_vsa count is 3
*Oct 15 17:43:50.223 PDT: :FEATURE_VSA attributes are: feature_name:0,feature_time:555761104,feature_id:1321
*Oct 15 17:43:50.223 PDT: //-1/xxxxxxxxxxxx/CCAPI/cc_update_feature_vsa:
*Oct 15 17:43:50.223 PDT:  feature_vsa is 21203CE8,featname is 0
*Oct 15 17:43:50.223 PDT:  cc_get_feature_vsa count is 4
*Oct 15 17:43:50.223 PDT: :FEATURE_VSA attributes are: feature_name:0,feature_time:555760656,feature_id:1322
*Oct 15 17:43:50.223 PDT: : Generating new feature vsa,inserting it
*Oct 15 17:43:50.223 PDT:  feature call forward featname is 3
*Oct 15 17:43:50.223 PDT:  feature_vsa is 21203EA8,featname is 0
*Oct 15 17:43:50.223 PDT:  cc_get_feature_vsa count is 5
*Oct 15 17:43:50.223 PDT: :FEATURE_VSA attributes are: feature_name:0,feature_time:555759760,feature_id:1323
*Oct 15 17:43:50.223 PDT: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
*Oct 15 17:43:50.223 PDT: :cc_free_feature_vsa freeing 21203DC8
*Oct 15 17:43:50.223 PDT:  vsacount in free is 4
*Oct 15 17:43:50.223 PDT: //1046/4E8686FF8C7E/CCAPI/ccCallDisconnect:
   Cause Value=16, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=19)
   Cause Value=19, Call Entry(Responsed=TRUE, Cause Value=19)
*Oct 15 17:43:50.231 PDT: //1046/4E8686FF8C7E/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x3E41966C, Tag=0x0, Call Id=1046,
   Call Entry(Disconnect Cause=19, Voice Class Cause Code=0, Retry Count=0)
   Call Disconnect Event Sent
*Oct 15 17:43:50.231 PDT: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
*Oct 15 17:43:50.231 PDT: :cc_free_feature_vsa freeing 21203888
*Oct 15 17:43:50.231 PDT:  vsacount in free is 3
*Oct 15 17:43:50.231 PDT:  vsacount in free is 2
*Oct 15 17:43:50.231 PDT: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
*Oct 15 17:43:50.231 PDT: :cc_get_feature_vsa malloc success
*Oct 15 17:43:50.231 PDT:  cc_get_feature_vsa count is 3
*Oct 15 17:43:50.231 PDT: :FEATURE_VSA attributes are: feature_name:0,feature_time:555761328,feature_id:1324
*Oct 15 17:43:50.231 PDT: //-1/xxxxxxxxxxxx/CCAPI/cc_update_feature_vsa:
*Oct 15 17:43:50.231 PDT:  feature call forward featname is 3
*Oct 15 17:43:50.231 PDT: :cc_free_feature_vsa freeing 21203EA8
*Oct 15 17:43:50.231 PDT: //1045/4E8686FF8C7E/CCAPI/cc_api_get_ccm_detected:
   CallInfo(ccm detected=FALSE)
*Oct 15 17:43:50.231 PDT: //1045/4E8686FF8C7E/CCAPI/ccCallForwardTo:
   Call Forward Number=13019, Call Forward Cause Reason=2, Call Id=1045
*Oct 15 17:43:50.235 PDT: //1045/4E8686FF8C7E/CCAPI/cc_api_call_disconnected:
   Cause Value=16, Interface=0x3D059174, Call Id=1045
   Call Entry(Responsed=TRUE, Cause Value=16, Retry Count=0)
*Oct 15 17:43:50.235 PDT: //1045/4E8686FF8C7E/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 302 Moved Temporarily
Via: SIP/2.0/UDP 216.13.193.132:5060;branch=z9hG4bK89cee816c2c0edf132576ee965bced69
From: <sip:6044175261@216.13.193.132>;tag=c4-45026-c001f6-2f28f60c-c001f6
To: <sip:7783720318@104.145.14.210;user=phone>;tag=6EC2D398-58D
Date: Thu, 16 Oct 2014 00:43:40 GMT
Call-ID: 6648198-3622409073-653461@SBC3-VAN.allstream.com
CSeq: 1 INVITE
Allow-Events: telephone-event
Server: Cisco-SIPGateway/IOS-15.3.3.M3
Diversion: <sip:13000@104.145.14.210>;reason=no-answer;counter=1
Contact: <sip:13019@10.1.17.2>
Content-Length: 0
*Oct 15 17:43:50.235 PDT: //1045/4E8686FF8C7E/CCAPI/ccCallDisconnect:
   Cause Value=16, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=16)
   Cause Value=16, Call Entry(Responsed=TRUE, Cause Value=16)
*Oct 15 17:43:50.235 PDT: //-1/xxxxxxxxxxxx/CCAPI/ccMemPoolTDFreeHelper:
   data = 405E6174
*Oct 15 17:43:50.235 PDT: ccMemPoolTDFreeHelper:mem_mgr_mempool_free: mem_refcnt(42035684)=0 - mempool cleanup
*Oct 15 17:43:50.239 PDT: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
ACK sip:7783720318@104.145.14.210;user=phone SIP/2.0
Max-Forwards: 70
CSeq: 1 ACK
Allow: CANCEL, ACK, INVITE, BYE, OPTIONS, REGISTER, NOTIFY, INFO, REFER, SUBSCRIBE, PRACK, UPDATE, MESSAGE, PUBLISH
Contact: <sip:6044175261@216.13.193.132:5060;tgrp=NLCAZZGEN21>
User-Agent: CS2000_NGSS/8.0
X-nortel-profile: NLCAZZGEN21
Charge: <sip:6044175261@66.46.60.88;user=phone>;noa=3
Content-Length: 0
*Oct 15 17:43:50.243 PDT: //1045/4E8686FF8C7E/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x3D059174, Tag=0x0, Call Id=1045,
   Call Entry(Disconnect Cause=16, Voice Class Cause Code=0, Retry Count=0)
*Oct 15 17:43:50.243 PDT: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
*Oct 15 17:43:50.243 PDT: :cc_free_feature_vsa freeing 21203C08
*Oct 15 17:43:50.243 PDT:  vsacount in free is 1
*Oct 15 17:43:50.243 PDT:  vsacount in free is 0
no supplementary-service sip moved-temporarily
and
no supplementary-service sip refer
did the trick. Thanks very much!
