SIP SRST and 9971 phones
I'm trying to get sip srst working and must be missing something very simple.
This is the config I've got:
voice service voip
ip address trusted list
  ipv4 85.119.63.4
  ipv4 10.26.120.129
  ipv4 10.26.120.0 255.255.255.0
address-hiding
allow-connections sip to sip
redirect ip2ip
fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback none
sip
  bind control source-interface GigabitEthernet0/1
  bind media source-interface GigabitEthernet0/1
  registrar server
  asserted-id pai
  midcall-signaling passthru
  pass-thru content sdp
  sip-profiles 1
voice class codec 711
codec preference 1 g711ulaw
codec preference 2 g711alaw
codec preference 3 g729r8 bytes 30
voice register global
system message *** SRST in Action ***
max-dn 56
max-pool 10
voice register pool  1
id network 10.26.120.0 mask 255.255.255.0
preference 2
proxy 10.26.120.129 preference 1
dtmf-relay rtp-nte
voice-class codec 711
As far as the router is concerned the phones are registering:
Jul 30 12:17:44.459 BST: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
REGISTER sip:10.26.120.148 SIP/2.0
Via: SIP/2.0/UDP 10.26.120.151:5060;branch=z9hG4bK43fdeaec
From: <sip:6001@10.26.120.148>;tag=d0c282d0aefe00125e06e369-237448af
To: <sip:6001@10.26.120.148>
Call-ID: d0c282d0-aefe007c-6f1a051f-74c189c4@10.26.120.151
Max-Forwards: 70
Date: Mon, 30 Jul 2012 11:17:28 GMT
CSeq: 105 REGISTER
User-Agent: Cisco-CP9971/9.2.4
Contact: <sip:da7b99eb-78ea-c180-af59-987dd2c5b195@10.26.120.151:5060;transport=udp>;+sip.instance="<urn:uuid:00000000-0000-0000-0000-d0c282d0aefe>";+u.sip!devicename.ccm.cisco.com="SEPD0C282D0AEFE";+u.sip!model.ccm.cisco.com="493";video
Supported: extended-refer,norefersub,X-cisco-srtp-fallback,X-cisco-config,X-cisco-sis-5.2.0,X-cisco-xsi-8.0.1
Content-Length: 0
Reason: SIP;cause=200;text="cisco-alarm:14 Name=SEPD0C282D0AEFE ActiveLoad=sip9971.9-2-4-19.loads InactiveLoad=sip9971.9-2-1.loads Last=cm-closed-tcp"
Expires: 3600
Jul 30 12:17:44.459 BST: //76/F6E40EFF8035/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
To: <sip:6001@10.26.120.148>;tag=3E5B6C-5D6
Date: Mon, 30 Jul 2012 11:17:44 GMT
Server: Cisco-SIPGateway/IOS-12.x
CSeq: 105 REGISTER
Supported: X-cisco-srst-sis-1.0.0
Supported: X-cisco-srtp-fallback
Contact: <sip:6001@10.26.120.151:5060>;expires=3600;x-cisco-newreg
Expires:  3600
Content-Length: 0
However, the phones themselves just sit there with the message : Registering and blank screen.
Any ideas?
  • IP Telephony
Everyone's tags (2)
Did you check if the phone has the SRST reference? At the phone Go to Setting -->Device Configuration --> Unified CM Configuration--> SRST: IP?
Regadrs
Please remember to rate useful posts clicking on the stars below. Favor calificar todos las respuestas útiles dando click en las estrellas de mas abajo. ___________________________________________ LinkedIn Profile: do.linkedin.com/in/leosalcie
Yep - 2nd server is the SRST gateway
CUCM Server1
10.26.120.129 Active
CUCM Server2
10.26.120.148 Standby
Hall of Fame Super Silver
Your proxy is the IP address of the CUCM server then, it needs to be the local SRST GW.
Chris
Tried that but still the same result.
1526
