08-17-2012 04:20 AM - edited 03-16-2019 12:45 PM
I am using the NM-1CE1T1-PRI module in cisco 2821 router. In this module i want to terminate the PRI line, anyone can tel me it will support the SIP trunk protocol.
Karthik
08-17-2012 06:19 AM
You can configure SIP, MGCP and H323 in the same router without issues.
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
08-17-2012 06:34 AM
SIP does not require any modules it is IOS dirven and only requires CUBE license if connecting to external SIP provider.
Chris
08-18-2012 09:56 AM
The answer is no, because NM-1CE1T1-PRI does not support voice, and cannot be used with SIP protocol.
