Sip + Sccp
hi, i am using CME4.0. Currently my phones are using sccp, is it possible to integrate sip into my voice LAN protocol together with sccp?
I'd like to have x-lite(softphone) connected to CME to call my ip phones. is that possible
Hall of Fame Super Gold
Re: Sip + Sccp
Currently CME does not support non-cisco phones, but it will at a later time.
The most you can get with a SIP phone today is to use like a dial-peer, however the phone will not register as extension.
The Cisco CIPC, that is SCCP, works fine as softphone.
Re: Sip + Sccp
I'm also using CME 4.0. Could You give me an example for a dial-peer who is working with a sip-client (x-Lite)?
(Now there ist CME 4.1 available could this solve the problems with sip-client's ?)
thanks a lot
Reto
Re: Sip + Sccp
In fact, the non-cisco phones will register and are supposed to work, it's just that Cisco TAC will not support this config if there are issues.
Configure "voice register pool" with username and password, and "id mac". MAC does not need to be actual one and can be anything.
Re: Sip + Sccp
yes to that, Cisco does not support, but does not mean that it doesnt work. Inorder for xlite to work with CME, configure
voice register global
mode cme
source-address
dialplan-pattern
voice register dn x
number xxxx
voice register pool x
id mac xxxx.xxxx.xxxx
username xx password xx
codec xxx
It works almost the same way as ephone+ephone-dn, but just different terms
Re: Sip + Sccp
A nitpick:
Codec must be g711 for x-lite, as it doesn't support g.729, and I didn't managed to work with anything else, even using voice class codec.
Re: Sip + Sccp
thnks all for the support. The XLite softphone works now fine.
Re: Sip + Sccp
I have a problem too, because I want to configure a Linksys SPA941 with my CME, I have tried with your method but it's not working
Is There anything to do about Firmware files or configuration Files ?
Thanks in advance for your help
Baptiste
Re: Sip + Sccp
What is not working ?
Does the telephone register ?
How is the linksys configured ?
Re: Sip + Sccp
No, the phone don't register, and I don't see any messages SIP in the output of debug ccsip all.
How is the Linksys Configured ?
Please see my config in attached
Re: Sip + Sccp
You also need "number" in voice register pool 1, to associate a DN to this phone.
To see the debug, please enter "term mon" before or after "debug ccsip message".
If you do not see anything, it means your phone is not even trying to register or place calls to CCME address.
Re: Sip + Sccp
I have add the "number" command in voice resgister pool, but it's not working
For the debug ccsip message, the term mon is ON, but I can't see nothing when i reload the phone for example
Do I need to create a profile File? And what's about the Firmware file?
I don't have understand this part for non-CISCO SIP Phone
Thanks in advance for your help,
Baptiste
Re: Sip + Sccp
There is no profile, no firmware for non-cisco phones.
When you reload the phone, it should attempt registering. When you make a call, you should see "SIP invite".
Check with "show logging" that debug to terminal has not been disabled. That could be the reason for not seeing debug messages.
Hope this helps, please rate posts using the scrollbox below
Re: Sip + Sccp
No, the terminal has not been disabled.
I have configured a monitoring port on the switch to see what's happened on the Phone Port, and I can see only DHCP communication, and after, there are UDP packets between the phone and the IP 224.168.168.169 (UDP 6061), but there is nothing about registration or SIP message
All the things to configure are on the CME ? There is something to configure on the phone ?
Re: Sip + Sccp
Ok, I assume that from the CCME you can ping the phone. It should register on port 5060, not 6061. Check how the phone is configured.
Re: Sip + Sccp
Now it's working fine, it was a problem of configuration of the Lynksis (Proxy adress)
Ok, thanks very much for your help
Re: Sip + Sccp
Glad to know it's working now.
Please take a moment to rate useful posts using the scrollbox below!
389
