SIP to SIP call between cisco 9951 phones gets cut after 79 sec
I have an issue calling sip to sip.  It gets cut after 79 secs
  • IP Telephony
2 ACCEPTED SOLUTIONS
VIP Super Bronze
I have looked in detail into the logs and here is what I have found...Your call is been disconnected due to OPTIONS ping issue. The 9951 IP Phone is not responding to the OPTIONS ping sent by the CCME and during an active call, CCME thinks the phone is not alive, it then tears down the call..
009773: Feb 10 09:38:02.457: //351807/80109254BB4D/SIP/Error/act_active_sent_options_wait_response: Out of retries
009774: Feb 10 09:38:02.457: //351807/80109254BB4D/SIP/Error/ccsip_handle_in_dialog_options_result: socket/dns/software error while trying to send the options - tear down call
009775: Feb 10 09:38:02.457: //351807/80109254BB4D/SIP/Info/ccsip_set_release_source_for_peer: ownCallId[351807], src[4]
The callid 351807 is the calleg from CCME to the 9951 SIP Phone.
It looks like your 9951 phones do not support OPTIONS ping or the firmware you are running doesnt support it. I suggest you disable options ping globally and leave the one on the dial-peer to your ITSP
voice service voip
sip
no options-ping 60
Test again
Please rate all useful posts
"The essence of christianity is not the enthronement but the obliteration of self --William Barclay"
Please rate all useful posts "The essence of christianity is not the enthronement but the obliteration of self --William Barclay"
VIP Super Bronze
Re: SIP to SIP call between cisco 9951 phones gets cut after 79
Another thing that I noted is that you have not modified your sip try timers..Hence the reason why it took that long for the call to disconnect..The OPTIONS ping was sent 7 times (first OPTIONS + 6 retries). The default try is 6
Please change the default setting..as follows:
conf t
sip-ua
retry invite 2
timers trying 150
Hi bern,
Is this happening for internal calling or over the wan?
Can you please share your call flow topology and detail trace from CUCM.
Nishant Savalia
Regards, Nishant Savalia
Hi Nishant,
Even local calls. Extension to Extension.  It is happenning only on the 9951 phones.  the SCCP phones have no issues.  SCCP to SCCP = no issue SIP to SIP = call drops SCCP to SIP = call drop.
Hi bern,
Please send detail trace from CUCM.
Nishant Savalia
Hi Nishant,
Please see debug details:
calling number:
112499444
called number:
114818300
extension 998
Feb  9 10:29:29: //333541/000000000000/SIP/Msg/ccsipDisplayMsg:
Sent:
OPTIONS sip:998@10.10.100.36:5060;transport=udp SIP/2.0Via: SIP/2.0/UDP 172.29.36.46:5060;branch=z9hG4bK3EB26CB6From: <112499444>;tag=5C6FF150-1D5ETo: <998>;tag=20bbc093acee009b70240ce2-47ab7511Date: Sun, 09 Feb 2014 07:29:29 GMTCall-ID: 92545B37-909211E3-B264E048-D6366222@172.29.36.46User-Agent: Cisco-SIPGateway/IOS-12.xMax-Forwards: 70CSeq: 102 OPTIONSContact: <112499444>Content-Length: 0
Feb  9 10:29:32: //333563/000000000000/SIP/Msg/ccsipDisplayMsg:
Sent:
