SIP received CSeq: 101 CANCEL
Im new to SIP. I just want to confirm from the SIP experts, if my setup is correct.
Call Flow:
Primary Active: IP Phone SCCP <-> CUCM 9.1 <-> H323 <-> VG2901 (CUBE) <-> ISDN DID
Testing: IP Phone SCCP <-> CUCM 9.1 <-> SIP Trunk <-> VG2901 (CUBE) <-> SIP DID
ISDN is currently active and I'm preparing SIP for the customer so we can cutover later when SIP is ready. At the moment, inbound works via SIP working side by side with the ISDN. Calling the SIP DID pilot # the call hits CUCM and the phone rings. For outbound I have created a route pattern in CUCM that goes out via SIP trunk then to the CUBE then to SBC. No luck with outbound call. I get a fast busy as soon as the called number matches the CUCM route pattern.
CUCM Setup:
CUCM: 192.168.1.251
Gateway registers to VG2901 (CUBE) as IP Address 192.168.1.254.
SIP Trunk registers to the same VG2901 (CUBE) as IP Address 192.168.1.254. Im not sure if this is causing the problem, having the same IP Address in CUCM for both H323 VG and SIP Trunk to the same VG/CUBE.
See attached debug
Everyone's tags (1)
1 ACCEPTED SOLUTION
Hello,From the logs, I see
From the logs, I see the call is coming in to CUBE from CUCM, but there is no logs between CUBE & SIP Provider.
Have you configured the VoIP dial-peers to reach the SIP DID at your provider side?
could you please post the CUBE config?
You can refer this document on CUBE config & Binding the ineterface.
https://supportforums.cisco.com/blog/154506
//Suresh
Please rate all the useful posts.
//Suresh Please rate all the useful posts.
//Suresh
Thanks Suresh. You pointed me
Thanks Suresh. You pointed me to the right direction. The problem was the outbound SIP call was hitting another dial-peer towards POTS which was matching the destination pattern .T
Problem solve. Thanks again for the tip.
Good to know the issue is
Good to know the issue is fixed smiley
712
