SIP SRST + 8961 phones + no voice register pool found
I have this sissue where the SIP phones are trying to register in SRST mode. SRST VGW does recognize the sip register packet but sends 404 not found back, unable to see the voice register pool.
This is the config i have used.
voice service voip
allow-connections sip to sip
redirect ip2ip
  sip
  registrar server expires max 600 min
voice register global
timeouts interdigit 5
system message SRST MODE
max-dn 100
max-pool 50
voice register pool  1
id network 23.222.23.0 mask 255.255.255.0
number 1 88483948.... preference 1
interface GigabitEthernet0/0
ip address 23.222.23.2 255.255.255.0
no ip redirects
no ip unreachables
duplex full
speed 100
no mop enabled
sip-ua
registrar ipv4:< CUCM IP> expires 3600
Logs:
REGISTER sip:23.222.23.2 SIP/2.0
Via: SIP/2.0/UDP 23.222.23.53:5060;branch=z9hG4bK1ef14e5f
From: <sip:884839480500@23.222.23.2>;tag=7c95f32213c815532b3fbbad-6522e7a5
To: <sip:884839480500@23.222.23.2>
Call-ID: 7c95f322-13c80360-0ecbfb72-1919fcbd@23.222.23.53
Max-Forwards: 70
Date: Sat, 05 Oct 2013 08:24:50 GMT
CSeq: 4595 REGISTER
User-Agent: Cisco-CP8961/9.3.2
Contact: <sip:5372d7ba-edcc-b58d-224b-20956ff3f6f2@23.222.23.53:5060;transport=udp>;+sip.instance="<urn:uuid:00000000-0000-0000-0000-7c95f32213c8>";+u.sip!devicename.ccm.cisco.com="SEP7C95F32213C8";+u.sip!model.ccm.cisco.com="540"
Supported: extended-refer,norefersub,X-cisco-srtp-fallback,X-cisco-config,X-cisco-sis-6.0.0,X-cisco-xsi-8.0.1
Content-Length: 0
Reason: SIP;cause=200;text="cisco-alarm:24 Name=SEP7C95F32213C8 ActiveLoad=sip8961.9-3-2-10.loads InactiveLoad= Last=phone-reg-rej"
Expires: 3600
008253: Oct  5 15:24:06.961 GMT: voice_reg_get_reg_expires_timer: no voice register pool found
008254: Oct  5 15:24:06.961 GMT: VOICE_REG_POOL: Register request for (884839480500) from (23.222.23.53)
008255: Oct  5 15:24:06.961 GMT: VOICE_REG_POOL: Contact doesn't match any pools
008256: Oct  5 15:24:06.965 GMT: //16746/5609C78FA3CC/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 404 Not Found
To: <sip:884839480500@23.222.23.2>;tag=23A450E8-C1A
Date: Sat, 05 Oct 2013 08:24:06 GMT
Server: Cisco-SIPGateway/IOS-15.2.4.M3
CSeq: 4595 REGISTER
Content-Length: 0
Any idea on what an issue could be?
Pankaj Malhotra
I think i found what an issue was.
In SRST, voice register pool shouldn't contain number field.
number 1 88483948.... preference 1>>> this needs to be removed and after which all phones will get the pool.
I'm getting same error, I removed the number field also, but still same, can you post your correct config ?
Regds
Hi Fernando,
My config was exactly same as pasted above except the number command that made it work. I implemented another site with same config and that worked too.
Can you paste the debug output along with sip config that you are using?
Pankaj
2153
