SIP Trace Configuration
Hi guys,
I am using trace to debug a SIP endpoint registration:
SIP Device is configured to register on a specific server in the cluster, so I am concentrating the trace settings on that server.
In particular I activated :
Trace --> Configuration --> SERVER IP --> CM Services --> Cisco Call Manager and:
     Enable SIP Stack
     Enable SIP Call Processing
     Enable SIP Keep Alive
However, in the trace I get the following results:
And no SIP TRACEs
Mike
1 ACCEPTED SOLUTION
Uncheck the box "Device Name Based Trace Monitoring" and try, it should be fine.
Manish
SIP Door Phone Registration
I must add that eventhough some SIP messages appear, I keep getting a lot of :
mn::mgcpendpoint related messages
which look informational and I cant get rid of, even though MGCP TRACE is disabled.
any idea?
Mike
Manish
Hi Manish,
I will try, however, I made sure the right device was included in the selection. That flag was to keep too much gargage from entering the logs
I will let you know,
I tried, but I still get flooded with MGCP messages and no SIP.
Maybe a services needs to be bounced to take modifications?
mike
YES,
that was it, maybe I didnt completely understand the meaning of the flag then.
I was sure I selected the right devices to appear in the log
Thank you,
Mike
Hi Mike,
Just to add here, i do not see this option in cucm 9.x, so its probably due to the following
http://tools.cisco.com/Support/BugToolKit/search/getBugDetails.do?method=fetchBugDetails&bugId=CSCsv30023
remove device name based trace monitoring from web page
Symptom:
Events missing from CM SDI/SDL traces.
Conditions:
Devicename  based trace monitoring configured.  Devicename based trace monitoring  filters some events from traces that are directly related to the device  being monitored.  This is a limitation of the feature.
Workaround:
Never use devicename based trace monitoring.
Further Problem Description:
Devicename based trace monitoring is not maintained.  It is overly filtering traces so critical events are not visible.
Manish
Awesome,
thank you,
Mike
268
