SIP to SIP transfer to CUE fails with Codec ILBC
Natalie Ramirez
ip phone ----  CME ------ CME ---- ip phone --> Successful
ip phone ----  CME ------ CME ---- CUE --> Fail
If I change the Codec to G711ulaw, it works fine, successful on both.  But if I change it to ILBC, which I want to run on my excessivly low bandwidth WAN link, it fails when the call is forwarded to voice mail.  I have seen multiple questions that were answered with, just change to G711, and this fixes everyones issue.  I know G711 works, I want ILBC to work.
alright, however your issue seems to be with a transcoder, Check on the SITEB status of the show SCCP
TCP states?
Transcoding Oper State: ACTIVE_IN_PROGRESS - Cause Code: TCP_CONN_ERROR
Active Call Manager: NONE
on both CME run below command
# no sccp
#sccp
and check again the status of the xcoder? if possible i would sugesst try to re-configure xcoder fro scratch.
use this as reference for configuration for transcoder
http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/admin/configuration/guide/cmetrnsc.html
Do let me know if you if stuck anywhere
Br,
Nadeem
Please rate all useful post.
Br, Nadeem Please rate all useful post.
11 Replies 11
Nadeem Ahmed
Hello Clark,
CUE by default works on G711 codec,that's why it works for you when you change the codec.
Do you have a xcoder configured to stream one audio to another?
Br,
Nadeem
I think I configured the xcoder correctly, see below, IP address listed is the IP address of the router local interface, is it supposed to be the IP address of the CUE?
2811 router, site A:
voice-card 0
dspfarm
dsp services dspfarm
sccp local FastEthernet0/0
sccp ccm 192.168.192.14 identifier 1 version 7.0
sccp
sccp ccm group 1
associate ccm 1 priority 1
associate profile 1 register TRANSCODER
dspfarm profile 1 transcode
codec g711ulaw
codec g711alaw
codec g729ar8
codec g729abr8
codec ilbc
maximum sessions 2
associate application SCCP
3725 Rouer, Site B:
voice-card 0
dspfarm
sccp local GigabitEthernet0/1.10
sccp ccm 192.168.10.1 identifier 1 version 7.0
sccp
sccp ccm group 1
codec g711ulaw
codec g711alaw
codec g729ar8
codec g729abr8
codec ilbc
maximum sessions 2
Nadeem Ahmed
No you do need to cue IP address
Can please paste the below command and config from router
Show sccp
Site A:
sh sccp
SCCP Admin State: UP
Gateway Local Interface: FastEthernet0/0
        IPv4 Address: 192.168.135.14
        Port Number: 2000
IP Precedence: 5
User Masked Codec list: None
Call Manager: 192.168.192.14, Port Number: 2000
                Priority: N/A, Version: 7.0, Identifier: 1
                Trustpoint: N/A
TCP Link Status: CONNECT_PENDING, Profile Identifier: 1
Reported Max Streams: 8, Reported Max OOS Streams: 0
Supported Codec: g711ulaw, Maximum Packetization Period: 30
Supported Codec: g711alaw, Maximum Packetization Period: 30
Supported Codec: g729ar8, Maximum Packetization Period: 60
Supported Codec: g729abr8, Maximum Packetization Period: 60
Supported Codec: ilbc, Maximum Packetization Period: 120
Supported Codec: rfc2833 dtmf, Maximum Packetization Period: 30
Supported Codec: rfc2833 pass-thru, Maximum Packetization Period: 30
Supported Codec: inband-dtmf to rfc2833 conversion, Maximum Packetization Period: 30
Site B:
show sccp
Gateway Local Interface: GigabitEthernet0/1.10
        IPv4 Address: 192.168.10.1
        Port Number: 2000
IP Precedence: 5
Call Manager: 192.168.10.1, Port Number: 2000
                Trustpoint: N/A
SCCP application services(dspfarm profiles) are not enabled
or haven't associated to SCCP CCM group
I updated it with the IP address of the CUE, but it appears to be showing the same error:
Site A:
sh sccp
        Port Number: 2000
IP Precedence: 5
Call Manager: 192.168.192.15, Port Number: 2000
                Priority: N/A, Version: 3.1, Identifier: 1
                Trustpoint: N/A
Reported Max Streams: 4, Reported Max OOS Streams: 0
Nadeem Ahmed
Sorry it was typo error
I mean you do not need put cue IP address
Hello Clark
Here is the issue, Your xcoder is not working due to TCP connection is not established and error, due to which xcoder is not getting invoked and calls are getting failed due to codec mismatch as no one there to stream the audio from one to another.
Site A:
sh sccp
        Port Number: 2000
IP Precedence: 5
                Trustpoint: N/A
Where is CUE is located is it on SITEA or SITEB?
Br,
Nadeem
Each site has its own CUE.  They are not sharing.
TCP states?
# no sccp
#sccp
Br,
Nadeem
You were right, improperly configured the transcoder.  I checked the web link you provided, but it was a little difficult to understand, so I searched for transcoder configurations and found this one:
https://supportforums.cisco.com/thread/290915
Dropped this on the routers and everything popped up working with no issues.   Thanks again for your help.
Perfect Clark , Glad to hear that :-)
Br,
Nadeem
