sip to vofr in dial plan?
Hello all, I am working with a 3845 and would like to deliver calls received by the router from a sip proxy through the router via dial-peer statements which use voice over frame. Is this possible?
Should this just work or do I need to configure something under "voice service" "allow-connections" to make this work?
Sorry if I sound naive :)
Thanks!@
Thanks!
1 REPLY
Hall of Fame Super Gold
Re: sip to vofr in dial plan?
Should work. Not sure if you would need an ip-to-ip gateway image.
115
