sip to sip codec change from g729b to g711u
I tried implementing internal transcoding on a Cisco 2431 IAD with no success.  The setup is that from SBC inbound codec must be set to g729br8 first and then to PBX outbound codec must leave IAD at g711ulaw.
Can you give any advice as how to achieve this.  See below config
voice class codec 101
codec preference 1 g729br8
codec preference 2 g729r8
codec preference 9 g711ulaw
codec preference 10 g711alaw
sccp local FastEthernet0/0
sccp ccm <x.x.x.x> identifier 1 version 4.0
sccp
sccp ccm group 1
associate ccm 1 priority 1
associate profile 1 register UBEXCODE
keepalive retries 1
keepalive timeout 10
switchover method immediate
switchback method immediate
dspfarm profile 1 transcode universal
codec g711ulaw
codec g711alaw
codec g729ar8
codec g729abr8
codec gsmfr
codec g729r8
codec g729br8
maximum sessions 10
associate application SCCP
dial-peer voice 101 voip
voice-class codec 101
incoming called-number 12345
dial-peer voice 400 voip
description toPBX
destination-pattern 12345
session protocol sipv2
session target ipv4:192.168.1.2
codec g711ulaw
dtmf-relay sip-notify rtp-nte
telephony-service
max-ephones 1
max-dn 1
ip source-address x.x.x.x port 2000
sdspfarm units 1
sdspfarm transcode sessions 10
sdspfarm tag 1 UBEXCODE
Everyone's tags (3)
VIP Super Bronze
Ricardo,
So what are you h aving problems with. ?? The call is not working or the xcoding is not happening..
Can you do a test call and send the ff:
debug voip ccaip messages
debug voip ccapi inout
sh sccp connection
sh call active voice brief
Please rate all useful posts "The essence of christianity is not the enthronement but the obliteration of self --William Barclay"
The call comes in and goes dead soon after.  I get a slow reorder like tone.
When call comes in I do sh sdspfarm sessions active but their is no activity.  The sccp connection is active and up.
Unfortunately the device was rolled back to an old config and pointed to an asterisk box in the interest of the customer as such I cannot run the debugs you ask for.
So yes transcoding isnt working.
When inbound call comes in and I ran 'sh call active voice com' I see incoming leg at g729br8 and outgoing at g711ulaw then I repeat the command and see both incoming leg and outgoing leg change to g711ulaw just before the call fails.
Sad thing is that I have no visibility into the PBX.  All I know is that it accepts only g711ulaw in and outbound.
VIP Super Bronze
Re: sip to sip codec change from g729b to g711u
You said the call changed to g711ulaw, so that suggests the g729 part of the call was xcoded to g711u. Otherwise you would see the call remaining as g729/g711.. The only strange this is that you said you dont see an active session on the xcoder.
Ideally this is what will happen. The side of the call that needs xcoder will do g711 to the xcoder and the othersie will use whatever codec is set either on dail-peer or region..
Eg,
536955078  537018410    xcode sendrecv g729    20998 20418 110.115.90.54
536955078  537018407    xcode sendrecv g711u   30948 27456 110.195.60.10
The leg that has G711u to the xocder is the one that invoked the xcoder.
VIP Super Bronze
      For future purposes here is the link to use for CUBE xcode. Its really good. It also helps with troubleshooting
http://www.cisco.com/en/US/products/sw/voicesw/ps5640/products_configuration_example09186a008092d6b3.shtml
Thanks for the advice.  I will look out for what you said in my next attempt.
1318
