SIP RTMT Trace Logs
We configured a sip trunk between Call Manager(v7.1.5) to a nortel switch.  We are able to call from CCM to nortel fine using the sip trunk.  When the nortel side tries to call ccm using the sip trunk they get reorder.  Is there a way in rtmt using trace tool to see if the call is getting to ccm or or what is happening to the call? Thanks
1 REPLY
Green
SIP RTMT Trace Logs
Try using this doc
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_tech_note09186a0080094e89.shtml
But in the SDI detail trace set up ensure that you check the SIP Stack trace
You should be able to view your traces using VLT
Alex
Regards, Alex. Please rate useful posts.
2427
