SIP TRUNK 503 Service Unavailable
We have an issue with calls from PSTN. When we received a call from PSTN the caller hears an IVR and then press the option "2" then the caller should be transfered to extension 96537, that is another IVR, but the caller hears ringback and then the call is dropped.
Our call flow is like this:
PSTN > R2 > GW > SIP > CVP > SIP > CUCM > H323 > SME > 96537
Atteched the call log from GW, in that log we saw this message:
NOTIFY sip:10.1.1.13:5060;transport=udp SIP/2.0
Via: SIP/2.0/UDP 150.212.102.250:5060;branch=z9hG4bK3E22427
From: <sip:5556236510@150.212.102.250>;tag=11A617A4-798
To: <sip:3007@10.1.1.13>;tag=ds7d41310a
Call-ID: F07DEE62-669B11E3-8E71C240-5FB154C1@150.212.102.250
CSeq: 103 NOTIFY
Max-Forwards: 70
Date: Tue, 17 Dec 2013 21:49:42 GMT
User-Agent: Cisco-SIPGateway/IOS-15.3.3.M
Event: refer
Subscription-State: terminated;reason=noresource
Contact: <sip:5556236510@150.212.102.250:5060>
Content-Type: message/sipfrag
Content-Length: 35
SIP/2.0 503 Service Unavailable
039256: *Dec 17 21:49:42.639: //0/000000000000/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 Ok
Via: SIP/2.0/UDP 150.212.102.250:5060;branch=z9hG4bK3E11BE0
CSeq: 102 NOTIFY
Content-Length: 0
Allow-Events: refer
Allow-Events: kpml
Allow-Events: cvp-transfer
I hope you can help me.
Regards.
A correction from my last messege
The call flow is like this:
PSTN > R2 > GW > SIP > CVP > SIP > GW >  CUCM > H323 > SME > 96537
Sorry for my error.
Regards.
Hi CCoria,
Can you please share your SIP trunk snapshot from CUCM?
Also share the configuration of all the gateways.
Also please clarify your call flow once as CUCM connectivity is not cleared yet.(Is R2 & GW is one device?).
Nishant Savalia
Regards, Nishant Savalia
it seems codec issue. have you configured 'early-offer forced' command in GW pointing to CUCM.
If I understand correctly, the inbound call coming from PSTN is transferred by CVP to GW and then to CUCM for extn: 96537.
The SIP Invite message from CVP to GW has no SDP. Also the SIP Invite from GW to CUCM has no SDP as it might be missing the EO Forced command.
in case if it is not configured previously, you can enable the Forced EO in 2 ways.
1) under the "voice service voip" -> "sip" configuration, configure 'early-offer forced'
2) under the dial-peer, the command will be "voice-class sip early-offer forced" . This will only take effect when  the call hits this dial-peer while the previous command under "voice service voip" will have global effect. SDP info would be from the codecs configured under outgoing dial-peer.
Please ensure you configure the Outgoing Dial-peer=96537 with voice class codec consisting g711a, g711u & g729 codecs
when the GW sends the INVITE without SDP to CUCM, the CUCM sends the 200 OK message with G729 codec in the sdp.
039123: *Dec 17 21:49:40.615: //2100/F07CB6128E6C/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 OK
Via: SIP/2.0/UDP 150.212.102.250:5060;branch=z9hG4bK3DE470
To: <96537>;tag=8933~4edf650c-7a65-470e-8db1-1714957ea965-46001607
Date: Tue, 17 Dec 2013 21:56:50 GMT
Call-ID: F6BD0C3F-669B11E3-8E8AC240-5FB154C1@150.212.102.250
CSeq: 101 INVITE
Allow: INVITE, OPTIONS, INFO, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY
Allow-Events: presence
Supported: replaces
Supported: X-cisco-srtp-fallback
Supported: Geolocation
Session-Expires:  1800;refresher=uas
Require:  timer
P-Asserted-Identity: "Opcion 3 SUN" <96537>
Remote-Party-ID: "Opcion 3 SUN" <96537>;party=called;screen=yes;privacy=off
Contact: <96537>
Content-Type: application/sdp
Content-Length: 257
v=0
o=CiscoSystemsCCM-SIP 8933 1 IN IP4 150.211.101.253
s=SIP Call
c=IN IP4 10.2.1.5
b=TIAS:64000
b=AS:64
t=0 0
m=audio 24652 RTP/AVP 18 101
a=rtpmap:18 G729/8000
a=ptime:20
a=fmtp:18 annexb=no
a=rtpmap:101 telephone-event/8000
a=fmtp:101 0-15
>> is the codec negotiation between CUCM & GW configured as G729? Please crosscheck the SIP trunk configuration & region settings for this.
>> The call is disconnected with "Reason: Q.850;cause=65" indicating "no matching codec".
>> As it is CVP, we may need to configure the dial-peers with G711ulaw towards CVP.
//Suresh Please rate all the useful posts.
Hi Sureshsub2
Our codecs should be like this:
All devices behind CUCM should talk G711ulaw
CUCM and SME should talk G729
This are our dial-peers to CVP and ext. 96537
dial-peer voice 3009 voip
description CVP SIP Comprehensive dial-peer
destination-pattern 3009
session protocol sipv2
session target ipv4:10.1.1.13
dtmf-relay rtp-nte h245-signal h245-alphanumeric
codec g711ulaw
no vad
dial-peer voice 13009 voip
preference 1
session target ipv4:10.2.1.9
codec g711ulaw
no vad
dial-peer voice 96537 voip
destination-pattern 96537
session target ipv4:150.211.101.253
voice-class codec 1
no vad
And my voice-class codec is this:
voice class codec 1
codec preference 1 g711ulaw
codec preference 2 g729br8
codec preference 3 g729r8
150.211.101.253 is CUCM 9.1
10.1.1.13 is CVP CALL/VXML SERVER A
10.2.1.9 is CVP CALL/VXML SERVER B
Regards.
César Coria
Did you try with the early-offer forced command in GW? Can you pls share the compete GW config? Also do you have transcoders in CUCM for CVP to SME calls?
696