OPTIONS sip:10.200.7.157:5060 SIP/2.0Via: SIP/2.0/UDP 172.29.36.46:5060;branch=z9hG4bK3EB291F6FFrom: <172.29.36.46>;tag=5C711FC0-359To: <10.200.7.157>Date: Sun, 09 Feb 2014 07:29:32 GMTCall-ID: C07A56CC-909211E3-B278E048-D6366222@172.29.36.46User-Agent: Cisco-SIPGateway/IOS-12.xMax-Forwards: 70CSeq: 101 OPTIONSContact: <172.29.36.46:5060>Content-Length: 0
Received:
SIP/2.0 200 OKVia: SIP/2.0/UDP 172.29.36.46:5060;branch=z9hG4bK3EB291F6FRecord-Route: <10.200.7.157:5060>Call-ID: C07A56CC-909211E3-B278E048-D6366222@172.29.36.46From: <172.29.36.46>;tag=5C711FC0-359To: <10.200.7.157>;tag=sbc0805dhf4se72CSeq: 101 OPTIONSContent-Length: 0
Feb  9 10:29:33: //333541/000000000000/SIP/Msg/ccsipDisplayMsg:
Sent:
OPTIONS sip:998@10.10.100.36:5060;transport=udp SIP/2.0Via: SIP/2.0/UDP 172.29.36.46:5060;branch=z9hG4bK3EB26CB6From: <112499444>;tag=5C6FF150-1D5ETo: <998>;tag=20bbc093acee009b70240ce2-47ab7511Date: Sun, 09 Feb 2014 07:29:33 GMTCall-ID: 92545B37-909211E3-B264E048-D6366222@172.29.36.46User-Agent: Cisco-SIPGateway/IOS-12.xMax-Forwards: 70CSeq: 102 OPTIONSContact: <112499444>Content-Length: 0
Sent:
OPTIONS sip:10.200.7.157:5060 SIP/2.0Via: SIP/2.0/UDP 172.29.36.46:5060;branch=z9hG4bK3EB2A4E1From: <172.29.36.46>;tag=5C712998-1D60To: <10.200.7.157>Date: Sun, 09 Feb 2014 07:29:34 GMTCall-ID: C1FADB6A-909211E3-B279E048-D6366222@172.29.36.46User-Agent: Cisco-SIPGateway/IOS-12.xMax-Forwards: 70CSeq: 101 OPTIONSContact: <172.29.36.46:5060>Content-Length: 0
Received:
SIP/2.0 200 OKVia: SIP/2.0/UDP 172.29.36.46:5060;branch=z9hG4bK3EB2A4E1Record-Route: <10.200.7.157:5060>Call-ID: C1FADB6A-909211E3-B279E048-D6366222@172.29.36.46From: <172.29.36.46>;tag=5C712998-1D60To: <10.200.7.157>;tag=sbc0803hbtkdbpeCSeq: 101 OPTIONSContent-Length: 0
Sent:
BYE sip:998@10.10.100.36:5060;transport=udp SIP/2.0Via: SIP/2.0/UDP 172.29.36.46:5060;branch=z9hG4bK3EB2B1B39From: <112499444>;tag=5C6FF150-1D5ETo: <998>;tag=20bbc093acee009b70240ce2-47ab7511Date: Sun, 09 Feb 2014 07:29:33 GMTCall-ID: 92545B37-909211E3-B264E048-D6366222@172.29.36.46User-Agent: Cisco-SIPGateway/IOS-12.xMax-Forwards: 70Timestamp: 1391930977CSeq: 103 BYEP-RTP-Stat: PS=3974,OS=635840,PR=3972,OR=635520,PL=0,JI=0,LA=0,DU=79Content-Length: 0
Sent:
BYE sip:112499444@10.200.7.157:5060;user=phone SIP/2.0Via: SIP/2.0/UDP 172.29.36.46:5060;branch=z9hG4bK3EB2C2BFrom: <4818300>;tag=5C6FA0A8-227BTo: <112499444>;tag=sbc0805uu4dbk7o-CC-41Date: Sun, 09 Feb 2014 07:28:54 GMTCall-ID: isbcofkakaotu4sku7cuabpf7bfa7hso2chc@SoftX3000User-Agent: Cisco-SIPGateway/IOS-12.xMax-Forwards: 70Route: <10.200.7.157:5060>Timestamp: 1391930977CSeq: 106 BYEReason: Q.850;cause=127P-RTP-Stat: PS=4666,OS=746003,PR=5097,OR=808812,PL=0,JI=0,LA=0,DU=103Content-Length: 0
Feb  9 10:29:37: //333541/000000000000/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 OKVia: SIP/2.0/UDP 172.29.36.46:5060;branch=z9hG4bK3EB2B1B39From: <112499444>;tag=5C6FF150-1D5ETo: <998>;tag=20bbc093acee009b70240ce2-47ab7511Call-ID: 92545B37-909211E3-B264E048-D6366222@172.29.36.46Date: Sun, 09 Feb 2014 07:29:29 GMTCSeq: 103 BYEServer: Cisco-CP9951/9.4.1Content-Length: 0
The Call Setup Information is:
Call Control Block (CCB) : 0x2B7240F0
