Community Member
SIP to carrier via MPLS with SRST H323 to POTS for backup
I have a customer running CM 4.1(3) with remote sites connected via MPLS using SIP (via CUBE) into MPLS cloud for PSTN connectivity. They also have 1-2 POTS lines to use for SRST if their T-1/MPLS/SIP connection goes down.
I've had a heck of a time getting the SRST/H323 dial-peers to work with the SIP dialpeer (and H323 dial-peer back to CUCM). Basically, I can't get SIP and SRST functioning simultaneously within the same CUBE/VGW. I've talked to TAC and have been clued into the use of the "monitor probe" dial-peer command with the call-fallback-active command to remove the SIP/primary-H323 dial-peers when the T-1/MPLS connection goes down; therefore, utilizing the SRST H323 dial-peers when in fallback mode. I have not been successful with this.
1) Does anyone have a working config that mimcs this environment, that they could share the highlights?
2) Does going to CUCM v7 help in any way, in determinng dial-peer selection? (Perhaps because I can then be SIP on both sides of the CUBE)?
Below are my config highlights:
voice service voip
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
h323
emptycapability
h225 id-passthru
h245 passthru tcsnonstd-passthru
sip
bind control source-interface Vlan241
bind media source-interface Vlan241
voice class h323 1
h225 timeout tcp establish 1
h225 timeout connect 60
h225 timeout setup 1
interface Serial0/2/0
ip address 2.2.2.2 255.255.255.0
encapsulation ppp
max-reserved-bandwidth 99
service-policy input WanIn
call fallback active
voice-port 0/0/0
timing hookflash-out 500
connection plar 8331
dial-peer voice 320 pots
*** TO CARRIER via POTS FOR H323/SRST ***
preference 8
destination-pattern 81[2-9]..[2-9]......
port 0/0/0
prefix 1
dial-peer voice 220 pots
preference 8
destination-pattern 8[2-9]......
port 0/0/0
dial-peer voice 1 voip
*** TO CARRIER SIP ***
preference 1
destination-pattern .T
monitor probe icmp-ping 10.99.204.10
voice-class h323 1
session target ipv4:10.99.204.10
dtmf-relay h245-alphanumeric
codec g711ulaw
no vad
dial-peer voice 2 voip
*** TO Subscriber FOR H323/SIP PRIMARY ***
preference 2
monitor probe icmp-ping 10.1.1.2
session protocol sipv2
session target ipv4:10.1.1.2
incoming called-number .
dtmf-relay rtp-nte
codec g711ulaw
no vad
dial-peer voice 3 voip
*** TO PUB FOR H323/SIP PRIMARY ***
preference 3
monitor probe icmp-ping 10.1.1.1
voice-class h323 1
session target ipv4:10.1.1.1
codec g711ulaw
no vad
dial-peer hunt 2
call-manager-fallback
secondary-dialtone 8
max-conferences 8 gain -6
limit-dn 7940 2
limit-dn 7960 6
timeouts interdigit 3
ip source-address 10.20.1.1 port 2000
max-ephones 42
max-dn 36
system message primary CM Failed, NOW on SRST
keepalive 10
Thanks for any input!
Mike.
316
