SIP to SIP gateway with POTS lines for 911 configuration
Hello All,
  I'am doing a setup with a CUBE and CUCM 7.x.  The CUBE also has pots lines for 911 calls,  I'am using a SIP trunk to the CUBE from CUCM 7.x for all outbound calls including 911.  I supposed I could do the 911 in H.323 but if I send the 911 calls to the gateway via SIP, what will I need in the configuration besides the normal pots dial peers?  I have the voip service voip currently conifugred with sip to sip and sip to h.323. Thanks
Jason
1 ACCEPTED SOLUTION
Re: SIP to SIP gateway with POTS lines for 911 configuration
you just need an explicit matching to 911 under your pots dialpeer pointing to the pstn
1 REPLY
418
