SIP-to-H323
I have the following configuration:
Asterisk<--(SIP with G711 codec)-->Cisco 2811(ipvoice IOS)<--H323 with g729r8 codec)-->VOIP Provider
I am calling from Asterisk to VOIP Provider. Cisco 2811nm act as SIP/H323 gateway and as G711/G729 transcoder. The problem: when i call from asterisk to VOIP Provider the connection is established but i can not hear the other side and they can not hear me.
A part of config:
voice service voip
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
redirect ip2ip
fax protocol t38 ls-redundancy 5 hs-redundancy 2 fallback none
h323
dial-peer voice 2 voip
session protocol sipv2
incoming called-number .T
codec g711alaw bytes 80
dial-peer voice 7 voip
destination-pattern 8T
translate-outgoing calling 4
session target ipv4:
tech-prefix 70
codec g729r8 bytes 40
gateway
timer receive-rtp 1200
How i can solve this problem ?
Hall of Fame Super Gold
Re: SIP-to-H323
You need a transcoding configuration for this, search "configuring transcoding". Also needed, an _ivs image (CUBE) and licence.
If you use asterisk as IP PBX try the router instead.
Re: SIP-to-H323
I am using c2800nm-ipvoice_ivs-mz.124-18 IOS.
I read this link http://www.cisco.com/en/US/docs/ios/12_3/vvf_c/interop/intcnf2.html but i do not understand why i need to configure SCCP ?
Re: SIP-to-H323
You need to because SCCP is the protocol used by transcoding, due to cisco architecture you cannot do otherwise.
The router can work as a nice PBX for SIP phones, that is called CME, that's why I suggested you use it.
Re: SIP-to-H323
I cannot refuse asterisk use :)
Can you explain a part of config from http://www.cisco.com/en/US/docs/ios/12_3/vvf_c/interop/intcnf2.html:
sccp local FastEthernet0/0
sccp ccm 10.4.20.24 identifier 1 version 4.0 - what it means, whose is the address ?
sccp ccm 10.4.20.25 identifier 2 version 4.0
sccp ccm 10.4.20.26 identifier 3 version 4.0
sccp ip precedence 3
sccp
sccp ccm group 988
associate ccm 1 priority 1 - what it means ?
associate ccm 2 priority 2
associate ccm 3 priority 3
associate profile 10 register CFB123456789966 (register - what it means)
associate profile 6 register MTP123456789988
keepalive retries 5
switchover method immediate
switchback method immediate
switchback interval 15
dspfarm profile 6 transcode
codec g711ulaw
codec g711alaw
codec g729ar8
codec g729abr8
maximum sessions 4
associate application SCCP
Re: SIP-to-H323
If your call is getting set up, and not being torn down automatically, you have other problems.
If the call automatically disconnects when you answer or when it rings, then it is a codec negotiation problem.
Regarding the SCCP question:
In order to transcode some operation/process needs to have knowledge of the calls and be able to talk to the transcoder to tell it what to do. You basically configure CME on the CUBE, and then register the transcoder to itself.
hth,
nick
Re: SIP-to-H323
at http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_configuration_example09186a008084fe1f.shtml and in other links about transcoding the Cisco Call Manager connecting to the router (CUBE if i am right). But how I can connect the asterisk to the router to transcode from one codec to another?
Re: SIP-to-H323
Re: SIP-to-H323
thank you for link
Whether I should use an asterisk IP address in this line:
sccp ccm 10.10.10.2 identifier 1
Re: SIP-to-H323
No, a local address to register to itself.
Re: SIP-to-H323
ok, i will try
Thank you
Re: SIP-to-H323
I try to configure my router according http://www.cisco.com/en/US/docs/ios/12_4t/12_4t15/it_unitr.html#wp1053671
but i have some problems - i can not set maximum sessions value and codec value in dspfarm profile 10 transcode section:
(config-dspfarm-profile)#maximum sessions ?
<0-0> Number of sessions assigned to this profile
(config-dspfarm-profile)#codec ?
% Unrecognized command
#sh dspfarm
DSPFARM Configuration Information:
Admin State: DOWN, Oper Status: DOWN - Cause code: ADMIN_STATE_DOWN
Transcoding Sessions: 0(Avail: 0), Conferencing Sessions: 0 (Avail: 0)
Trans sessions for mixed-mode conf: 0 (Avail: 0), RTP Timeout: 600
Connection check interval 600 Codec G729 VAD: ENABLED
Here is a part of config:
voice-card 0
no dspfarm
dsp services dspfarm
voice service voip
redirect ip2ip
h323
sccp local FastEthernet0/1.89
sccp ccm 193.109.89.245 identifier 1
sccp
sccp ccm group 1
associate profile 10 register ASTERISK
keepalive retries 5
shutdown
gateway
gatekeeper
shutdown
Re: SIP-to-H323
This is because you do not have enough DSPs.
'show diag | i FRU' should include some PVDM2-X modules.
If not, you will need DSP resources to do transcoding.
-nick
Re: SIP-to-H323
I think that no DSP in this router, isn't it ?
#show diag
Slot 0:
C2811 Motherboard with 2FE and integrated VPN Port adapter, 2 ports
Port adapter is analyzed
Port adapter insertion time 1d06h ago
EEPROM contents at hardware discovery:
PCB Serial Number : FOC091736XY
Hardware Revision : 3.0
Top Assy. Part Number : 800-21849-02
Board Revision : B0
Deviation Number : 0
Fab Version : 06
RMA Test History : 00
RMA Number : 0-0-0-0
RMA History : 00
Processor type : 87
Hardware date code : 20050429
Chassis Serial Number : FCZ0924709H
Chassis MAC Address : 0013.c4dd.39b8
MAC Address block size : 24
CLEI Code : CNMJ7N0BRA
Product (FRU) Number : CISCO2811
Part Number : 73-7214-10
Version Identifier : V01
EEPROM format version 4
EEPROM contents (hex):
0x00: 04 FF C1 8B 46 4F 43 30 39 31 37 33 36 58 59 40
0x10: 03 E7 41 03 00 C0 46 03 20 00 55 59 02 42 42 30
0x20: 88 00 00 00 00 02 06 03 00 81 00 00 00 00 04 00
0x30: 09 87 83 01 31 F1 FD C2 8B 46 43 5A 30 39 32 34
0x40: 37 30 39 48 C3 06 00 13 C4 DD 39 B8 43 00 18 C6
0x50: 8A 43 4E 4D 4A 37 4E 30 42 52 41 CB 8F 43 49 53
0x60: 43 4F 32 38 31 31 20 20 20 20 20 20 82 49 1C 2E
Re: SIP-to-H323
Correct - there are no DSPs.
You would need to get DSPs - they are PVMD2-X. The X can be 8,16,32,48,or 64.
You may want to use the DSP calculator to determine what is appropriate for your transcoding situation:
http://www.cisco.com/cgi-bin/Support/DSP/cisco_prodsel.pl
hth,
nick
Re: SIP-to-H323
ok,
thank you for help and discussion !
1575