State of The Call        : STATE_DEAD
TCP Sockets Used         : NO
Calling Number           : 112499444
Called Number            : 998
Source IP Address (Sig  ): 172.29.36.46
Destn SIP Req Addr:Port  : 10.10.100.36:5060
Destn SIP Resp Addr:Port : 10.10.100.36:5060
Destination Name         : 10.10.100.36
Feb  9 10:29:37: //333541/000000000000/SIP/Call/sipSPIMediaCallInfo:
Number of Media Streams: 1
Media Stream             : 1
Negotiated Codec         : g711alaw
Negotiated Codec Bytes   : 160
Nego. Codec payload      : 8 (tx), 8 (rx)
Negotiated Dtmf-relay    : 6
Dtmf-relay Payload       : 101 (tx), 101 (rx)
Source IP Address (Media): 172.29.36.46
Source IP Port    (Media): 21846
Destn  IP Address (Media): 10.10.100.36
Destn  IP Port    (Media): 33082
Orig Destn IP Address:Port (Media): [ - ]:0
Feb  9 10:29:37: //333541/000000000000/SIP/Call/sipSPICallInfo:
Disconnect Cause (CC)    : 127
Disconnect Cause (SIP)   : 200
Feb  9 10:29:37: //333532/85FF0019B257/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 OKVia: SIP/2.0/UDP 172.29.36.46:5060;branch=z9hG4bK3EB2C2BCall-ID: isbcofkakaotu4sku7cuabpf7bfa7hso2chc@SoftX3000From: <4818300>;tag=5C6FA0A8-227BTo: <112499444>;tag=sbc0805uu4dbk7o-CC-41CSeq: 106 BYEContent-Length: 0
Call Control Block (CCB) : 0x2B707F40
Called Number            : 4818300
Destn SIP Req Addr:Port  : 10.200.7.157:5060
Destn SIP Resp Addr:Port : 10.200.7.157:5060
Destination Name         : 10.200.7.157
Feb  9 10:29:37: //333532/85FF0019B257/SIP/Call/sipSPIMediaCallInfo:
Number of Media Streams: 2
Media Stream             : 1
Negotiated Codec         : g711ulaw
Nego. Codec payload      : 0 (tx), 0 (rx)
Dtmf-relay Payload       : 97 (tx), 97 (rx)
Source IP Port    (Media): 29418
Destn  IP Address (Media): 10.200.7.157
Destn  IP Port    (Media): 25778
Media Stream             : 2
Negotiated Codec         : No Codec
Negotiated Codec Bytes   : 0
Nego. Codec payload      : 255 (tx), 255 (rx)
Negotiated Dtmf-relay    : 0
Dtmf-relay Payload       : 0 (tx), 0 (rx)
Source IP Port    (Media): 0
Destn  IP Port    (Media): 0
Feb  9 10:29:37: //333532/85FF0019B257/SIP/Call/sipSPICallInfo:
VIP Super Bronze
This is not a detailed CUCM trace. Please send the full CUCM trace
I have run CCSIP error messages, ccsip call, and ccsip message.  this is running on CME.
VIP Super Bronze
Looking at the logs you posted, they are incomplete. Please add the following config to your router
conf t
service sequence-numbers
service timestamps debug datetime localtime msec
logging buffered 10000000 debug
no logging console
no logging monitor
default logging rate-limit
default logging queue-limit
Then..
debug ephone state
debug ccsip all
(such as Putty)
then do the ff:
terminal length 0
show logging
Attach the debug to the thread,,dont paste it please..
Please see attached debug:
Calling number 0112499444
called    01148118300 extension 998
THanks in advance
HI,
Also, please see attached CME configuration.  I only included the SIP part as it is the ony one that is having a problem.
THanks in advance
552
