SIP Support Module In Cisco 2821
I am using the NM-1CE1T1-PRI module in cisco 2821 router. In this module i want to terminate the PRI line, anyone can tel me it will support the SIP trunk protocol.
Karthik
Everyone's tags (5)
You can configure SIP, MGCP and H323 in the same router without issues.
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
Hall of Fame Super Silver
SIP does not require any modules it is IOS dirven and only requires CUBE license if connecting to external SIP provider.
Chris
Hall of Fame Super Gold
The answer is no, because NM-1CE1T1-PRI does not support voice, and cannot be used with SIP protocol.
766
