Community Member
sip to qsig via 2811 no ring back tone
Hi i'm trying to connect a qsig with a siemens
i'm sending sip invite to a 2811 that should send the call to siemens
when my side dial the siemens i have no ring back tone.
my audio are good the caller id /called number are ok.
so i tried the following
http://www.cisco.com/en/US/tech/tk1077/technologies_tech_note09186a0080094c33.shtml#voipcalls
applying this chapter
No Ringback Tone on VoIP Outbound Calls from Cisco CallManager (or Third Party Device) through Cisco IOS Gateway
but it's not working i applied all the params but without success on the pots dial peer.
I see the doc is  for h323 and can't find it for sip.
any ides?
thks
1 REPLY
Green
Can you post show runn
Also debug isdn q931 for a failure
Alex
Regards, Alex. Please rate useful posts.
386
