SIP SRST with 3905
Hi I have SIP srst with 3905 and 6921. 6921 Phones are getting registered as expected with SRST gateway. but 3905s not like that. i need to restart (re-plug) the phone manulally, then they will register with SRST. what will be the reason for this ?
is this a bug ?
Regds
  • IP Telephony
Everyone's tags (2)
Re: SIP SRST with 3905
Since you need SIP  SRST in order to re-register these phones to the GW, please check these  links:
http://www.cisco.com/en/US/docs/voice_ip_comm/cusrst/admin/sccp_sip_srst/configuration/guide/srst_41.html
http://www.cisco.com/en/US/docs/voice_ip_comm/cusrst/feature/guide/srst71ft.html
The solution was to put configurations related to sip, these are the lines that i added
********* Enable SIP srst register **************
voice register global
system message XXX
max-dn 20
max-pool 20
********** Create the endpoints that are going to register with the gateway ************
voice register pool  1
id mac XXXX.XXXX.XXXX
number 1 711
codec g711alaw
********* SRST related **********
application
global
  service alternate Default
sip-ua
Voice CCIE #37771
SIP SRST with 3905
Hi Hermanus
Thanks for the reply, I aleady using SIP srst, my other Phones are registering as Expected. (suddenly when disconnect the WAN) but for 3905 i need to manually re-plig the cable (restart the phone to register)
Regds
SIP SRST with 3905
an
d
your 3905 is on the latest FW ver for your CUCM ver?
Voice CCIE #37771
VIP Purple
SIP SRST with 3905
Hi Fernando,
what is CUCM version u are using?
have u added IP address in SIP Network/IP address under SRST reference configuration?
regds,
aman
SIP SRST with 3905
Yes, i'm using latest FW version
CUCM - 9.1.1.20000-5
FW  - CP3905.9-4-1-0
Regds
VIP Purple
SIP SRST with 3905
Hi Fernando,
please check have u added IP address in SIP Network/IP address under SRST reference configuration in call manager.
regds,
aman
SIP SRST with 3905
Yes I did it.
Regds
SIP SRST with 3905
have you tried one of the 3905 on a lower FW ver like 9-3-2 or something and see if you get the same issue.
Voice CCIE #37771
SIP SRST with 3905
No i'm not, because there are lot of bugs in prevous FW version. So thats why i upgraded it to latest. if I downgread it other bugs will eb hit to phone.
Regds
627
