07-23-2012 10:00 AM - edited 03-16-2019 12:19 PM
Hi guys,
I have a client who is using 2911 as the voice gateway which is connecting between Nortel and SIP Server.
The PSTN calls made by SIP Phones use 2911 to route calls to Nortel (which is connected to 2911 through PRI).
They are also using an IVR application which is running off SIP server as well.
The issue as blind transfer between SIP and Nortel is not working.
I did a 'debug ccsip messages'.
Here is what is standing out in my debugs:
Sent:
NOTIFY sip:8971@192.168.4.11:5060 SIP/2.0 <-- 8971 is the number that i dialed. It exists on IVR and it does a blind transfer to my cell phone. 192.168.4.11 is the voice gateway.
Via: SIP/2.0/UDP 192.168.4.241:5060;branch=z9hG4bK4D270 <-- 192.168.4.241 is the 3rd party SIP server.
From: <sip:1180@192.168.4.241>;tag=EE9D3918-37E <-- 1180 is the number on Nortel side. Its my calling number.
To: "Voice Server on pos-ipcm"<sip:8971@pos-ipcm.xyz.com>;tag=2a5ba710
Call-ID: A7752611-D41611E1-9A8CCB82-FEC7DE00@192.168.4.241
CSeq: 103 NOTIFY
Max-Forwards: 70
Date: Mon, 23 Jul 2012 16:02:36 GMT
User-Agent: Cisco-SIPGateway/IOS-12.x
Event: refer
Subscription-State: terminated;reason=noresource
Contact: <sip:1180@192.168.4.241:5060>
Content-Type: message/sipfrag
Content-Length: 35
SIP/2.0 503 Service Unavailable
Any help in solving this would be appreciated.
07-23-2012 10:33 AM
Hi !
Is any Q931 cause code you able to get in this debug ?
you can enable the debug ccsip info for more details...
07-23-2012 11:05 AM
Looks like normal call clearing on Q931.
Jul 23 16:02:36.562: ISDN Se0/0/0:23 Q931: TX -> DISCONNECT pd = 8 callref = 0x8017
Cause i = 0x8290 - Normal call clearing
07-26-2012 11:20 AM
Sorry, Actually I also see the following on the debug:
Channel ID i = 0xE9808316
Exclusive, Interface 0, Channel 22
Jul 23 16:02:36.338: ISDN Se0/0/0:23 Q931: RX <- CALL_PROC pd = 8 callref = 0x92D4
Jul 23 16:02:36.506: ISDN Se0/0/0:23 Q931: RX <- DISCONNECT pd = 8 callref = 0x92D4
Cause i = 0x819D - Facility rejected
07-26-2012 11:56 AM
You need to post the entitre trace for failure case, not just fragments.
07-26-2012 12:00 PM
07-26-2012 12:22 PM
To make it short, cisco makes a call for 94168268250 to PBX, that is rejected.
Is PBX configured to allow calls to that number ? Check with PBX technicians.
